Question about Ricoh Aficio 1035 Copier
RICOH AFICIO 1035 I GET AN ERROR CODE SC326 AND PAPER KEEPS GETING JAMED WHERE IT TRIES TO ENTER THE BIG GREEN ROLLER.
  • 1,110 Answers
SC326 is a laser synch detect error. The jamming is probably just because of the code popping up and the machine shutting down. 9 times out of 10 the cause of an SC326 is toner dust buildup on the laser optics. It is either that or possibly a laser unit (LD Unit) failure. The power to the LD unit flows thru the front door switches and I have seen those go bad and cut or reduce power to the LD unit which will cause the same code. I would get a Ricoh tech out to clean the laser optics. This is especially true if you open the fron door and there is toner dusting around the toner cartridge/DV unit area.
Good Luck and Thank You for using Fixya.
Posted on Aug 31, 2010
MY RICOH AFICIO MP C6000 IS SHOWING AN ERROR CODE SC326
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Mar 05, 2011 | Ricoh Aficio 1035 Copier
Sir my Ricoh 1045 machine have SC 326 problem, after taking a single copy the error code comes. please give a good solution to clear my problem. thanks
sc326 is a laser synchronization error. The problem is usually caused by the laser sync detection board or the LD unit.
Jun 02, 2010 | Ricoh Aficio 1035 Copier
Ricoh aficio 1045 jams on duplexing
there could be multiple reasons for it to be jaming on duplex, just depends where in duplex it jams. most common for the age of the copier rubber rollers in duplex getting dirty or hard. like swan34 said try some type of rubber cleaner.
Feb 07, 2010 | Ricoh Aficio 1035 Copier
Code error SC 541 ricoh aficio mp2550
SC541 is a Fusing thermistor open (center) The temperature of the hot roller remained below 0oC for 5 sec at the center of the hot roller. Fusing thermistor out of its position because of incorrect installation. Fusing thermistor disconnected or defective power supply not within rated range (15% or more below rating). Try cleaning or replacing the thermistors and reset code in service mode.
Jan 30, 2010 | Ricoh Aficio 1035 Copier
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Aficio 1035 ARDF cannot pick papers most likely when they are over 4 sheets
Clean the takeup roller and feed belt with a damp rad (water). If that doesn't help, you man need to replace the roller, belt, seperator belt and possibly the sep roller torque limiter.
Sep 24, 2009 | Ricoh Aficio 1035 Copier
My machine show c 210
Please specify the machine model,in the Ricoh 1035 not exist the C210 error code.
If your machine show CC201=When the paper jam condition is not reset for 10 minutes the code is automatically generated.For reset please enter in the SP mode turn main switch OFF,unplugged and wait 10 sec.Plugged and turn ON the power switch.
Sep 05, 2009 | Ricoh Aficio 1035 Copier
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Oct 20, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh Aficio 1035 Copier Logo
1,172 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
