posted by WHKoenig on May 09, 2008
I have four of these motherboards and all give the same problem. Two of them have Intel Quad Core processors installed with 2 Gb Ram and two of them have Intel Core2 Duo processors installed with 4 Gb Ram. All have qualified PCIe x 16 Graphics cards installed in the "blue" slot. Two have 160 Gb HDDs and two have 500 Gb HDDs. All have 52X CD-Rom Drives. All turn on and fans run and lights lite up, but nothing happens on the monitors. I have reset the CLRTC per the manual pg. 1-26 and still no good. Please advise?
Comment by WHKoenig, posted on May 10, 2008
There are four seperate monitors, all working, checked out on other machines. No extra power pins on video cards. Monitors are plugged into video cards. Motherboard manual showes these video cards compatible with motherboard. I was very careful when assembling to ensure no static discharge to the equipment. Please advise? Thanks, William
Best Solution
posted on May 09, 2008
1.make sure your monitor is plugged on the video card.
2.check *********** board manual for videocard slots.
3.check your videocard if they nid extra power from four(4) pin
female power cable or six pin female power cable.
4.try using another monitor.. or TV XD
Rating Locked! (?) WHKoenig has rated this solution as Thanks for Trying
Suggest a new solution for this problem
Post a New problem for ASUS P5N-E SLI Motherboard
Email this problem
Email this problem
Can you Help with these Motherboards problems?
Blank Screen, no beeps, New...
System: Asus P5N-E SLI Quad 2... Answer This...
Repair Service
Find Motherboard Repairman Near You:
