Copies have black vertical line down center of the page when fed through automatic feeder, but it doesn't happen if you place them inside manually.
Check your glass and rollers where the paper feeds through the machine. Most like they just need to be cleaned. Can be done with a q-tip or tissue and a little rubbing alcohol.
Posted on May 09, 2008
Copier leaves a black line when printing through the top paper feeder. Ok coping from the flatbed
When copying from the feeder the page is fed across a fixed point at the head of the flatbed. Any dirt etc on the glass at this point can present as a dark line running vertically down the printed page. When copying from the flatbed, the scan head is moved down the page so any dirt on the glass will only appear as specs. Try cleaning the glass, especially at the head of the flatbed where the feeder is loading the page to be copied.
Jan 12, 2014 | Office Equipment & Supplies
Black lines down on printed page
This is caused by dirt/debrise on the ADF (automatic document feeder) scanner glass. You need to open up the feeder where your originals are fed in and look for a strip of glass that runs from front to back. It is about an inch or so wide. You need to clean this glass to get rid of the lines. Some models have this glass just to the left of the large main glass, but in your case I beleive it is in the feeder itself.
Good Luck.
Apr 23, 2010 | Brother MFC-7820N Printer
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
Vertical lines about one half inch apart down center of the page when fed through the document feeder. No problem with fladbed copying or scanning.
If you open to document feeder and look at the glass when scanning via flatbed, just to the left will be a smaller piece of glass. That is the glass used when scanning through the feeder. Clean that glass as there is probably a couple of spots on it.
Jun 30, 2009 | HP LaserJet 3030 All-In-One Printer
Two lines, one on each side of copies made from feeder and faxes
Try cleaning the rollers inside the scanner including the glass inside and out with a soft damped cloth. Look also for a piece of paper, staple wires, paper clips or pencil lead jammed inside the rollers or somewhere in the corner.
Also, look for a foreign object or substance on the cold cathode tube light and clean it. Try also cleaning the mirror.
May 24, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
ADF has something on it causing a stripe on all copies
Lift the document feeder and clean the narrow glass, (next to the glass where you place your originals). Documents are scanned across this glass when automatic feeder is used, thus a small piece of dirt becomes a line down the page.
Feb 24, 2009 | Canon ImageClass D880 Copier
Full page vertical line appears on copy fed pages.
Open up the document feeder. You will probably find wite-out on the scanner glass.
Dec 12, 2008 | HP Officejet 5510 All-In-One Thermal...
Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
155 people viewed this question
