Need arm for Phillips TV model # 37pf9631d/37 part #313912877751
Screen wont come on, LED blinks once then 4 times whats this error code and where do I begin?
hiya
the power board has failed are you happy with opening the back of the tv? if so then look at the board for any capacitors that have domed and unsolder them and replace
this is a known issue which phillips know about and refuse to address from what i can gather they hope that customer get fed up with complaining
hope this helps
John
Oct 26, 2011 | Philips 37PF9631D 37 in. LCD HDTV
Where can i find a service manual for the philips 37 pf9631d tv i need a schematic for troubleshooting thecomponents on the boards
What type of defect? most of these are board level repair.
you can purchase the manual from encompass electronics if you need it.
Feb 18, 2011 | Philips 37PF9631D 37 in. LCD HDTV
I have a phillips lcd hdtv. When I turn it on the light blinks 6 times. I'm sure its the power supply board, my question is how do i repair the power supply board without replacing it? I have a power...
look ON THE POWER SUPPLY FOR SWOLLEN CAPASITORS. usually 2 RIGHT BY HEAT SINK. VALUE VARIES... REPLACE ANY SWOLLEN CAPASITORS AND SHOULD SOLVE PROBLEM
Feb 17, 2011 | Philips 37PF9631D 37 in. LCD HDTV
How do i get the stand off my tv
first pop the base off by pushing in on the four tabs simultaneously and pulling it out... once you have the base off you will need a long phillips head screw driver to get the single screw inside the arm that is connected to the base loose. After that you can work the arm off and your stand will be completely removed.
Aug 05, 2010 | Polaroid TLX-01911C LCD TV
Philips Cineos flat screen TV vith Ambilight 37PF9631D/10, went in standby and blinking red power led diode once-two times in cicles.
Sounds like an issue with the power supply board. We will have to go component by component and you will need to knowledge of using a multimeter. If you are skilled enough to do this then let me know and I will help you troubleshoot it.
Mar 19, 2010 | Philips 37PF9631D 37 in. LCD HDTV
I have a Phillips tv model no 20GX8350/75R and need to find the remote for it as the universal remote i bought will not work. Kmb.
I have a phillips tv, i have a living solutions universal remote control . need codes for phillips tv
Jan 20, 2010 | Philips Televison & Video
I cannot get the tv to recognize the firmware upgrade i downloaded from philips, any suggestion?
Contact Phillips. They can walk you through the process and determine where the error is occurring.
Joe
Dec 20, 2009 | Philips 37PF9631D 37 in. LCD HDTV
Red blinking light
The red light blibking 6 times indicates that the power supply board has a defective or damaged area. I know this because i had the same problem...bought a damaged tv for parts and replaced the power supply board as the tv would not turn on...wokrs like a charm now.
Jul 24, 2008 | Philips 37PF9631D 37 in. LCD HDTV
Phillips 37 LCD Service Manual
http://www.eserviceinfo.com/most_popular/list_5800.html
https://www.manualsparadise.com/Sho...model=M31429247
https://www.completeservicemanuals.com/panasonic/digital-camera/lumix-dmc-fz5-service-manual/prod_86.html
http://www.user-service-manuals.com/Sony/UP.shtml
http://www.schematicsforfree.com/
Mar 09, 2008 | Philips 37PF9631D 37 in. LCD HDTV
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
Electro Med Services...
