New error after installing a dell hard drive w/os on it
Could you read my LAST post and tell me if you know what I need to do?
Things appear to be ALMOST working so I'm not ready to give up yet!
Thank you!
Michele :-)
You are a skank!
Posted on May 11, 2010
My laptop is telling me i have an error 0141
The Dell error code 0141 is a hardware related error which appears when you first load your Dell computer. The error that normally appears will have the error code "2000-0141? and will relate to the hard drive components of your computer. This error generally shows even though there might not be anything wrong with your PC.
  • Corrupt or damaged Windows processes
  • Damaged registry settings on your system
  • A computer infected with viruses or malware
Update your antivirus and rescan your computer. If is showing again you have to re-install the OS
thanks & regards
Anas K A
Jun 27, 2011 | Dell Inspiron 1525 Notebook
1st, my desktop (dell Dimension 5100) had been not used for several months. When turned on, the green error code lights 3, 4 and a flashing battery appeared, along with a beeping noise. I read up on the...
I assume your new computer has IDE controller on the motherboard.
Yes you can install your old hard drive into your new computer as a Slave hard drive.
If the old hard drive is installed on the 2nd IDE controller and it is the only device on the controller then the jumper and be master or slave, but connect the hard drive at the last connector on the IDE cable.
Oct 18, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Unable to restore back to factory image read error
Are you using Factory CD/DVD or Made from utlity Disks or from hard drive utility option.
This seems to be a CD read error.
I found the same error code need help for posted for HP, Compaq, Gateway, ETC.
ALL new setups with the MAKE RECOVERY DISK UTILITY and NO factory disks.
Factory recovery disks are available for $60 and up from manufacturers.
Other option is Install Retail OS - get drivers from manufacturer - Install software you want to use.
Other option is expensive but reliable.
Factory option would be for your system only.
Apr 05, 2010 | Computers & Internet
Dell latitude c600 is not reading the hard drive . what should i do?
Most likely you will need a new hard drive installed. Hard drives come blank, so you will need an OS installed on it as well if you get the new hard drive.
Mar 12, 2010 | Computers & Internet
I cannot install any OS in my aspire m5641. blue screen always appear when i install windows xp... and if i use vista it requires driver for my cdrom drive to continue. what shouli do? pls help...
Hello there
please tell me during the blue screen is there any error message
you can also try boot to the safe mode and see if you can do it from there
also you can boot to the bios screen and check the setting for the cd rom and if needed set the system back to default settings and save and reboot and see what happens please keep me posted on this there is still more things that we can do ok
best regards
Aug 05, 2009 | Acer Computers & Internet
Hard drive not seen in dell latitude d600 after upgrade to vista
Your hard drive may need reseating.
If it still gives error hard disk not found then you have a faulty hard drive.
You need a new hard drive and then install Windows Vista
Mar 23, 2009 | Dell Lattitude D600 Notebook
Hard disk error
Unfortunately this error occurs with a fault hard drive. You will need to replace the hard drive and then reinstall the OS.
Mar 20, 2009 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
1. purchase a 2.5" usb enclosure.
2. remove your hard drive and install in the enclosure.
3. plug the enclosure into a working computer and copy or move your important files onto working computer.
4a. reinstall the laptop hard drive and try a repair installation by booting from the XP cd. (if you are running xp)
4b. reinstall the laptop hard drive and try booting to Last Known Good Configuration. Press either the F5 or F8 key while rebooting to get to the menu.
4c. purchase a new hard drive and reinstall the OS using the reinstallation cd's
Dec 09, 2008 | Dell Inspiron 1501 Notebook
Dell c640 laptop
Hrmm be nice huh, lets see, First you have to rip it all apart, kidding =)
I will assume you have been using this laptop prior to this happening.
Your computer is telling you it cannot find anything to start loading Windows etc
This is normally on your hard drive. If your hard drive fails or the system cannot find it, then it will give this message.
You can also use the CDrom to boot, but this is what you would use if there was a new hard drive without Windows installed.
This page will show you and give you full instructions on how to remove the hard drive. After you find it, do not remove it all the way, just slide it out an inch or so and then just slide it back in and put the screw back in.
Turn the laptop back on and see if that fixes the problem, sometimes they just need to be reseated.
Post bak your results and if it is still doing nothing we can try more things.
Apr 16, 2008 | Dell Latitude C640 P4 Mobile Notebook
Dell Latitude will not boot
Reseat the hard drive and then get into bios and check if the hdd is detected ,if not you need to replace the hdd ,if detected reinstall the OS.
Apr 03, 2008 | Dell Latitude C600 Notebook
Computers & Internet Logo
David Payne
David Payne
