Question about JVC Audio Players & Recorders
I need to set the balance on my tone arm I have a model AL-F3
  • gievo Aug 31, 2010
    Not on this model the back of the tone arm does not turn but it has an anti skating dial that goes from 0-3
  • gievo Sep 01, 2010
    I have a perfectly good record skipping so what should I set the anti skate number to it has 2 - 3 digit calibrations in inner and outer circle?
  • 864 Answers
This is not a problem i have many turntables and have worked in repairing them for years. But since it is not broken and you just need to set the weight of the tone arm this is not a problem. If you look at the tone arms pivot point. On the end of the tone arm you will see a round black weight. Turn it till it is at about 1-1.5 grams of weight. This should be the proper adjustment. if you still have issues with skipping cause the weight isnt heavy enough turn the tone arm back more in small increments till it is the proper weight. If you cant figure it out or have any other problems please follow up with a comment and from there i will be glad to assist you. Thanks, Midwest-tek
Posted on Aug 31, 2010
  • 1 more comment
  • Nathan Ayers
    Nathan Ayers Sep 01, 2010
    anti skate has to do with skipping and retraction. But if it doesnt have a adjustable balance weight thats because it is a household unit and the weight is preset from the factory. What is happening that you feel you need to adjust the balance of the tone arm?
  • Nathan Ayers
    ya set the anti skate 1 digit at a time. And work it through another thing i can recommend is to get a level out. Then place it on the platter closest to the needle and make sure the turntable is level. But if its weighted at the factory and you want more weight and the anti skate wont work. What i would do tape a penny or a dime on the top of the needle. ive used it on 60s-70s turntables that dont have adjustable weights. but when you do this it adds roughly 2.5 grams for a penny or a dime will add 2.3 grams. You can also tape something smaller on the top of the needle to add more weight. I know of dj's that tape several pennies to the top of there needles to reduce shock and movement of the needles. But the anti skate should solve any problems you have.
  • Nathan Ayers
    also make sure the records are cleaned you can do this by taking zippo lighter fluid and putting it on a microfiber towel then letting the record spin will you hold the towel just lightly enough to leave a trace that there is lighter fluid on it. Only use zippo type lighter fluid.
I have a realistic clarinette 120 turntable . How do I replace the needle?
Most are held in place by 2 small screws, remove them and carefully unplug the cartridge from the tone arm, reverse to install new one, then check the balance the tone arm and set to correct pressure..
Dec 23, 2016 | Audio Players & Recorders
Crosley CR6019A turntable skips
Hi
Being a portable model, it is very easy not to have the turntable level. It is very important that it is level as a tilt can lead to the head "skipping", amongst other things.
You can get a full User Guide here
http://0bee184f253cf7f48610-d2b1caba160808a264f409f8f32a9b54.r0.cf3.rackcdn.com/Crosley%20CR6019A%20%20Executive%20Turntable.pdf
Another possible problem is that the balance has become upset by being moved around. The correct balance is achieved b the positioning of a weight on the tone arm on the opposite end to the needle. This can usually be moved short distances to balance the tone arm so that the needle is held in the record groove, by the minimum necessary weight on the needle.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 26, 2014 | Audio Players & Recorders
Arm skiips across record
The tone arm needs balancing. You need more force (weight) on the front of the tone arm. Here are three links which will describe how to balance it.
Charlie
http://stereos.about.com/od/systemsetup/ss/Turntablesetup_3.htm
http://www.youtube.com/watch?v=IoIHn2g0398
http://balanceyourtonearm.com/
Feb 01, 2011 | Spectra SB6053 Turntable
Record keeps skipping arm won't move toward center of record
Sounds like your arm is tracking too light. To proper set the tracking weight on most units you need to zero the arms balance so that it is balanced just at the surface of the record. Once that is done using the weight on the back of the tone arm, or whatever system your unit uses, there should be an adjustment by turning the weight on the arm or perhaps a lever near it. You owners manual should really explain all this and give the recommended tracking weight in grams and fractions of grams. Each weight is different for different styli. Take a look at your operation manual and adjust the weight. Let me know how you make out.
hardrocko
Thanks for using FixYa
Feb 22, 2010 | Numark ttUSB Turntable
My brandnew Songwriter is not playing records properly. When a quarter is placed on the tone arm, it plays fine. Is there an adjustment I can make??? Marilyn
http://www.crosleyradio.com/Manuals/CR248_Manual.pdf
I didn't see the tone arm balance adjustment in the user manual, however that is what needs to be done. At the rear of item #39, on page 10, is there a dial with numbers from 0 to 4 or 5? If so, set the dial to "0" to see if the tone arm will "balance" (like a see saw) If not, the dial assembly (which is a weight) needs to be slid either forward or backwards to achieve balance. After balancing, turn the dial to a number higher than 0 to increase tracking force..keep increasing the tracking force until it stops skipping, but no more than necessairy. To much force causes wear/damage to albums. If there is no tracking force adjustment on the tone arm, I would suggest contacting Crosley @ http://www.crosleyradio.com/Support.aspx
Hope this helps.
Aug 18, 2009 | Crosley CR248 Turntable
Difficulty balancing the tone arm on kd-1033 turntable.
A new stylus should not change the tone arm balance setting if it is the correct stylus.
Does your arm have a sliding balance weight at the rear of the arm? If so you can slide this slightly towards the cartridge to regain the correct playing weight.
I would suggest you get a repair shop to do this for you, or you could finish up damaging your records.
Jan 01, 2009 | Kenwood KD-291RC Turntable
I balanced my tonearms correctly. i think .. but the stylus jumps off the record and when i back spin (cue) the needle skates drasticly. can you walk me through the balancing proceedure and tell me how to...
Balancing the tone arm is a two step process. Set the needle weight adjustment to zero(0) and make sure that the tone arm is balanced. It should rest horizontally without touching anything. Next, set the needle weight (usually 1.5 grams). Both adjustments should be on the rear of the tone arm. That should cause the tone arm to drop toward the record and have the correct pressure for the needle. Also, check the anti-skate adjustment. If that is off, the behavior you describe will occur as well.
Dan
Jul 21, 2008 | Technics Audio Players & Recorders
Fisher turntable M-720 need to set weight and return levels
Hi mariahom
Setting the tracking force is an easy task. Try this method.
  1. first thing to do with the tone arm sitting above its rest, rotate the weight on the end of the tone arm until the tone arm is balanced in the middle. neither up nor down, just right in the middle.
  2. calibrate the numbered rotating collar on the weight so that 0 is exactly on the reference line on the tone arm.
  3. then turn the weight and numbered collar together to the tracking force that you are seeking. Most moving magnet cartridges need at least 1.5grams of weight. Set it for 2 grams if you are unsure of what your is or needs.
  4. adjust the anti skate dial(if you have one) to the same number as the tracking force you are using.
At this point you should be able to gently bounce the tone arm on your index finger(not above the record of course). This is about all there is to it.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jul 13, 2008 | Fisher Audio Players & Recorders
Well on my technics MK2 1210's, the little anti sketch settings and all the others probably arent set to what they are supposed to be, because my needle arm keeps jumping :P could someone tell me what all...
There are two main things that will influence the anti skate settings.
1) The Headshell Weight and Balance
Firstly, check the data sheet for the cartridge and stylus you are using. It should tell you the correct weight setting which will vary from one cartridge and stylus to another. If the stylus is set too light, it can skate across the disc. This can damage the disc and the stylus. The sound will also be thin and it is likely to distort on high frequencies. If the weight is too heavy, it will not jump but will definitely damage the disc.
If you are a serious vinyl user, get yourself a tone arm balance. This is a device that you place on the turntable and you rest the stylus on a plate which is marked in micrograms. You place the stylus exactly at the correct weight marking and then make adjustments to the turntable settings until the tone arm is balanced. It's easier than it sounds!
If you don't have the data sheet for your cartridge and stylus and cannot find it online, use an old disc that you don't mind damaging, set the weight on the light side and gradually increase the weight until it stops skating.
2) Platter Levelling
Secondly, you need to make sure your turntable us on a level surface. If you are a purist, use a spirit level. to do this.
There are other things that can cause skating and jumping, especially if you use the turntable as a DJ. For example, vibration (caused hopefully by dozens rocking to your music). DJs will often increase the headshell weight very slightly to overcome this and I have sometimes placed the turntables on a thick rubber sheet such as carpet underlay to improve shock absorption.
Mar 26, 2008 | Technics SL-1200MK2 Turntable
Tone Arm
It's very hard to get those screws aligned and tightened correctly. They are machine calibrated with the precise amount of torque. Once they become loose, it's very hard to get them back to original factory settings. Also, those screws are conical screws, which means they have a cone shaped tip on them. That cone shaped section sits on 4 very small ball bearings which balance the tonearm. There is a very thin piece of sheet metal which protects the ball bearings and keeps them aligned, if any of these parts are damaged, or bent in any way, your tonearm is damaged.
Unfortunately, if you can't get the balance correct, you will have to replace the tonearm. You can buy a new TONEARM HERE, however, replacing it, is a whole other process and not recommended if you have no soldering experience, as you could damage your unit even more.
Hope this helps.
- The 1200s Experts
Nov 17, 2007 | Technics SL-1200MK2 Turntable
279 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
