Question about Kodak Cameras
Kodack z 730 dead battery ok - Kodak Cameras
  • bridget-ray May 18, 2008
    with battery charged unit will notturn on dead.have checked battery and is ok
    Genius:
  • 3,422 Answers
Can you please describe your problem more clearly so that i can help you fix it.
Posted on May 18, 2008
  • Priya darshan May 18, 2008
    Possible causes and how to handle them
    1. The camera is not
    on
    Turn on the camera.
    (Operation procedure varies between camera models. Please refer to the camera
    user guide supplied with your camera.)
    2. The rechargeable
    battery is not fully charged.
    Make sure the
    rechargeable battery is fully charged. If the battery has not been used for an
    extended period of time, or if it is being used for the first time, it may not
    be fully charged. In cases like this, fully charge the battery and then
    discharge it completely in the camera several times to bring the battery back
    to its normal performance.
    The rechargeable
    battery's capacity diminishes the longer the battery is used. When the battery
    consumption becomes quicker, the battery life may be at its end. Replace the
    battery with a new one.
    3. The battery
    terminals are dirty.
    When camera does not
    operate with a brand-new alkaline battery (for cameras that use AA-size
    batteries) or with a fully charged rechargeable battery, the terminals may be
    dirty.
    Polish the terminals
    with a dry cloth and make sure the terminals are clean. If the terminals are
    covered with oil from your skin or similar matter, this may cause poor contact
    and power may not be fully supplied to the camera.
    Also, polish the
    battery charger terminals with a dry cloth before charging the battery. If the
    terminals are covered with oil from your skin or similar matter, this may cause
    poor contact and the battery may not be fully charged.
    4. The batteries are
    not installed correctly (for cameras that use AA-size batteries)
    For cameras that use
    AA-size batteries, multiple batteries are used in one camera. Make sure the
    direction of each battery matches the direction indicated on the camera. If any
    of the batteries are improperly inserted, the camera will not operate.
    5. The battery cover
    or CF card (SD card) slot cover is not securely closed
    Most cameras have a
    lock mechanism on the battery cover. The camera will not turn on if the battery
    cover is not locked or securely closed, or if the CF card (SD card) slot cover
    is not securely closed. Make sure these covers are securely closed.
I THINK MY BATTERY IS FRIED ON MY LG HBS 730
SOLVED: MY LG TONE HBS-730 WILL NOT CHARGE - Fixya
www.fixya.com/support/t17797017-lg_tone_hbs_730_will_not_charge
Apr 20, 2013 - MY LG TONE HBS-730 WILL NOT CHARGE When i plug the ... with this headsets to prevent frying the small battery, especially if they charge ...
fix/repair/extend battery of HBS-730/750/700 very easy and simple ...
? 1:44
https://www.youtube.com/watch?v=qLwpemHhLRc
Jan 30, 2017 - Uploaded by techtronicity
fix/repair/extend battery of HBS-730/750/700 very easy and simple way ... I put my headset to charge and ...Missing: fried
LG HBS-730 USER MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > LG Manuals > Headphone > HBS-730 View and Download LG HBS-730 user manual online. ... DOWN button for 1 second, you can check the battery status of the HBS-730 while in standby mode or playing music. ... My on & off switch on my 730 won't turn my earphones on.Missing: fried BATTERY IS FRIED ON MY LG HBS 730 Google Search
Jun 24, 2017 | LG Radio Communications
My HBS 730 LG Stereo Bluetooth head set doesn't seem to come on. It seems not to charge up according to its indicator light.
the rechargeable battery has died and usually not serviceable by the consumer .check with a phone store .
Dec 08, 2015 | LG HBM 730 Bluetooth Headset Wireless...
Lg hbs 730 problems
i have LG HBS 730 wireless headphones. When turning on they connect to my bluetooth and then just shut down. the battery is fully charged yet the headphones act as if it has a dead battery.
Dec 30, 2012 | LG HBS-700 Bluetooth Headset
My kodack easy share c183 camera will not charge
The C182 isn't a battery charger. It uses standard AA batteries, disposable or rechargeable. If you use rechargeable batteries, you must charge them outside the camera using a standard battery charger.
Dec 26, 2010 | Kodak Easyshare C182 12MP Digital Camera
Why does my tomtom go 730 not function when it is cold and how long should the battery work for
To my experience, battery capacity and life is very poor for the GO 730.
If brand new, the battery can last up to three hours but this degrades quickly. If its cold, the electrochemical process in the battery is slower, adding to the problem.
Also, switching off the TomTom does not really switch off, it goes to standby, still using a little power continuously. After a day or two this completely drains the charge.
I have my GO 730 since mid 2008 and battery is down to ten minutes of use after a full charge. In my car I use the provided car DC adapter, so I do not mind the bad battery too much.
Feb 07, 2010 | Tomtom GO 730T Car GPS Receiver
730 camcorder
well it sounds like the battery is dead. try charging it fully...if it doesn't work, then try getting a new battery for it, and if that doesn't work, try taking it in to a camera repair shop.
Apr 16, 2008 | Hitachi DZ-MV730A DVD Camcorder
Olympus Stylus 730 Digital - Won't work 60 days old
I'm having the exact same problem. I was in the middle of zooming on a shot and it froze, so I turned the camera off and on, and now I get the 5-chimes+Zoom Error screen. This is nuts, I've only had the thing for six months, and it was $250 (got the Stylus 730). I *think* I got a replacement plan so that's good. But still... I hope circuit city lets me get a different brand b/c I'm not happy with this now. The only problem I had before was the HORRID shutter delay. I want a model that doesn't have that problem .
Sep 08, 2007 | Olympus Stylus 730 Digital Camera
Cameras Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
