Question about KEF Audio PSW 3000 Subwoofer
My kef psw3000 doesn't work. The system powers up however absolutely no bass/sound is delivered when connected to an amp. I have checked the cable and amp through another sub and there aren't any problems there. Do you have any suggestions on how to fix ?
2 Suggested Answers
SOURCE: my kef psw 2150 sub
is probably faulty capacitors
you should check out this link: http://lug.demon.co.uk/kefrepair/?cat=1
Posted on Dec 05, 2010
Hi i have a problem w spaker kef Q700 so has stoped working tweeters in pair spakers ,bass working , and I don't know what happen ;-(
Check the cabling. Check the connections. Check the audio source.
Check the extended warranty you added when you bought those $1500.00 speakers.
May 05, 2014 | Audio Players & Recorders
How do you connect the back cables so the sound will come out right
There are four posts - two black and two red. They should be connected together, as shown in the picture. If you are missing the brass straps, simply use wire to reconnect the posts, black-black and red-red.
Then it's a simple matter of connecting the red (+) amplifier output to one of the red terminals, and the black (-) amplifier terminal to the black terminal on the KEF.
The KEF terminals can be seperated if you wish to "biamp" or "biwire" these speakers. Each black/red pair is dedicated to either the bass or the treble. For higher fidelity, some listeners prefer to run seperate wires from a single amplifier channel to each individual speaker input.clmrt5000_5.jpg
Jan 19, 2011 | KEF Audio Q75 Speaker
Do LF and HF +/_ both be connected and if yes do they both go to speaker system A or separate to A and B on the amplifier.
From the factory, those are equipped with "jumpers", one for red-red and one for black-black. This allows for one speaker cable to power one speaker.
The jumpers can be removed, allowing for "bi-wiring", where you run two leads from a single amp channel to both inputs on each speaker. There's also "bi-amping", using a treble amp and a bass amp dedicated to each input.
If the jumpers are missing, you can use a short piece of stripped speaker wire to reconnect the upper and lower binding posts, just be sure to match colors.clmrt5000_0.jpg
Jan 10, 2011 | KEF Audio Q55 Speaker
OVERLOAD
First of all the KEF is a powered sub which means that it wants a line level signal NOT a speaker level. Send the signal from a tape output or pre-amp output to the sub input. The overload is because the impedence load for the speaker output is too low and looks like a short to the amp. Continued attempts to connect the system as described will result in damage to the output section of the amp.
Please let me know if you need more info.
Dan
Feb 03, 2010 | Technics SA-DX750 Receiver
HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
Nov 06, 2009 | KEF Audio PSW 3000 Subwoofer
Is there an incompatibility between Onkyo 606 and KEF Wireless?
This is cycle hum place offending units away from each other or, isolate the power supplies and, re- check electrical circuit grounds
Jun 01, 2009 | Onkyo TX-SR606 Receiver
Kef subwoofer kht 2005:2
check for the connection og the main wire is cut.. or check the supply..
Dec 07, 2008 | KEF Audio KHT 2005.2 System
How to test your speaker
Check sub buy pushing cone in gently if you hear or feel a rasping sound the sub is blown,if not check for a fuse where the power cable goes in as this may need replaced.Also make sure you have the sub plugged into the sub pre out and not the six channel input.
PS did switch on the sub in the speaker set up in the menu?
hope this helps.
CABLE GUY.
Jul 01, 2008 | B&W ASW1000 Speaker
Subwoofer not working
if u are a technician then its easy to check, problems are, blown fuse, power amp IC output transistor may be blown, check for burnt componenets. changing and blowing a fuse means ur output IC or transistors are shorted.
May 15, 2007 | KEF Audio KHT 2005.2 System
KEF Audio PSW 3000 Subwoofer Logo
166 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
shaqsatin
Level 1 Expert
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
