Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
Need to replace the main belt on my Bissel 1698-P. Can't figure out how to get the belt around the brush roller. Have the top off. Cleaned the water tubes, didn't let the water come down.
  • 2,272 Answers
Remove belt access door at left front of unit. Unplug the unit. Remove the two solution tanks.Remove spray tips from guides.Remove the brush and cog belt by removing the screw from the orange retaining collar. Remove belt from pulley.
To get the step by step part disassembly service manual for your bissell 1698 vacuum,please click on the link below:--
http://newzealand.bissell.com/images/includecontent/service_center_help/upright_deep_cleaner_repair_guide.pdf
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 31, 2010
Bissel easy vac roller won't work
remove brush roll and clean any string, hair, or whatever from it. especially around the ends. you can also unscrew the ends and check for debris there also. when you put ends back on use a little wd40 to lube up the bearings. if that doesn't work replace brush and won't hurt to change belt
Feb 13, 2013 | Bissell Roller Brush 2037029 for Easy Vac...
7901-1 need to remove brush and replace small belt
Follow the manual instructions! You just pop a little tab on top of the vac above the wheel. It says someting about belt replacement.
Just be VERY careful...I made it harder than it was (not checking the manual) and pulled the roller off, breaking the plastic roller arm clamps. NO ONE carries them & they have to be ordered off the web. They are less than $3 but it will cost double that for shipping!!!!
Apr 11, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Changing the belt
It is quite easy. Just take off the bottom of the vacuum encasing the roller brush. It should snap off or you may have to unscrew some screws and lift the cover off. Then remove the roller and clean it while you have it out. Now put the new belt on the motor shaft or pulley and slip the brush into the belt. Then replace the roller brush pulling the belt tight. Replace the cover and clean house.
Apr 03, 2009 | Bissell Upright Vacuum - The Pet Hair...
Burning smell when vacuuming, not belt
Try turning the vacuum on and hold the base up so you can see if the roller is turning. Odds are it is not and what you smell is the belt burning (not literally). If the roller is not turning, look for anything that is binding it - after you have unplugged the power cord. Probably the roller head is not fully aligned with the retention lugs that hold it in place or the belt is not properly placed on the roller itself, or if it is a used model, hair and twine can get tangled in the roller and cause it to stop turning.
Dec 26, 2008 | Bissell 5770 Healthy Home Bagless Upright...
Bissel Healthy Home vac brush/roller is jammed, cannot be rotated
You'll need to take the bottom plate off, remove the roller, remove the belt, and pull out whatever may be clogging the rollers on the side of the brush/roller.
Can you give us a model name for your vacuum? I can give you more details on how to remove the roller.
Usually a pair of needle nose pliers can help with this.
It happens when hair, carpet fibers, and other fun things get tied up and tangled around the sides.
Best Wishes
Nov 03, 2008 | Bissell Vacuums
Putting on a belt on a vacuum
Greetings from GoVacuum.com,
Replacing a Belt on an Upright vacuum can vary from model to model, but it is basically going to be the same for most upright models.
First you will need to access the belt. Most upright vacuums this is done by turning the machine upside down, and most you'll need to remove the bottom plate by unscrewing (usually 4) screws that hold the plate on. You should see screws that are closest to the actual roller brush, simply remove these screws, and take the bottom plate off. If the machine is a Eureka, or Kenmore, the top agitator housing will be removed from the top of the vacuum, not the bottom.
Once you have removed the bottom plate, or top agitator housing, you should be able to see the belt (or broken belt) along with the roller brush. Remove the broken belt. Make sure that you purchase the correct belt by taking the make, and the model number (located on the back or bottom of the machine). Please note that a broken belt may be 4-5 inches longer then a new belt, as they stretch a lot before they finally break.
Once you have the new belt, you will need to remove the roller brush. Pay attention to how the roller brush fits into the agitator housing, usually there will be fittings on the end of the roller that have to be put in a specific place, or in a certain way to work right. After the roller brush is taken out of the machine, you will need to wrap one end of the belt around a metal pulley on the opposite side of the roller brush. Most pulleys are located where the main housing (handle part) of the vacuum meet the the agitator (floor part) part of the machine. Anyways, wrap one end of the belt around the pulley, and then put the roller brush through the other end of the belt. This is where you'll need to put some elbow grease into it. You'll need to stretch the roller brush and belt so that the brush and belt are stretched back to the place where you took the roller brush out of the vacuum.
Once you have replaced the roller brush with a new belt around it, pull the belt a few times to make sure that the brush spins while you are pulling it, to ensure that the belt is not pinched, and is spinning freely.
I hope this helps. Here's a video showing how to replace the belt on a Hoover Windtunnel Self Propelled model; Feel free to email me if you'd like to send me the model number of your vacuum, this way I can be a little more specific, and give you part numbers. I have all belts for all vacuums in stock. Email; chris.jones@govacuum.com. 1-866-468-2288. You may also chat with me by going to our website, www.govacuum.com, and clicking in the top right part of the page. Thanks!
Oct 11, 2008 | Vacuums
I have a bissel carpet cleaner and the brush does not rotate when machine is on.
The brush roll is driven by a cogged belt, the brush roll will also have these cogs. If they look all right, then check the end of the pump, it has a dual pulley on it, one for the flat pump belt, and the other for a cogged belt. If the cogs are wore away or that part of the pulley broke off, then you will have to replace the pump. That pulley only comes with a pump.
Mar 18, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Belt removal Bissel PowerSteam ProHeat
First take off the cover on the left side oif the top cover, then turn it over, remove the screw holding the red lock and pull the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together.
Jan 18, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell proheat 1698 cleaner not spraying water
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Feb 25, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1698 Powersteamer no spray
If it seems like the tank does not fit in securely, the round gasket that goes around the valve at the bottom of the tank may have come off and actually be in the hole in the bottom of the vacuum base. It looks like it belongs there but you can pull it out with some needle nosed pliers. After you remove it, put it around the valve on the bottom of the tank, then it will fit into the hole again and everything should seal correctly. Mine was not spraying and would not suction well. figured this out and now it works great again.
Apr 16, 2006 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
41 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
