Question about Yamaha HTR-5890 Receiver
No Power The unit has worked fine for 6mths then just would'nt power up. I have voltage coming in and the two fuses are good. I dont hear any stanby click and no lights indicating voltage. Are there any fuses other than the two near the power cord or any thing else that I can try?
  • Anonymous Dec 20, 2008
    I have the exact same problem with my receiever. I bought it 4 months ago and haven't used it for about a month. It worked fine a month ago when I used it last and for the previous 3 months. When I hit the power button it clicks but nothing happens. None of the fuses are blown that I could see. Any thoughts?
    Novelist:
    Champion:
  • 236 Answers
In your power board near the back of transformer you have a backup power source of 5volts. that is for the cpu and the power relay swicth. can you check if you have that 5volts present. What i can see only in your unit is a major brekadown of your main amp section, all power transistros must be busted/shorted, and no chance even for a click on the relay. that is also feature of the protection. you wont be able to get the unit started even for a while. the fuses for yamaha do not normally blow and very often only your protection circuits enables. but in your case it is a very bad output stage now that you dont even get the display on to see the trouble in the built in diagnosis.
Posted on May 14, 2008
MY RADIO AND CD PLAYER IS NOT WORKING NO SOUND IS NT COMING OUT
Is power reaching the unit? If not is the fuse any good? Is power reaching the fuse? If power is reaching the unit (lights up) and it still does not work then something is seriously wrong with it and replacement may be in order..
Sep 12, 2017 | Car Audio & Video
Can't get my working lights to come on
If you have power to the fuse box, measure with a multimeter to see how much you have from the battery, then to the fuse box... Then see how much leaving the fuse box, if there isn't any power leaving the fuse box,,, you have a faulty fuse box or a possible bad connection (ground) if you have power check the relays, often you relays go bad, you'll hear them flicker but the don't actual make the connection to give voltage to the lights... Also you can test the voltage at the light bulb socket with the power on and switch on with a multimeter..
Nov 16, 2013 | John Deere 420,1020,2010,2020,2510,2520...
2000 MONTE CARLO BLINKERS DO NT WORK,AC/AND HEAT DO NT WORK,AND RADIO IS SAYING LOCKED UP
Does the vehicle start?
If not, then check battery voltage. If below 12.5 volts, then recharge the battery and retest system charging voltage (should be around 14 volts)
If battery is fine and vehicle starts, then check fuse box and wiring loom connectors.
Nov 13, 2012 | Chevrolet Cars & Trucks
Intertherm Air Conditioner S3BA-042KA compressor and fan not working (has power)
It sounds like that unit is connected to a "power saving load controller" device from the power company. The power company can turn your unit on & off with a radio signal. If you manually activated contactor and unit ran. I would bet that the power company's device or the wiring connecting it is where the problem lies. Call the power company and have them check their device. If they tell you that the device has been tested remotely and is working fine. Explain to them that you can activate your unit manually and it works fine. They should not charge you to come out. Those "load controller devices" have a pretty good longevity record.
Jul 11, 2012 | Intertherm Heating & Cooling
A friend gove me her lg plasma and ive plugged everything in and it hasnt even got a stand by light it has no remote
When no standby light the unit has a problem in the power supply circuit, you may need to first check the line fusee on the power supply to make sure its not blown. If the fuse is good then you may need to futher troubleshoot the power supply. All televisions have standby lights you just may not be visible because of a falty 5 volt stanby voltage..
Aug 03, 2011 | Televison & Video
Fuel pump was intermittent now just dont hear it come on anymore.
are they good in the way that your getting power with a test light or volt meter?? if you are getting 12 volts with the ignition on or if you can actually hear the fuel pump relay clicking then its probably the pump itself or the wiring from the relay back to the pump. see if you can get at the wiring at the gas tank and try for voltage there with the ignition on if you get voltage then you have pump problems for sure
Apr 25, 2009 | 2003 Kia Spectra
Power will not come on, but fuse is good
i dont know about a code but i would check my 5 volt standby power supply voltage ,and depending on tv check all standby voltages with set pluged in only .if stand by voltages is good check for horiz drive at base of driver trans when you press the power button
Apr 16, 2009 | Televison & Video
I have no power in the rear audi0 sreen and ajustments
no i havnt found the problem yet but my brother who repairs electronics will be back from australia in the nex few days ill run it past him thanks steve
Jan 03, 2009 | Pioneer DEH-P9600MP CD Player
No Power
Hello jasper100, Have you opened the unit to take a look inside? Since you dont have a blown fuse we cans assue the a short has not occured. Now I would chect to see if the voltage regulator in the amp has voltage coming from it. It may not in that case you may have to remover the old regulator and put in a new one just to get to the point of properly troubleshooting this amp. I would suggest that you get a schematic for this unit and use a multimeter to look at the voltages in the power supply section and see which sections have no rail voltage (12v supply voltage). I would also advise checking the remote to for regulator failure.
Sep 10, 2007 | Legacy Audio Blue Diamond LA580 Car Audio...
Face plate wont move
First check the power fuse as well as the stanby or always on fuse. then if that does not work Try to disconnect the power and standby line and let the unit reset . This should be done for at least an hour or so.. Good Luck
Jul 25, 2006 | Kenwood KDC-7009
Yamaha HTR-5890 Receiver Logo
470 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
