Question about Maytag Refrigerators
Freezer is cold but refrigerator has warmed up to 60.
  • 4,070 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Posted on Aug 31, 2010
LG french door refrigerator with bottom freezer. Freezer is cold but the refrigerator is warm
Refrigerator Freezer is Cold But Refrigerator is Warm ...
www.repairclinic.com/...Refrigerator/...---/Refrigerator-freezer-is-cold-b...
Refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
LG Refrigerator Freezer is Cold But Refrigerator is Warm ...
www.repairclinic.com/...Refrigerator/...-/LG-Refrigerator-freezer-is-cold-...
LG refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
4 Reasons Why Your Freezer is Cold but Fridge is Warm ...
www.bestfridgereview.com/freezer-is-cold-but-fridge-is-warm
Jul 25, 2014 - Your freezer is cold but refrigerator is warm? This can be a very big problem. Check Out the top 4 most common problems and their solutions ...
Why is my refrigerator not cooling? - Refrigerator - iFixit
Jan 04, 2016 | LG LFC20770ST
My refrigerator isn't cooling well. The freezer isn't freezing at the top only the bottom.
if it's just cold at the bottom and warm up top it sounds like you have a bad evaporator fan motor in the freezer side,when you open the freezer door do you hear the fan blowing?if not bad fan motor,this happens when the fan motor is bad because heat rises and cold air sinks.part number : 2259385 and it's around 60 to 70 dollars
Nov 19, 2013 | KitchenAid Superba Architect KSCS25INSS...
CSX22GRZAWW freezer works, refrigerator warm
Damper problem.
This ice box has a damper which is controlled by a thermostat. When the fresh side be warm that damper opens and allows cold air to enter the fresh food section. It must be gone out. it is what i would check.
Jun 12, 2012 | Hotpoint HSS25GFP Side by Side...
Frezzer warm 60 degrades and refrigerator warm 60 degreades refrigerator sounds is working fans working what could be the ploblem
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 04, 2010 | GE GSS25LGM Side by Side Refrigerator
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
REFRIGERATOR WARM ABOVE 60 FREEZER 0
Try moving the air flow setting in the refrigerator up higher. I know my beer wasn't that cold before and moved the setting from 2 -6 and that made all the difference
Jan 02, 2009 | Refrigerators
Freezer not staying cold
the temp control thinks its cold enough to stay off so you need to have the temp in home warmer so it will cycle / atleast 60 / larry
Dec 12, 2008 | Frigidaire FRT21H8 Top Freezer...
Freezer not working properly, refrigerator okay
thatts exactly right , the "thermostat that runs the compressor, in the refrig compartment never gets to warm to cycle the unit on/off. come spring itll work like a champ again,, ambien t temp cant be below 60 deg F
Dec 06, 2008 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
87 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
