Question about Gateway 40G / 40GB for laptops / notebooks. (410000218372) Hard Drive
Hard drive/memory/speed if i have files such as itunes on an external hard drive hooked up through a UBS port and also on my computers hard drive. my computer is getting old and starting to run slower than i would like- i am trying to speed up my computer and preserve it's life before having to shell out the bucks for a new one. my question is- can i now take files completely off my computers hard drive without losing them since they are now on the external hard drive? thanks
    Guru:
  • 722 Answers
Music files and photo files take up a lot of memory/space on a hard drive. If you are using your flash dirve (external drive) to upload songs, phots etc to a website (i.e. Facebook;MySpace etc.) you can upload them directly from the external drive rather than loading them to your computer. I suggest, that if you have a cd/dvd burner, burn all music and photo files to dic, if your external drive is for temporary storage. Once you have done this, remove all music and photo files (except any you may want to use as start up theme music, background use for desktop etc.) then, degragment your hard drive, C:\. Once the degragmentation is complete, close all programs and reboot your computer. NOTE: while you can operate the computer while a defragmentatioin is in progress, any use slows this process, as degragmentations (or defrag's) can take some time to complete (i.e. 1 hour or more depending on the status of the computer and it's need for being defragmented) You can run an analasys to determine if it need to be defraged. This can be done under the Start Menu,All Programs, Accessories, System Tools,Disc Defragmenter: When Disc Defragmenter Opens, it will give you a list of the internal (hard drives,including the D:/ Partitioned Drive) Select C:\ and click on Analyze. This should only take a few minutes to complete. Once the Analysis is complete, it will tell you directly whether or not the computer (Drive C:\) needs to be defragged. In the event it does not, You can also run a Disc Cleanup: Go to Start Menu, All Programs, Accessories, System Tools, Disc Cleanup. Be careful doing this as you do not want to remove any programs that you use on a regular basis, or frequently, that the computer automatically may deem "seldom used". Here, you can remove, or uninstall programs and files that you or the computer do not need, and free up space. Freeing up memory or space will improve speed a little bit. Depending on the OS (operating system) and it's current grade (upgraded or not) - you may need to have more memory and RAM installed.
Posted on Mar 31, 2009
How do I backup itunes file on external harddrive
It's a good idea to regularly back up all important files on your computer to an external source to prevent data loss. Your iTunes music, videos and other digital downloads are stored in separate files within the iTunes folder. However, if you consolidate them into a single folder, it's easier to back them up to an external hard drive.
Launch iTunes. Go to the program's Preferences menu. Click the "Advanced" tab. Check the box next to "Copy files to iTunes Media folder when adding to library" and click "OK." Click "File." Select "Library" and then "Organize Library." Check the box next to "Consolidate Files" and click "OK." Close iTunes. Connect your external hard drive to your computer. Find the iTunes media folder on your computer's hard drive. Drag the folder to the icon for your external drive to copy your iTunes media.
Back up your iTunes library by copying to an external hard drive http://support.apple.com/kb/HT1751
Mar 19, 2013 | Computers & Internet
Can external hard drives be "piggy backed"? I have
Each external device connects to one USB port on your computer.
So, you'll have no problems running two devices at the same time, in different USB ports.
Dec 13, 2010 | Seagate FreeAgent Pro 1TB External USB...
Can't retreive files
if the computer reads the hard drive and data but does not transfer it it may be a space issue otherwise if its reading nothing it may be a connection issue cause by lose wires or a faulty port ensure you have the drivers for the external installed and windows updated
Apr 01, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Question about transferring files from computer hard drive.
Is your other drive an external or an internal drive??? If external then attach it to the USB port and see it as an additional drive in My Computer. Then you can use it as any other drive.
If an internal drive then you will have to purchase an adapter that can take this drive and get connected to the PC/laptop to through the USB port. Again visible on My Computer as additional drive and can be used such.
Dec 17, 2009 | Averatec 6100 Notebook
I can not find or download driver after I deleted things fron computer now I am unable to access the portable hard drive
This external drive dont need any driver it should be a plug and play device, what you can try here first is to connect the drive on different UBS port and then check if it will be detected by your computer if still NO , try connecting a different usb device so we cna check if this is a problem with your USB port...........
Oct 27, 2009 | Western Digital Elements powered by WD 320...
My computer is out of memory. How do u transfer iTunes to an external hard drive?
Select File/Library/Export Library... from the drop-down menu.
Jun 03, 2009 | Apple iTunes
I download songs into my Itunes but the C: drive still decreases
The external hard drive will have a different drive letter than the default hard disk (C:). So in iTunes, you need to configure a different location to store your songs.
Just open My Computer and you should see the new drive letter.
Alternatively, you can move other files from the C: drive to the new external drive.
For further troubleshooting see here:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Apr 19, 2009 | Computers & Internet
SimpleTech Portable Hard Drive
You can either do copy/cut + paste or just simply drag and drop the files/folders that you want to move.
Apr 08, 2008 | Computers & Internet
Computers & Internet Logo
111 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
