Question about Tools & Hardware - Others
I am feeding the wood but the rollers seem to be lower than the blade consequently the front roller is getting in the way and not allowing the wood to be in contact with the spinning blades.
  • 90 Answers
Go to the back of the planer and remove the cover. loosen the bolts holding the blade and let it out a fraction. it should have springs to push it out a little. make sure both blades are out the same abount. it is not hard to do and will be quick.
Posted on Sep 01, 2010
Dewalt 735 planer trips overload a lot. New blades, thin cut no difference. Run it, without wood, it trips. Overload switch? Checked everthing. Turns free with chains off. Bluespook
id check the feed roller drive or feed rollers them selfs I find due to pressure there under most times they get flat spots in them from sitting makes for a hard start to planer
its best to back off tension rollers when storing these and keep them bearings lubed up well
and yes it happens to sealed bearings too
Apr 28, 2015 | Garden
Feed extremly hard to push board thru
my be you planning to much wood at once or the cutter is dull
Mar 15, 2014 | Dewalt Planer (DW734)
The self-feed slips on my Dw 734 Planer.
I have had the same problem with my planer since it was new. I hate this planer. The way I fixed it was to pull the feed rollers off and put one washer in the hole the pressure springs are on the rollers. I also put about a 1/32 washer under the hold down plate for the roller. It allows the rollers to put more pressure on the wood. Now it works perfect. If it sounds complicated, it will all come together when you take it apart. You take the bottom off to do all this. Trust me it works and is worth the trouble to do it.
Oct 25, 2011 | Dewalt Planer (DW734)
Ryobi AP1301 planer. Suddenly started getting ripples in wood.parallel to blades. Tried reversing blades to unused side, made no difference.Only trying to take of about 1/16". Stock is...
CHECK THE ROLLERS THAT PULL THE WOOD THRU, I HAD TO REPLACE MINE FOR THE SAME REASON.
IF THEY HAVE A LOT OF USE YOU WILL SEE WORN FLAT SPOTS ON THE ROLLERS CAUSING THIS PROBLEM
Jan 16, 2011 | Ryobi Thickness Planer Blades
When i click print the paper feeds fromright side and jams.
if your paper feed not straight, most probably the feed roller.. the roller which feed the paper is broken.. the normal broken area is the tip holding the roller, it can be repaired if you know how to open the printer and remove the roller.. you can always drill a small hole and insert a small round wood piece..
to be sure, try feeling the roller with your hand first.. if there is much free space between the roller and lower part.. then most probably it's broken..
May 23, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Thickness Planer (DW733) leaves fine scratches on wood surface.
It sounds like your blade holder assy has become misaligned on the blade drive shaft. Try if you can to use a straight edge on 2 planes 90 deg apart and see if there are any gaps in either of the srtaight edges. I suspect that the blade drive holder has become slightly dislodged from the drive collar on one end allowing the blade drive to tilt on the drive shaft. I had the same thing happen on another brand named Planer and it was a matter of reseating the collar to cure the stripes. Sure took a long time to sort out. Good Luck.
Feb 06, 2010 | Dewalt DW735R Reconditioned Heavy Duty 13"...
Cutting straight
The tension on the blade. the position of the guide rollers, and the condition of the blade are all important to get a straight cut. You might want to try lowering the guide rollers down close to the wood being cut. good luck.
Apr 26, 2009 | Ryobi 9 in. Benchtop Band Saw
Feeding speed is erratic
Researching Your Model. The Rollers are Chain Driven, but this Planer is a V-Belt Drive. Any slippage of Your Belt? Are the Chains Loose?? (there's a Drive Chain on one Side, and a Driven Chain on the Other Ends of the Feed Rollers) Never Hurts to apply a "Light" Coat of Chain Lube to these Parts(Gears & Chains)
DO NOT SAND THE ROLLERS!! Cleaning them with Denatured Alcohol is OK ( I prefer Brake Parts Spray Cleaner Myself)...the Planer Knife Head & the Front & Rear Rollers all work together as a Unit.
What Thickness are You Trying to Remove?? Usually I don't like removing More than 1/32" per pass...
Have you contacted DeWalt Service?
Jan 08, 2009 | Dewalt DW744S 10" Portable Table Saw with...
Planer is not feeding wood through without manual force
I had the same problem...sometimes you have to take the smallest amount off (1/64th) and it might work, otherwise your blades are probably dull. Try to feed the boards through the planer towards the sides, not just the center so they wear evenly across the length of the blades. They wear out very quickly, which makes this planer very frustrating. If you take the top cover off and inspect them, you'll probably see nicks in them and it's time to replace or rotate them. Each blade has two sides you can remove all the screws using the T-handle wrench from the top cover and flip them. Also, as the blades begin to wear, the planer will become louder and louder. That's another way to tell. When you install new blades notice how much quieter it is when you plane boards.
Nov 13, 2008 | Dewalt DW735R Reconditioned Heavy Duty 13"...
Tools & Hardware - Others Logo
90 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
