Question about LG Xenon GR500 Cell Phone
My external speaker will not work - LG Xenon GR500 Cell Phone
  • 677 Answers
Hi, what causes the phone not to be able to ring out is due to the ringer inside the phone that allows you to hear a ringing tone and can be used as external speaker too.it's bad.
You will need to replace the ringer inside the phone. When replaced phone will start ringing out and you can hear when it rings out.
have a nice day.
Posted on Aug 31, 2010
My phone only works on speaker, even when it have a volume level of seven, it won't work on a regular phone call. Also any icons that use to beep no longer have any sound
Notifications sounds from either external speaker or headphones, but never from the ear piece volume. Your question suggest that the external speaker is damage but it only works on external speaker. Try using a headphone or a bluetooth to make calls, if they work, then you need to fix the external speaker.
Jun 26, 2017 | Computers & Internet
HOW a 36A41 model's External Speakers Work ?? ...
Your speakers may be plugged into outputs intended for connection to an external amplifier.
May 04, 2014 | Toshiba 36A41 36" TV
External speakers won't work on HP T5570e Thin Client
Try to use earphones, plug them in to phone audio connector....
try if it works..... if so, disconnect them and plug speakers.... and try again.... if doesn't work, go to audio advanced setup and check if speakers are not muted, or set up voicevolume level is too low. Play with that setup....
Also some computers can turn on or off speakers in Bios.
If problem will not be solved, try to use USB speakers
Jan 13, 2014 | HP T5740 Thin Client Desktop PC
External speakers don't work
If the set has a connection for external speakers they have be the same impedance (ohms) and the set will likely have to be switched from internal to external.
Dec 10, 2012 | Televison & Video
No sounds comes out in headset but external volume is ok
Try to use external speaker. connect it where you usually connect your head and check if it work . If ever the external speaker will work it only means that the problem is your headset ( defective )If in case the external speaker will not work it means the problem is the terminal ( the port where the headset or external speaker connection )
Apr 01, 2012 | Computers & Internet
Having problems getting sound from internal speakers after having used external ones, any suggestions?
Hi, I understand that external speakers are working but internal speakers are not working on your laptop.
This could be due to the socket you are using to connect external speaker. if the socket's inside contacts looses the contact it cannot internal speakers.
Thanks,
Shiva
Dec 18, 2010 | Apple MacBook Mac Notebook
My speakers don't work, I can plug in head phones or external speakers and they do work. it started after my son repeatedly pluged and unpluged the external speakers
There is a microswitch in the speaker jack of the system. It disables the on-board speakers when external speakers are connected. If sounds like that switch is stuck and the on-board speakers are staying disabled when the jack is removed.
Jan 30, 2010 | Dell Inspiron E1505 Notebook
IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Dec 22, 2009 | IBM ThinkPad T23 2647 Notebook
Speaker Problem
Nothing is wrong. Most computers automatically turn off the internal seakers after the external seakers are connected. Go to cntrol pannel and see what you can do under audio options or some such equivelent. Check back with more problems,
hope this helped/helps.
Mar 10, 2008 | Audio Players & Recorders
Computer speakers work but external speakers do not
Schuttie
hello there!
First Things First:
1) Check if your external Speakers are connected on the external sound card output connector **
2) Check on control panel and multimedia if your sound card (external) is enable, and not MUTED sound. Rise the volume.
3) check cables from Speakers and see if not old or broke.
Good Luck
Feb 09, 2008 | Audio Players & Recorders
LG Xenon GR500 Cell Phone Logo
245 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
