TAPE detection I ran Boot Log Analyzer and found that "Enumerating Tape Detection (Tape controller\Tape Dectection\0000)" is taking 227 seconds. Does anyone know how I can disable this detection? I do not have a tape system.
    Problem Solver:
  • 35 Answers
Tape detection is probably a result of having installed MSBackup. When you installed MSBackup it installs three virtual device drivers one or more of which is causing you your start-up problems. I would suggest removing or renaming the following files to stop tape detection at startup.
drvwq117.vxd
drvwppqt.vxd
drvwcdb.vxd
You might also want to remove/rename:
pnpwfdc.inf
pnpwide.inf
pnpwtape.inf
pnpwppt.inf
Boot Log Analyzer should tell you which of the above vxds is causing you your problems; I seem to recall that the usual culprit is drvwq117.vxd.
Posted on May 09, 2008
Robotic hardware error and I/O station status shows open
A physical obstruction in the path of the robot's motion. Examples
include tape cartridges that are extending from the picker assembly or
from a storage location, as well as tape cartridges or debris that may
have collected on the floor of the library.
2. A large number of electrical hardware failures. Firmware or hardware
detects that motion control is not occurring properly (encoder issues,
motor driving circuits, motor winding issues, etc.)
3. A relatively small number of mechanical hardware failures that do not
result in the detection of a complete obstruction, but where motion
control generates robotics firmware error codes (contamination or damage
to encoder wheel, high friction, etc.).
Possible FRUs is Robot Assembly
Sep 01, 2013 | IBM System Storage TS3200 Tape Library...
Tip
CANON iR2016/2020 ERROR CODES
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
on Aug 03, 2010 | Office Equipment & Supplies
Hello, I have found a Sansui DA-T550 music-system with AM/FM stereo tuner, integrated amplifier, cassette deck and turnable/gramophone (placed separated). It seems like the system is working OK. My...
Hi!
I have the same deck. Did it come with rammophone or are you using your own grammophone?
I have it with original grammophone and I don't need a remote control, I don't even have it. You just turn on your grammophone and it is automatic, just place the needle on record and it should switch and play automatically. That is if you have connected the wires right (two wires for sound, one for automation, all in the same area).
If you have separate grammophone, I am assuming you just need to place two wires into the separate phono channels and it should work. There is just no automatic detection, so you have to swithc to mono manually: There is a button on the right, beside Volume control "tape to CD" or something.
To play the tape, just simply push the play button on the bottom, should work, or you could try tape to cd button off and see if it detects automatically when tape is inserted.
Currently I have it taken apart and there is tape detection system apparent. Its quite automated reciever, which sucks, because all kinds of problems appear and it is difficult to fix.
On my Sansui, the tape player starts winding slowly when pressed play button. And the tape motor seems to be on always, even when the tape is not used, and the motor is really loud. --Need to find a solution to this problem. And I hate it switch to radio/FM every time the record stops. Plus the original grammophone doesn't work correctly, it is supposed to take off the needle when record reaches an end, but it just pushes the neelde to the holder... over the record..... "screeeeech".
Nov 15, 2010 | Audio Players & Recorders
Where can i get the codes canon ir 2016 series.
Hi, here you go:
E540
E542
E744
0002
0003
0004
Jul 16, 2010 | Canon Office Equipment & Supplies
I want to find out what a report suspended error 0008 is and how i can get rid of it. Canon photocopier 2018i
ARE YOU SURE THAT IS E008?
hERE ARE THE ERROR CODES FOR 2018
E196 0001 Error on writing and readout ROM of image processor PCB (main ROM).
0002 Error on writing and readout ROM of image processor PCB (option ROM).
E261 0000 Zero-cross signal error
E540
E542
E730 0000 Inside error of the image processor PCB (PDL system error)
E744
0002
0003
0004
Sep 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
560X Camcorder Handycam won't record or play
This behaviour is relaterd to tape reading / tape detection. You may have a dirty or worn-out head on the video heads drum.
You may try to use a cleaning tape in order to retrieve normal perfoming of your camcorder, BUT you should take care, as cleaning tapes are also abrasive tapes, and the amount of cleaning cycles a video head can support is limited.
Then it should be possible that after cleaning the result is nul or worse (I had this lately on an old Sony Camcorder, it was recording with much losses in the film, after using the cleaning tape it doesn't record any more).
All that means you may repair your camcorder with the cleaning tape, but you may finish it too, if the video heads are too old.
In any case take time to read the cleaning tape user manual, cleaning time is very short (10 seconds generally) and must'nt be overtaken.
Hope you would have the good result !
Jun 17, 2009 | Sony Handycam DCR-TRV130 Digital Camcorder
Download standby error
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание E000 0000 Fixing temperature abnormal rise E001 0000 Fixing unit temperature rise detection (by main thermistor) 0001 Fixing unit temperature rise detection (by sub thermistor) E002 0000 Fixing unit temperature insufficient rise E003 0000 Low fixing temperature detection after standby (by main thermistor) 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 Fixing film rotation error E010 0000 Main motor rotation error E019 0001 Waste toner full detection 0002 Waster toner full detection sensor failure E052 0000 Duplex unit connection error E100 0000 BD cycle out of range E197 0000 Erroneous communication with printer engine E500 0001 Finisher communication error E520 0000 Offset error E531 0000 Stapling error E540 0001 Paper surface not detected (standard tray) 0002 Not moved within the specified time (standard tray) 0003 Sensor not reached within 3 seconds (standard tray) 0005 Encoder clock failure (standard tray) E542 0001 Paper surface not detected (optional tray) 0002 Not moved within the specified time (optional tray) 0003 Sensor not reached within 3 seconds (optional tray) 0005 Encoder clock failure (optional tray) E575 0000 Stack delivery error E584 0000 Shutter failure E716 0000 Erroneous communication with optional cassette E719 0000 Erroneous communication with card reader (serial communication) 0002 Erroneous communication with coin vender (serial communication) E733 0000 Erroneous communication between controller and printer E736 0000 CCU communication error E739 0000 Erroneous communication between controller and network board E744 0001 Language file/boot ROM/USB memory error 0002 0003 0004 E805 0000 Fan failure E808 0000 Fixing drive circuit failure
Apr 10, 2009 | Office Equipment & Supplies
Canon IR2018 E007
E007 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
you need to call a canon technician to sort it out
Mar 22, 2009 | Toshiba e-Studio162D Copier
System error E808
0002
0003
0004
Mar 22, 2009 | Canon CLC 1140 Copier
No tape icon problem
Hi insert tape mark digital the detection will on icon.
Jun 11, 2008 | Panasonic PV-GS80 Mini DV Digital...
Computers & Internet Logo
David Payne
David Payne
