Question about Frigidaire Refrigerators
The water in my frigidaire refrigerator come's out normal when you push the bar and then it slow's down but still flow's. What is the problem?
  • 1,531 Answers
There could be some restriction with the filter and or the water line itself.
there could also be some frozen water in the supply line.
Posted on Aug 31, 2010
Why is my water dispenser flowing slow
Good Afternoon Friend,
I understand that the water dispenser is dispensing water slowly, from your Frigidaire refrigerator. I suggest changing the water filter. If that does not work, check the lines going into your refrigerator, to make sure they are not kinked. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully.
-Best Regards-
WP
May 18, 2014 | Frigidaire Refrigerators
Www frigidaire com
make sure the fill lineis not blocked and it's turn on. some models have a bar and if its pushed all the way up, that is off, down is on
Apr 13, 2014 | Frigidaire Refrigerators
Water flow has decreased at the dispenser. Changed filter and when the system fills the flow is great then slows down again once the reservoir is full. How do I check the reservoir?
check the heater in the fridge compartment as it is on a timer to defrost the water line that goes through the rear compartment and allows the water to flow
Dec 27, 2011 | Frigidaire FRS26KF5C Side by Side...
Water flow of filter too slow
When was the last time you changed the water filter? If the filter is clogged from long usage it will slow down the water flow. Filters should be changed 6-12 months.
Jul 11, 2010 | LG LFX25971ST Bottom Freezer French Door...
Can't make ice cubes only crushed ice
This happened to me. If you pull the ice bin out you will see a metal bar that extends from the front to back on the bottom of the bin. Find the square hole in the back of the freezer. Stick you finger in and slide the white plastic square up or down.
The switch you are moving is the toggle from crush to cube.
Jun 02, 2009 | Frigidaire FRS3R5EMB Side by Side...
Slow water flow from GE Fridge water dispenser
slow water from my ge refrig side by side. less than a momth old
May 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Low flow from water dispenser
hi, this can be because of the filter. when the water is flowing threw the filter, it is sent threw many channels inside the filter before it reaches the dispenser. this slows it down a bit. this is quite normal but, if it's slowed down to a dribble, i suspect a water valve malfunction or you may need to change the filter.
Mar 15, 2009 | GE GSH25JFR Side by Side Refrigerator
Slow water coming out od water dispencer in door.
first off replac ethe water filter in the unit this will slow down the flow
Feb 15, 2009 | Amana ARSE66MB Side by Side Refrigerator
Not making ice
The filter does effect somewhat the flow of the water. For some people having problems with ice dispensing it may be as simple as lifting the metal shut off bar up and down. Then check the top of the ice tray to make sure no ice is stuck up there. When you move the metal bar up and down you should see the plastic dispenser that pushes the ice out turning or rotating. Hope this helps.
Dec 10, 2008 | Frigidaire FRS3R5EMB Side by Side...
Slow water flow
dadcanfix. There are two possibilities here. One could be the water valve itself, clogged or not seating or opening properly. The second would be the water tank on the refrigerator side, partially frozen. I believe they have a kit now with coiled tubing that replaces that tank because of the trouble they had with it. Remove the refer drawers and take a hair dryer and go over the tank lightly. See if that improves the water flow. Catriver..post back.
Mar 20, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
43 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
