Question about Sanyo Audio Players & Recorders
Sanyo Personal Audio System. Looks practically new. Sometimes it works and other times it keeps going through all the functions on the screen and can't get it to do any of them. After a lot of fooling around sometimes I can get the CD shelf to open but when I push the button to start playing it just does a ticking noise. Every once in awhile it will play. Part of my problem may be in memory. I don't have a user's manual so I really doin't know how to program the functions like Memory. Maybe I need to delete and start fresh. I don't know how, though, except for unplugging it and that doesn't seem to do it. Is there a manual available?
jsrock516
  • 5911 Answers
SOURCE: maytag dishwasher mdbh950awb
Sounds like you have a control panel and/or control board issue. Normally when operator functions fail or "halfway" work the main control board, associated keypad, or wiring are the likely suspect. Now...another remote possibility could be the door latch not closing properly. However, this would affect ALL functions. I hope this helps you.
Posted on Jul 31, 2007
SOURCE: Can't close door of CD on Sony CMT-CP1
Mine had the same fault. The CD is being rejected as it could not load up - this is probably because of the CD loading mechanism.
You'll need to unplug and remove the case - 4 screws on the sides and 4 or 5 on the back. Once this is done plug back in (be careful not to touch any live parts inside), load a CD and watch. What you'll probably see is that when the drawer closes the mechanism under the drawer doesn't lift sufficiently. Give it small push when it tries and I bet it then will and the CD will play.
What you need to do to fix this is remove the front panel/PCB and also remove the plastic cover that is screwed above the CD drawer so that you can see more of the topside of the mechanism.
Remove the front panel/PCB by releasing the 2 screws on the bottom and then easing forward. Gentle - as there are pins connecting the front PCB to the side PCB. You should then be able to see a worm drive type arrangement that lifts the lower assembly. This will need regreasing (I used vaseline) with a small stick (I used a Q-tip with the bud cut off). You will probably see where the old grease has been pushed out. Once you've done this, reassemble and operate a good few times to work the grease in.
Done! Mine works fine now after sitting there performing the annoying trick you described for many months!
Posted on Jan 08, 2009
  • 108 Answers
SOURCE: system lights up - stuck in demo mode - sometimes CD player plays
if detach face may not be making good contact try removing wipe connections w/rub alchol and put back on
Posted on Mar 26, 2009
SOURCE: Help - CD won't eject! I press 'Open' on my sony
I have the same problem and it's due to dirt!
I'm going to try using compressed air, but -
this definitely works:
:) Seriously:
tilt the cd player to a 45 degree angle (flat, basically - as if they tray were horizontal.)
I had my player for 10 or 12 years, and this problem is only coming up now. My house gets very dusty.
Also - vertical load disc players are hard to clean. X_X (inside the disc tray)
I love this stereo too!
I don't want to have to go out and buy another stereo!
Posted on May 04, 2010
  • 65 Answers
SOURCE: After pushing the CPU power
seems to be a power supply issue I would check www.newegg.com to find a power supply that would be a good replacement for your pc
Posted on Sep 23, 2010
I have a sanyo sound bar. Lost remote. Got new one. Need to know how to pair it.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Mar 11, 2016 | Sanyo Televison & Video
No power sanyo r227
I had the same problem. A defective capacitor is trying to charge near the audio chip .
My solution : I have remove the audio chip (the one with big heat sink) and I use the aux out output to my amplifier.
When plugging it takes some time to finally work : but once plug and working it stays on and work ok.
Jan 21, 2013 | Sanyo R227 WiFi FM Radio
We turned it off, went to bed, this morning nothing works. we replaced batteries. tried manually. nothing. Plugged into wall outlet, new house. It's a Sanyo, VIZON, HGTV 48" flat screen bought at...
My personal suggestion would be to go for these repair
catalogs. I know this website reliable-store that i used to buy them from, and they sold online it was very good manual. Go ahead, I bet.
Mar 05, 2018 | Sanyo AVM-2756 27" TV
Radio/nav system dead
I have 2010 Porsche Cayenne and Nav screen just goes black and turns back on - sometimes it does it few times a day sometimes its working fine ..any idea?
Jul 13, 2010 | 2006 Porsche Cayenne
The system will not play discs. It says "NO PLAY."
if the tray feed-mechanism is working smoothly, try a audio cd, if it play optics needs cleaning or replacement. If not- mechanism alignment.
Mar 03, 2010 | Sanyo 770 DVD Personal Home Theater System...
New lamp turns on flashes 7 times
Just a thought...you *might* have a bad ballast in addition to that defective power supply.That flashing could be the ballast trying to ignite the lamp. A lamp is just like an enclosed welder's arc. The ballast generates a high-voltage spark to initially start the lamp, then low voltage with high current keeps it burning. If you look into the lens and see "lightning" flashes but no lamp ignition, that's what's happening. The ballast could've been damaged by the defective supply. Also, try a known-good lamp...just to rule out a defective new one--in the shop, we kept all old working lamps as testers.
Aug 30, 2009 | Sony XL-2100U Projector Lamp for...
The vcr will sounds like its working but no image or sound on screen
Hello brother, It looks that is no problem in vcr mode I think you just need to play a head cleaning cassette. I hope it should solve your problem All the best to you Uday
Sep 02, 2006 | Sony Handycam DCR-TRV230 Digital Camcorder
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
138 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
