Question about HTC G1
Kuhn fc 302 g1how to remover gear wheels from bed of mower
The right rear wheel intermittently locks up on my lawnmower when going forward stopping forward movement temporarily, until I move it backwards to "unlock" it. Any ideas?
There is an excellent 3 part video that may help you to fix this problem. Please see the 2nd and 3rd videos:
https://youtu.be/Vk_tpjKlbjM
https://youtu.be/DdiewLxTQDc
Things you can try:
(1) Remove casing over rear wheel drive assembly and perform a test run to assure all parts are moving as expected
(2) Lubricate the shafts with lightweight motor oil where the shaft penetrates into the gear box of each wheel
(3) Remove each rear wheel, inspect gears for damage and free movement. Grease up each drive gear and the shaft.
(4) Inspect gears on each wheel for damage.
(5) If none of the above fixes the problem, try swapping out the front wheels to the rear wheels provided the front wheels can accommodate the gearing on the rear wheels
(6) If this doesn't work try replacing the small gear assembly on the right rear wheel
These steps are illustrated in the videos.
Good luck and hope this helps.
Oct 11, 2016 | John Deere JA65 Self Propelled Mower
Walker mower pulls to right
If this is a self propelling mower, check the inner wheel gear patterns for wear. Remove each wheel, only the ones that are self propelling. On the inside of each you will see the jagged pattern that rides on the mowers propelling gear, the plastic eventually wears out causing one to catch better than the other hence you will get pulling on either side.
Nov 20, 2015 | Garden
I need an operating manual for Kuhn GF 452T Tedder?
This may be of some use.
http://www.kramp.com/shop-fr/fr/130143/500897/0/Entra%C3%AEnement+ext+adaptable+sur+Kuhn+GF+452+%28nouveau+GF+5000+M%29
Otherwise try here.
http://www.ebay.ie/itm/KUHN-GF-452-GYROTEDDER-GF452-PARTS-MANUAL-/291111250895
Sep 17, 2014 | Computers & Internet
Remove self propel gears and axle from Troy bilt push
Most of the self propelled mowers have a pin in them. you need to use a pin punch and a hammer to knock it through. The gears will come off then. Post a picture if need more info.
Sep 02, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Have a toro lawnmower mdl #20012 front whell drive. When I engage the system it makes a grinding sound & when I take the weight of the wheels it runs smooth. Seems like a gear but not sure. Could it...
Some have gear in each wheel. Remove wheel see if plastic in wheel is worn out. Home Depot or Lowes carries some replacement wheels. Lawn mower repair shops sell them also.
Aug 22, 2012 | Toro Power Lawn Mower
I have a Honda HRR2165VXA mower that is having issues with the smart drive.
hello, hello, Drive belt replacement for front drive mowers. remove the belt coved on top of deckand clean out grass,turn mower on side where carb is facing up,use a pair of vice grips on side of mower deck so the blade can stop,remove the blade,remove the belt cover and clean out the grass,remove belt from rear and front pulley pulleys. install new belt,put belt cover and blade back on,put front belt cover on, should work,if that is not the problem; wheels will not prepeal the mower,wheels turn only when raised off ground, Check the gears or groves on the inside of the wheel for access wear that is a common problem,check the axle drive gears to make sure turns ok, to check gear box if ok pull mower back wards while drive is engaged,if wheels turn backwards than the trams is bad,all of this is caused by the operator,by not disengaging drive while pulling mower backwards or by holding mower back not allowing to propel self completely,hope this helps,any comments welcome,thank you.
Feb 15, 2012 | Garden
Need to dissassemble my sons gator to put in a new gear drive ---how do i get to the gear drive is threre a disassembly guide or diagram for this
remove the center caps of the rear wheels then use a 13mm wrench on each side and loosen the bolts for the rear wheels, when loose remove the wheels and axle, then remove the red pin on the fron of the bed, then the two black pins on the rear of the bed, then lift the bed off, then lift the green plastic panel off this will expose the motors then, disconnect the wires from the motor and remove the two screws that hold the gearbox in place then take the gearbox and motor assembly out then remove the two screws that hold the motor to the gear box
Mar 23, 2011 | Peg Perego John Deere Gator HPX Ride on...
I have a self-propelled Toro Personal Pace lawnmower, Model 20022. Both rear wheels engage and rotate when I lift the rear wheels off the ground, but when I put the mower back on the ground, the right...
Routine maintenance is required on the drive gears on these Toro mowers and Toro doesn't tell anybody. Put a block under the rear end to lift the wheel off the ground. Remove the wheel. You will see the drive gear. VERY IMPORTANT: take good notes, pictures, etc..when dissasembling. Remove the outer snap ring retainer from the axle shaft. Next should be a thin washer. Remove the washer. Pay very close attention to the gear, as it has to go back on in exactly the same direction. Remove the gear. There is a slot in the axle shaft. Rotate the axle to have this slot pointed up. In the slot is a small key (rectangular piece of metal), remove the key. Under this key is a spring. It, and the key, is stuck in the axle slot, therefore not allowing the gear to drive the wheel. Dig out the key and spring, clean them and the slot. Put a dab of axle grease in the slot and reassemble. In my shop, this is part of a mower tune-up, and is recommended every 50 running hours. That is usually every other year for the average home-owner.
DO NOT TIP your mower over to do this repair. Mowers are just like cars, they like all 4 wheels to stay on the ground. Tipping a mower over can/will cause fluids to go places they aren't supposed to go.
This is a relatively simple repair and can be done with basic mechanical knowledge and basic tools.
Do the other side too, it needs it.
Sep 11, 2010 | Garden
How do i sharpen cylinder mower blades
I believe you mean to say a 'reel' mower. Normally and old fashoined push (non-engine powered) mower.
Most consumer reel mowers do not need to be sharpened. They do however have a knife bed that occasionally needs to be adjusted. It should have the thickness of a regular piece of notebook paper between the blades and the knife bed. (that is really VERY close) You can buy 'lapping compound' from an automotive parts store, and apply that to the bed knife, and then rotate the blades to provide a precise fit for all blades.
Commercial reel mowers, such as those used on golf course equipment are however sharpened normally once or twice a year. It requireds dismantling, and many courses send their blades to a central location for golf equipment, where they are placed on a computer operated sharpener for precision grinding. This cost several hundreds of dollars just for the grinding.
Nov 12, 2009 | Garden
The front wheels on my lawn mower have locked
on yours you must replace the entire tranny unit - to make it roll you can remove the front wheels and remove the small gear on both sides - doing this of course will turn it into a push mower not self propel
Oct 01, 2008 | Garden
HTC G1 Logo
100 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
