Question about Bosch Water Heaters
My kitchen facet will not activate the hot water buner now and it takes two hot water facets in the bathroom to activate hot water. Is there a maintenance pronlem I need to do? Where are instructions how to fix it? Thanks
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
There is a minimum water flow required to operate your Bosch tank-less water heater. It is around .75 gallons a minute. There are three things you can do to help the flow.
1.Turning the temperature down will help increase the flow.
2. Installing higher flow aerators on your faucets.
3. Clean the Bosch tank less water heater.
You are not alone in having this issue. The most common problems are low flow faucet aerators and low flow shower heads.
Posted on Sep 01, 2010
Water heater
Most instant-on tankless water heaters require at least 10 psi of water pressure to start the heating process. The flow of water determines how hot the water will be, within the heating range. An electric 110 volts heater will increase the water temperature about 25 degrees F. A gas water heater will increase the water temperature about 45 degrees F.
Too much flow will not allow the water time to heat. Too little flow will not allow the heating system to work. Each heater must have the outflow water flow adjusted for the best heating outcomes. The best way to find the ideal flow is to turn the hot water facet on and adjust it (open or close) until the water reaches the balance of producing hot water.
Apr 25, 2016 | Water Water Heaters
Vaillant 209703 ABS....hot water without heating on
If you have hot water the heater must be heating. Perhaps the switch is bad or the gas on/off solenoid is malfunctioning. But, how do you know that there is hot water, is the water facet on? If so try turning off the water.
Mar 13, 2016 | Water Water Heaters
Water heats up then trips off red button
The lit red button may be an indicator that the water temperature inside the water heater flow channel has become too hot. If the outflow facet is adjusted to allow more water outflow (opened more) the water temperature should drop some and therefore with increased water flow, the temperature inside the water heater will also decrease. Or, if there is a manually adjustable outflow valve on the water heater, adjusting it to a more open position would also decrease the internal temperature.
Sep 17, 2015 | Water Water Heaters
How to change out copper piping from release valve
If the release valve referred to is the pressure release valve, then a water leak out the attached vent pipe is an indication that the valve is failing. To change the valve, the water must be allowed to cool (turn off AC power or gas) and the water level inside the tank must be lowered (drained) to below the level of the pressure relief valve. Once this is accomplished the vent pipe is unscrewed from the relief valve and the pressure relief valve is unscrewed from the water tank. A new pressure relief valve with a sealant on the threads, is then screwed and tightened into place with the outlet port facing downward. The vent pipe is attached to the new valve and the tank refilled with water. A hot water facet must be opened to allow air to exit while filling. Upon becoming full (water will begin to flow from facet), turn off the facet and restore AC power or gas, therefore allowing the water heater to heat up. When the first hot water is utilized there may be some air expelled from the facet.
Sep 13, 2015 | Water Water Heaters
Richmond water heater
The water inlet to the heater must be plugged.
May 16, 2017 | Water Heaters
Hi, I have a Atwood 91043 (Model 37C14U-5). The pilot and main burner seem to work fine (main burner ran a couple minutes then shut down) but I'm not getting hot water at the facet. I have the...
Have you checked back of water heater for proper valve positioning? (by-pass may be on)
Cold water enters through bottom fitting and hot comes out the top. Any valves in between should be closed and any valves going in bottom and out top should be open.
Jun 03, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Hot water tap only warm water in bathroom but hot in kitchen
Usually when you are having a problem at only one fixture, and not any others it is a sign that you have a faulty fixture. Hope this helps.
Jul 16, 2009 | Stiebel Eltron CK20E Electric Tankless...
Losing hot water in one facet only
There is something in the line or in the faucet.Are your pipes going to the faucet black iron or galvinze.Some of the pipe will rust up and stop a full flow of water.But I would check the faucet first to see if the screw is loose or somethng in it.
Mar 17, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
AquaStar 125B NG continues heating water when no demand
I found the manufactures website and read this specific tech bulletin. I will be replacing or repairing my water value soon.
http://www.boschhotwater.com/Portals/7/TechBulletins/TWH-G1-25_Water_valve_rebuild_B.pdf
The bulletin said the following:
If the burners fail to go off immediately when the
water is turned off, usually due to mineralization in
the water valve on older heaters. To test for this
possiblilty, run hot water at a faucet, then shut off
the cold inlet supply and observe if the burners go
off immediately. If they do not the Aquastar will
overheat and shut down on safety depending on
the delay.
Jan 11, 2009 | Bosch & Tankless LP Hot Water Heater
Water Heaters Logo
253 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
