Hp g60-438nr not powering up. I've tried it with and without power adapter and battery, and still nothing. Laptop is 14months old.
    Scholar:
  • 183 Answers
You need a functioning battery even when running with the mains adapter. If the battery is knackered, nothing will start up.
Posted on Aug 31, 2010
Pavillion zv5000 won't boot
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Nov 13, 2012 | HP Pavilion zv5000 Notebook
I have a HP laptop that won't power up. I put in a new battery, and bought a new AC adapter. Now lights nothing. It was running than just quick and I haven't been able to get it to come back o
Hi There,
If you've got a multimeter - test your AC adapter to see if it is outputting the correct voltage for your laptop. If it is, Then you've got an HP boat anchor. Unfortunately HP laptops are known for their overheating issues, and if this is the case, a lawsuit filed against said manufacturer means you may be able to be compensated for your loss.
Jul 18, 2012 | Computers & Internet
Battery is not charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 14, 2011 | Gateway MX6453 Notebook
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Laptop won't power up without battery, needs 135W adapter
The ASUS power adapter is below spec and it may damage the adapter because the HP is drawing 45 W more power than it can deliver and will cause it to overheat.
The 17" HP requires 18.5 or 19 volts depending upon the model of the HP laptop (check the power requirements on the label on the bottom of the laptop). If the ASUS adapter doesn't deliver this voltage, it most likely won't power up the HP laptop.
Use the power supply/adapter from the other 15" HP. If this HP's adapter has a voltage output of 19 volts and the 17" laptop requires 18.5 volts, don't worry a voltage difference of 0.5 volts, the only problem is whether the power plug will fit into the power socket of the 17" HP laptop.
Oct 28, 2009 | HP Pavilion zd7020US Notebook
HP laptop does not start.LED on.black screen "warning-battery low
Im not sure but there is normally a button somwhere on the laptop which acts a a reboot button. normally very small and have to press it using a pin etc. You could try that then turn it on but not sure if it will help?
Jun 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
HP pavillion dv1000 won't charge
Try using your laptop without the battery and just using your power supply (new universal or your old one).
If your laptop works on just mains power it means your battery is causing the problem, which is not unusual.
Aug 07, 2008 | HP Pavilion dv1000 Notebook
Wont Charge
Generally I would say power supply, but I'm leaning towards the power management chip on the motherboard. You can send it off and have it repaired or replace the board.
Jun 12, 2008 | HP Computers & Internet
Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
Mar 14, 2008 | HP Pavilion dv6000z Notebook
HP has a known issue with this model. You might want to check there site here:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c01087277&dlc=en&lc=en&cc=ca
Jan 24, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
David Payne
David Payne
