Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Poor print ,not dark enough.had this problem before and changed printer head and fixed .I think head going bad agian.I did everything the trouble shoot told me.what do i do?
  • Kodak Master
  • 1,879 Answers
Common problem with Kodak print heads. And since you're done with the troubleshooting and is likely very familiar with the printer and its problem, definitely the print head is going bad again.
Thanks
Posted on Aug 31, 2010
  • wullen Oct 27, 2010
    I am selling Kodak new printhead now:http://www.aliexpress.com/product-fm/348...
    (PS. If AD is not welcome here, please delet it)
My eltron ip2844 wont print dark enough. I went into setting and turned the burn darkness to 15, but still not dark? Help!!
This may be due to your thermal paper.
This printer doesn't deliver enough heat to your paper or you have a problem with the head pressure.
Press on the bloc while printing to see if it's this reason?
You may also have a mis-alignement of the thermal head.
Try also to change the print speed?
Aug 05, 2011 | Zebra Eltron LP 2543 Thermal Label Printer
I have a canon MP630, for some reason the blue cartridge wont print. Was full and not printing so i changed it and still nothing. I have been using generics ever since i bought the printer without a...
I've had the same problem with my MP630, and have tried everything to fix it - still not working properly. I've washed the print head, changed settings, changed printer drivers, upped the cyan on my preferences, but still get poor quality blue, which in turn skews all other colours. Can anyone help???
Aug 24, 2010 | Computers & Internet
When you change the print heads for a Hp L7580 what problems does it resolve?
Replacing the print heads fixes any poor print quality you are experiencing. Typically people replace print heads when a certain color (most likely black) is printing very faint or streaky. Over time the nozzles in the print head can get clogged with dried up ink. Enough clogged nozzles will inhibit ink from being deposited on the page in certain areas.
Feb 02, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Printing in wrong colors
You need to go to the maintenance tab on your printer properties and deep clean the head. If that fails, remove the print cartridges and poor some rubbing alcohol on the print head enough to wet it, replace cartridges and deep clean again, if that fails you may need a new print head or replace the printer, cost dependent.
Oct 08, 2009 | HP Photosmart 3310 Printer
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
Epson 9600 no ink coming out
That happens to me as well I'm using epson R230x pigment ink. At first yellow does'nt come out. and fixing the yellow by pumping it with a solution and putting everything back ALL HEADS ARE NOT PRINTING ANYMORE....
Sep 26, 2009 | Epson Stylus Pro 9600 InkJet Printer
Light in color and won't copy dark. It come out light purple
you may try
1) color ink cartridge--- no enough ink or the cartridge ink channel dryer and constipated, refill ink and put down the cartridge bottom surface to water a little for 1 hr, then set back. or change a new cartridge if not fixed go next
2) print head--- the ink channel dryer and constipated, take out print head clean it's ink channel using cleaner or steep in water (do not touch circuit pin area with water) 20 minutes or longer. then set back and test (you can do more times), still not fixed, your print head have to change.
Feb 06, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Only half of the 6c nozzle check pattern working
That issue usually indicates a bad printhead. I had to fix a lot of i9900 printers, and after cleaning the printhead there still was no change. Other models do that too when the printhead starts going out. This is an expensive printhead, but easy to replace, as you know. Link below to some options:
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p3984.m570.l1313.TR0.TRC0.H0.Xi9900+printhead.TRS0&_nkw=i9900+printhead&_sacat=0
Jun 09, 2017 | Canon i9900 InkJet Photo Printer
PRINTING IS DARK
Dark copies (whole pages) are usually a result of poor charge of the drum. Drum is that green thing (usually, seen blue ones too). You get text and graphics in places, where the drum has been discharged (light discharges drum). So if everything is dark - the drum is discharged fully, or not charged at all. Look for bent, dirty or missing connector plates, springs, paper covering contacts. If you get lines it could also be the fuser (hot thing) - needs replacing. Everything depends on how the copy looks like, I would have to see it. Hope this is helpful somehow ;-)
Aug 28, 2008 | Brother HL 5140 Laser Printer
Poor printing
With printers $23 at Wally world these days its not fessible to repair this age of printer. The problem we have with customers here locally is the same thing. We ask them "How old is the ink?" They reply "Its new!" then come to find out later that its new to them cause they bought it 6 months ago and havent used it since. Well typically if this is a cartridge printer eg:the tank and head is one unit, change the blasck cart. IF it has seperate heads change the black print head it has probable reached the end of its life, but the thing with the heads is there typically $30-$70 each which its more feesible to go get a new unit.
Sep 14, 2007 | Canon MultiPASS F50 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
798 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
