Question about Jacuzzi Bath Era BK37 959 White toilet bowl and tank
Jacuzzi sent me new rubber gasket for attaching flapper assembly to tank-(held in place with a large white plastic nut) Does the totally flat side of the rubber washer face the tank or away from the tank? Also, how tight should this connection be?
  • 28 Answers
The rubber washer goes to the inside of the tank under the flush valve which gets screwed on with the large plastic nut on the bottom side of the tank. Then the foam gasket fits over the plastic nut which goes into the toilet bowl hole for the water to flow into the bowl. Tank needs to be removed from the toilet bowl.
Posted on Sep 01, 2010
Fluidmaster instructions
Turn off water at valve. Drain tank. Remove fill line that goes to bottom of tank. Remove large nut from underneath tank holding in old fill/float valve assembly. Clean area around hole in tank above and below. Get large black washer from kit put onto bottom of fluid-master pipe (lip side down). Place fluid-master into hole from top of tank to check height. Top of fluid-master valve should be even or just a bit below top of tank. To adjust hold head of fluid-master and turn pipe ccw to lengthen, cw to shorten. Once adjusted put into tank. Using large flat nut in kit tighten to tank, making sure its centered in the hole, no part of the float touching the sides of the tank, and that the small nipple on the side where the small black hose will attach is facing towards the overflow pipe. Make it nice and tight, but don\'t break it.Then re attach water supply line you removed earlier, hand tight only. Place pipe clip onto top of overflow pipe (funny looking plastic clip with metal piece attached). Attach small black hose to fill valve nipple on side of valve, other side to funny clip. You may need to cut it shorter so it doesn\'t kink. Tun on water and adjust float if required. Level should be 1/2" below top of overflow pipe.
Aug 23, 2014 | Home
Blanco Supreme 533-U sink drain leaking at seal
The sink basket/strainer that fits into the large hole of the sink should have either a bead of silicone sealant applied to the sealing lip of the assembly or a ring of plumbers putty. Silicone will work very well if the mating flanges are clean and dry.
With the baket in place, the rubber seal goes between the large nut and the sink. A bead of silicon on this is optional on the sink side of that rubber seal. and the nut tightened down snug , forcing some of the silicone out fro beneath the mating flange and rubber seal. Tight enough so the basket is not free to move. Be it plastic or brass/metal, that order is the same, only a plastic nut is not tightened as tightly as a metal nut would be.
On the bottom of the drain basket assembly there is a nut, to retain a plastic or brass tail piece. The plastic tail piece will have a polyetheylene "flanged washer" for a seal to the bottom of the sink basket. If it is a brass tailpiece, a rubber seal and metal nut is used with "pipe dope"/thread sealing compound used on the threads of the metal nut. With the plastic nut, you can apply a few wraps of teflon tape to the threads of the drain basket, but is not required in most cases as the poly flanged washer will form the seal. The plastic nuts should not be tightened any more than hand tight.
beneath that, the rest of the drain assembly attaches. If plastic- no more than hand tight. if metal, only about 1/4 turn past hand tight. Metal nuts and parts should use rubber gaskets/seals and the plastic parts should only use the poly tapered/lip seals.
Jan 15, 2012 | Plumbing
Tank to bowl leaks
Turn water supply line of to toilet. Flush and hold handle down to drain water from tank. Take lid of tank off and use a towel to soak up the rest of the water inside tank. Remove nuts on bottom of Tank bolts. Lift off and lay down on its side. Remove the rubber or sponge type gasket that is on bottom of the tank that covers the nut from standpipe assembly. Buy new gasket and install back on bottom of tank over Nut for standpipe. Put tank back on toilet bowl. Install bolts and tighten. reconnect water line and turn on.
Aug 25, 2011 | Jacuzzi Bath Perfecta EZ33 959 White round...
Please tell me how to replace the gasket on the flapper assy.
flapper.jpgFlapper or flush valve needs servicing
First try cleaning minderal deposits from around the valve seat. This can keep the flapper valve from sealing properly and allow water to seap into the bowl. First turn of the water and flush the toilet to empty the bowl. You can unhook the flapper valve to get it out of the way. Using emery cloth scrub the inside of the valve seat to remove the mineral deposits. Next coat the valve seat with petroleum jelly to help the flapper valve make a tight seal. Replace the flapper valve, turn on the water and check to see if the water still leaks.
If the flapper valve is old it may be deformed. In this case you will need to replace it. You can unhook the valve and remove the lift chain from the valve. Be sure to purchase a similar size replacement valve.
If the valve seat is damaged you will need to replace the entire flush-valve assembly. You will need to remove the tank to do this. Be certain to turn off the water supply and flush the tank to drain it. You might also want to place newspaper and towels on the floor to soak up any water that may leak out. Using and adjustable wrench loosen the nuts at the supply tube and push the tube aside. Next, use a flat-head screwdriver to hold the bolts inside the tank still while using an adjustable wrench to loosen the nut on the bottom of the tank. You will then be able to lift the tank off of the bowl. Lay the tank on the newspapers or towels.
To replace the flush-valve assembly first remove the old one by unscrewing the locknut on the bottom of the tank. Use a hacksaw to cut the new overflow pipe to 1/2 ince below the tank top. Put plumber's putty on the washer at the base of the flush-valve assembly and push the assembly against the tank opening, removing any excess putty. Use a monkey wrench to tighten the locknut. Replace the gasket over the locknut and replace the tank on the bowl and reassemble them.
Jun 15, 2011 | Kohler - Toilet - Two-piece - Highline -...
Flapper problem
did you have the tank removed from the bowl?
if you did, there is a rather large nut that holds the flush valve to the tank, fairly simple to reinstall.
if you did not have the tank removed from the bowl, and you pulled up on the overflow tube "round white thing" then you probably broke it. you will need to replace the whole flush valve assembly.
you can get one from your local hardware store. you will also need new tank bolts, and a new gasket that goes between the tank and bowl.
Jul 04, 2010 | Pegasus Technologies Pegasus Toilet Paper...
How to assemble tank to bowl jacuzzi toilet perfecta
  1. Place the Rubber Donut on th bottom side of the tank (this will form a seal from the tank to the bowl)
  2. There are two small holes to either side this is for your two tank bolts. Place a washer on both bolts and place them in the two holes with the head of bolt and washer inside the tank. Place tank on bowl, matching up the holes.
  3. there are two plastic nuts that are beveled on one end, with bevel up toward bolt head thread onto bolt finger tight. Repeat for remaining bolt.
  4. Apply a little pressure to one side of tank and tighten nut finger tight again then repeat for other side. May need to do this a couple of times back and forth. IMPORTANT tight the nuts equally and carefull not to overtighten or you will crack the tank ONLY FINGER TIGHT.
Good Luck and have a Great Day. Please give a 4 THUMBS UP if this free answer was helpful. THNX
Apr 01, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
The tank leaks where attached to bowl. Are there any universal gaskets I can use?
you can buy a servicing kit from plumbers merchants which includes the necessary big rubber seal when fitted make sure the 2 retaining plastic or wing nuts on cistern are tightened evenly
Mar 12, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Installing new jacuzzi 1.6 gallon maxima toilet. despite following the instructions, the water is leaking from between where the tank connects to the bowl. Please help.
Yes, it seems the folks who wrote the instructions have never actually done any plumbing.
first place a rubber washer on the bolt, then put it through the hole in the tank. Then place another rubber washer on the bolt, followed by a metal washer and a nut. Tighten the nut, not the bolt.
Using a screwdriver hold the bolt in place, and tighten the nut until snug and the rubber washers are compressed slightly.
Follow this step with all the "tank to bowl" bolts.
Now the bolts are tight to the tank and will not leak water.
Then place the large rubber gasket over the flush valve hole on the bottom of the tank. and set the tank on the bowl with the bolts through the bowls holes.
Place a metal washer on the bolt, and then a nut.
Tighten each nut equally until the tank has no wobble.
Oct 01, 2009 | Jacuzzi Bath Maxima EL61 959 White...
Jacuzzi Bath Era BK37 959 White toilet bowl and tank Logo
275 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
