Question about Dishwashers
My dishwasher makes a horrible noise, either during wash or drain out not sure
  • srpug Nov 13, 2008
    my GE dishwasher makes horrible noises Please help
    Genius:
  • 1,073 Answers
What is the model number of the dishwasher
Posted on May 11, 2008
Why is my whirlpool dishwasher making a loud noise during drain, wash and rinse cycles?
They can be complicated to re-assemble. Best solution is to video the procedure (if you have a video camera) during disassembly and make notes and diagrams to orient things properly and make sure the correct screws go back where they shoud. Takes more time, but you'll be glad you did, it will save you a lot of aggrevation in the long run.
Aug 24, 2014 | Whirlpool 24 in. GU1500XTLS Stainless...
My GE Nautilus roll away dishwasher is making a horrible noise when it is turned on. We have had the impeller changed before when having similar problems (and while it was under warranty), but we aren't...
noise mean something got broken during washing,usely it glass are trash made sure your dsihwasher unplug before u work on it.if you open door to dishwaasher in back of the tub there a drain for washer an trash drain out if you take cover off to clean out BUT becareful there might be broken glass in there so you dont want get cut if you are not sure how do this call appliance service tech better be safe
Dec 23, 2017 | Dishwashers
Water is not draining after wash. What might be the cause?
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit ( there are others, this is just an example )
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plug at connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Apr 01, 2010 | Jenn-Air 24 in. DW861 Built-in Dishwasher
Bit of plastic stuck in the drain is making a horrible noise.
On this particular model you have to go thru the top section of the pump. Remove spray are and using torx crew driver remove all the upper section to get to the piece of plastic. Don't worry you can do this and not cause any leaks.
Jan 31, 2010 | Dishwashers
The dishwasher wont stop drying to drain . The darin is not blocked
check the following:---- Check for hose kinks or food plugging drain hose. Start at the drain port exit
  1. Check the check valve and drain hose for debris.
  2. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  3. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  4. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  5. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  6. Check pump impeller for damage.
  7. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
    thanks.
Oct 10, 2009 | Dishwashers
Water does not drain
Hi
You can :
Please contact for further clarifications.
Thanks
Rylee
Jan 27, 2009 | Kenmore 17252 Free-standing Dishwasher
My dishwasher does not completely drain after a wash. what do i do?
  6. If you have recently installed a new garbage disposal, check knock out plug at connection.
Jan 08, 2009 | GE Nautilus 24" Built-in Dishwasher
Nautilus dish washer won't drain
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
    ok.
Jan 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher was making whirliing noise during wash, now no wash, only fill and drain
there is a #10 torx screw holding that cover down.do not drill it out. after you take it off you can tell if the chopper is broken.be careful for broken glass.
Oct 17, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Loud buzzing noise throu8ghout cycle. Sometimes washer sticks in wash mode
first thing i would check is to make sure your copper water line is not touching the motor this will give you this noise. just take off lower kick plate and start d/w you will be able to tell where the noise is coming from.
Nov 28, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Dishwashers Logo
104 people viewed this question
Top Dishwashers Experts
