How do i switch the Hz setting on the monitor
  • 3,287 Answers
Usually, if there is a selector switch to match electrical requirements of a monitor or computer to that which may be available in the home, it is for voltage or voltage AND frequency. Seldom is there are selector for frequency only (I've yet to see one anyway).
The selector switch it typically found near where the AC mains power cord enters the enclosure. This can be on the monitor itself - or in the case of a monitor that uses a low voltage cable and connector connected to a power adapter, it would be located on the power adapter instead. Sometimes, these devices automatically detect and switch to match the power being supplied to it. The device should clearly indicate that it will work a wide range of voltages - do not assume it will if it does not specifically indicate that it will.
The selector above is set to 230 volts.
Set the selector switch BEFORE connecting to the power outlet. Most times, the selector switch has the voltage indicated on the slide. The switch will allow the user to choose 110-120 or 220-240 volts. The 110/120 selection is likely to be the 60 Hz variety and the 220/240 selection is likely to be 50 Hz.
If you are unable to locate such a switch, the device is not intended to be changed by the user - and there is likely no "easy way" for the user to change it.
Please rate this reply - good luck!
Posted on Aug 31, 2010
  • Steve Sep 01, 2010
    I misunderstood your question - it appears you were looking for SCREEN REFRESH FREQUENCY adjustments. Disregard this reply as it deals with power supply frequency and voltage adjustments instead. Good luck.
  • 629 Answers
Go to the display properties through the control panel, or right-click on the Windows Desktop, then click Properties. Go to the Settings tab, then click the Advanced button. On the next screen, click the Monitor tab, then you can find the section to change the hertz.
    Scholar:
  • 85 Answers
The monitor will swap to what you set it to.
I assume that you will have to go into safe mode. press f8
when starting your computer.
in windows go into control panel
select classic view
display properties in xp / Personalization in vista
settings in xp / display settings in vista
advanced
then click the monitor tab
and change the mode 60hz is usually a safe bet.
Confusion installing drivers on Dell Latitude 120L laptop running XP
to run duel screens you will need a graphic board that has 2 outlets
I run a nvidia board and it has a dvi and vga outlets connected to 2 monitors
open up the control panel and go to display
that will show 2 screens and they will be identified as 1 and 2
the printing will be for one screen and it will say -make this my main screen
further down will be a dropdown box that will have extend screen
click on that
as for the screen size or pixal settings click and drag the slide button up to the top and click on apply
any way in that display section you can move and click on different settings to get what you want, always apply to fix the settings selected
it will come back with a message --do you want to retain the settings and if you are happy --click on yes
regardless of what you choose , you can always reset at a later time
Feb 26, 2017 | Aoc Monitors AOC e2752Vh Glossy Black...
Tell me what is samsung syncmaster 794 default setting
The maximum resolution supported is 1280 x 1024 pixels at 65 Hz refresh rate, while the recommended resolution stands at 1024 x 768 pixels at 85 Hz. However, the maximum usable resolution is 1152 x 864 pixels at 75 Hz. Maximum usable resolution signifies the maximum resolution supported by a monitor at a refresh rate of 75 Hz or better. Though 85 Hz is an ideal refresh rate, 75 Hz is the lower limit. Any refresh rate, lower than 75 Hz, will give a flickered output and can cause some serious eye damage after prolonged usage...i hope this helps.
Aug 29, 2011 | Samsung 793DF 17" CRT Monitor
Unable to get 1024 x 768 resolution on philips 105e
Hello, that resolution should be available but only at a refresh rate of 60hz as per the specs pasted below. Can you see this resolution setting on your graphics card? If not then perhaps you need to check you have the latest driver for your graphics card and just make sure that your graphics card does support that setting anyway.
Display
Diagonal Size 15" Viewable Size 14" Dot Pitch / Pixel Pitch 0.28 mm Max Resolution 1024 x 768 / 60 Hz Max Sync Rate (V x H) 120 Hz x 54 kHz Video Bandwidth 65 MHz Factory Preset Resolution Modes 1024 x 768 / 60 Hz
800 x 600 / 85 Hz
640 x 400 / 70 Hz
640 x 480 / 75 Hz
640 x 480 / 60 Hz
800 x 600 / 75 Hz
Regards,
nicam49
Dec 26, 2010 | Philips SoHo 105E 15" CRT Monitor
I have a 21 inch CRT Monitor. It works fine in all other rooms except mine. In my room, the display rolls upwards from the instant it is switched on. Please guide me as to what is causing this vertical...
its the Hz it is set on the "refresh rate" it is likely you have in all other rooms except yours teh same kind of lighting and in this one room it likely has the same Hz lighting as your crt monitor set it above 60hz and you should be fine.
Mar 25, 2010 | Computers & Internet
Upon startup a gray box appears reading "frequency out of range"how do i fix it? 95kHz / 120 Hz Please change it to 1280 x 1024 with 60. i have set the computer up with another monitor and it works just...
Reconnect the "other" monitor.
Right-mouse click anywhere on your desktop "wallpaper".
Click Properties.
Click Settings.
Move the slider to 800 by 600.
Click Advanced.
Click Monitor.
Change to 60 Hz.
Click OK.
Reconnect the LCD monitor.
It should display your desktop, at 800 by 600 by 60 Hz,
including that "Properties" page.
Move the slider to 1280 by 1024.
Click Apply.
If you can see the "prompt", click OK.
If you cannot see the "prompt", wait 15 seconds,
to revert to 800 by 600.
Slide to 1024 by 768, and click OK.
Jan 04, 2010 | Princeton Digital VL1918 Monitor
Need new drivers for Hyundai Monitor Drivers IT
Try connecting the LCD monitor to a notebook computer.
Set the notebook's video to 800-by-600 and 60 Hz,
to see if the LCD monitor will accept these settings.
Set the notebook's video to 1024-by-768 and 60 Hz,
Set the notebook's video to 1280-by-1024 and 60 Hz,
Restart your desktop computer in "Safe Mode",
after reconnecting the LCD monitor, and use the settings that work
when the LCD was connected to the notebook.
Nov 09, 2009 | Hyundai Electronics ImageQuest N91S 19"...
Not set h size in dos mode
change the monitor frequency 60 Hz.
Jun 04, 2008 | LG Studioworks 563N 15" CRT Monitor
Samsung sync master 510 monitor display problem
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1024x768 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab. Change the screen resolution by moving the slider to the recommended setting (1024x768)
and
under the advanced button click the "monitor" tab - make sure the screen refresh rate is set to 60 hertz (60 hz)
May 21, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
TFT Problem
This LCD can work at 75 Hz refresh rate, btw much more healthy for your eyes, you can change it accessing Control Panel -> Display -> settings -> Advanced -> Monitor -> Screen Refresh Rate -> select 75 Hz.
Dec 07, 2007 | Samsung SyncMaster 152N 15" LCD Monitor
No clear picture just wavy lines and error message
The spec sheet I found says your monitor should be able to display 1280 x 1024, 720 x 350, 720 x 400 and four other resolutions in the 640 x .... range which are pretty useless. Try setting ti to 1280 x 1024 at 16 million colors @ 60 Hz and let us know what happens.
Nov 26, 2007 | IBM 9516 Monitor
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
