Question about Protron PLTV-3750 Television
Screen split half upside down half still ok good clear picture
I replaced my main board on a 42lb45rq now my picture is upside down
Configure Windows "video" properties to have Windows "rotate" the picture 180 degrees, i.e., make Windows produce "upside-down" output, and the screen will "flip" that output.
Oct 30, 2014 | RCA 42LB45RQ 42 in. LCD HDTV
Turned the tv upside down now the screen is divided and reversed
This is a easy one....turn all your chairs upside down next. Haha! Just playing around. I sure hope everyone here has a sense of humour.
Aug 10, 2012 | Panasonic TCL42U22 42 in. TV
TV picture upside down.
go to " SETTINGS " and rotate picture in there , hope it helps , AJ
Nov 03, 2009 | Audiovox VE1020 10.2 in. TV/DVD Combo
Bottom half of screen doesn't work
Since I do not have a picture of your screen, I can only guess. If it looks something like on the figure below, that can be fixed.
In the foregoing picture, the screen is split horizontally. The black cursor is in the lower half of actual screen. You can restore the full screen by pressing [MODE], and scrolling down till the last line Full Horiz G-T. Move cursor on Full and press [ENTER]. Then press [CLEAR] to go back to the main screen.
If I did not guess right, well I am only human.
Oct 18, 2009 | Texas Instruments TI-84 Plus Calculator
After xbox is turned on the screen is split in half?????
I had this problem with my dvd player. It turned out the solution was to replace the cables. Once I used a new set of cables the problem vanished. This may work for you as well as if the cables get kinked or frayed at all it will not give an optimal connection. Hope this helps you out.
Jul 26, 2009 | Microsoft Xbox 360 Console
LG 42PC3D plasma television -- screen split down the middle
Our 42" LG picture is also split down the middle. It doesn't matter if it is cable or a DVD. I would love to know if anyone has found out the solution to this prob. The TV is only 3 years old...
Jun 19, 2008 | LG 42PC3D 42 in. Plasma Television
Flashing led light
Sounds like the circuit board may need to be replaced. Mine did a similiar thing only my picture turned upside down, screen went blank yet had good voice. Samsung tech said the 2 circuit boards were bad and had to be replaced at a cost of $780 in parts plus labor. I bought a new LCD TV, not Samsung.
Aug 27, 2007 | Toshiba TP50G60 50" Rear Projection...
Picture reversed and upside down on screen????????
just happened to me, phoned customer support and solution is to press the Ctrl key and Alt key and Up arrow together and it should solve the problem
May 02, 2007 | Toshiba SD-P1200 Portable DVD Player
Televison & Video Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
