Question about Polar S150 Heart Rate Monitor
Source of a Polar S150 rubber seal (gasket) for sealing the back plate.
  • 831 Answers
Took apart a polar s150 watch to change the battery. I went too far and 2 little springs fell out and a small black rubber donut. I don't know how/where to put these back. The two springs appear to...
Hello Clintsanders,
I am sorry to inform you but there is no way that you can repair the unit yourself, you will need to return the unit to Polar to be repaired. Here is a LINK to Polar and all of there service centers and the numbers and procedure that you need to follow in order to return your unit for repair.
Sorry but this is not a DIY item.
Thank you for choosing FixYa.com
Justinbur167
May 16, 2011 | Polar S150 Heart Rate Monitor Wrist Watch
I lost the gasket for my watch, ive tried to see where i can gat one like that but i cant find it nowhere. help
They are not a part that is sold separately as the watches are not intended to be user serviceable. The only way to get the watch properly sealed again is too send it into a Polar Authorized Service Center and have them replace the seals/ Batteries. The seal/ gasket is a pressure seal, so when they put the new one in they also use a special vacuum sealer to make it water tight. Send the watch in and they will fix it up right for you, plus you get a warranty on the service work they do, very helpful if something goes wrong.
Apr 16, 2011 | Polar FT60 Cross training Fitness Watch ...
I need to replace battery
All you need is to open watch case back, remove the rubber seal and unclip the contact. Take the battery out (memorize polarity: + and -) and buy the same one. Fit new battery in the right way back in watch, fit the contact, place back rubber seal and refit watch case back. Reset the watch. Done.
Feb 25, 2011 | Polar M32 Heart Rate Monitor Watch
Hello, I am looking for a replacement body for my Polar F11 HR watch.
Wow. I just went through this.
Polar doesn't sell replacement bodies. You can only go through a repair center for about $50. I bought a "display only" non-functioning model off of eBay for $10 and the body is the same as a functioning model.
It came with protective plastic over the face that peels off and a dummy display on the inside that peels off too.
The only problem is the display model didn't have a seal/gasket and after removing my old seal it was stretched out and didn't fit. I cut the seal to make it shorter but now it is no longer waterproof.
It is possible the seal can be purchased at one of the Polar service centers.
I suggest removing the seal carefully without stretching it.
Good luck.
Jun 14, 2010 | Polar F11 Heart Rate Monitor
How do i take out a rear main seal?
Remove the transmission, after holding the rear of the engine supported, using a jack with a piece of wood between it and the engine. Remove the clutch and pressure plate, and the flywheel or if automatic, the flex plate. The rear main seal retainer will then be exposed. Remove the 2 oil pan to main seal retainer assembly, and the bolts circling the retainer, and slide the retainer assembly unit back off the crankshaft. Remove the old gasket from the retainer, and clean the gasket ridge before installing a new gasket. It's a one piece hard rubber gasket, which must be inserted in the retainer evenly. This can be done on a work bench, or flat wood on a concrete floor, Some light oil might help it seat easier, Once seated slide the retainer containing the new gasket back over the rear of the crankshaft, A rubber hammer will help ease it back into position, Replace all bolts, not forgetting the oil pan to retainer bolts, and reinstall all parts in reverse order of removal. If a manual trans, this would be an excellent time to install a new clutch kit.
Jan 11, 2010 | 1989 Mazda B-Series
Replaceing the wet end seal on my hot tub
disconnect power take pump out remove front plate take back cover off motor use 7/16 wrench to hold shaft unless it has a place for a flat head screw driver at the back of the motor while holding shaft unscrew impellar counter clockwise take shaft seal off impellar make sure rubber gromet comes off with seal take back seal plate off motor by unscrewing bolts thru back of motor should be 4 knock out ceramic ring replace ceramic ring with rubber side toward plate reinstal back plate install seal on impeller with with flat side with rubber gromet toward back of impellar. screw impeller back on holding shaft if the shaft is rusty and pitted clean off with sand paper b4 reinstalling impellar lube up oring around front plate screw back tight and reinstal pump.
Sep 18, 2009 | Jacuzzi Impeller, L - 3/4 H.P
Can't remove rubber seal from Espresso Gaggia /A machine in ...
Screw a self tapping screw into the perished rubber seal. Then pull it out with a pair of pliers.
Sep 14, 2009 | Gaggia Baby Espresso Machine
Setting Polar CE0537
You do not have the right model number. For some reason, Polar puts the CE0537 in big numbers on the back of the case. The real model number on my unit was in very light engraving right above the words "Polar Electro" on the back of the case. Looks like they have an engraving problem where both the model and serial number are very hard to read. If it helps, my model was S120 and I found the manual quickly on the polar site. The polar site also has the location of model numbers in their FAQ area.
Jun 29, 2008 | Polar S150 Heart Rate Monitor
Horse trainer polar
Step 1: Remove the old battery so you can find a replacement. Somewhere should sell you the battery alone, even if they won't do the replacement for you.
Step 2: If you're not going to use this in a wet environment just put the new battery in and don't worry about the seals. Just be careful when you clean it. For example, use a damp cloth but don't immerse it.
Step 2b: If you really want to seal it get some silicon seal from a hardware store or maybe an outdoor store. Line the edge of the battery compartment where the cover meets the compartment and replace the cover. Let it set and you should be good.
Nov 25, 2007 | Polar S150 Heart Rate Monitor
Polar S150 Heart Rate Monitor Logo
149 people viewed this question
Top Polar Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Jerry Greenberg
Jerry Greenberg
Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
