Question about Tricity Bendix 24 in. DH102 Free-standing Dishwasher
Tricity Bendix DH101 dishwasher
My dishwasher will not empty
My tricity bendix dh101 will not fill up with water what could be the problem
Posted on Nov 03, 2008
My Tricity Bendix DH101 has a drip on the inside when it is switched off.
Posted on Jun 26, 2008
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: tricity bendix dh101 wont empty
Check the drain hose and the drain lines, if you find no obstructions, then you have a defective drain pump.
If you find no problem with the drain lines, you may need to replace the pump.
If you enter model number here , you can find parts and diagrams.
Posted on Dec 08, 2008
ginko
  • 19396 Answers
Check pressure from power supply, check if the inlet valve is faulty or obsstructed.
My tricity Bendix dh101 fills with water goes for a short while and the trips the electricity. This is concerning me.
Most likely..... 1st does it run the exact amount of time when it trip. If so the action that it is about to cycle into has to much of a load on it, or bad breaker. if machine detects a problem it will automatically go 2 zero and let the water out. Also check the board for corrosion
Dec 19, 2017 | Tricity Bendix Washing Machines
Can I use my Triciry Bendix dishwasher DH101 if I remove the top. It needs more clearance below the worktop. When I remove the top there is a material, not a solid top.
Listen to hear if dishes are rattling against each other. Cups should be loaded only in the top and care to keep each cup separated from other. Chipping usually will occur when dishes are close together and in contact. The racks are rubberized and would be very unlikely the source.
If the feet are adjusted so the machine will not rock it would be unlikely that the top on or off would have any effect.
The upper shelf is adjustable up or down. Suggest locating upper shelf to the up position.
TRICITY BENDIX Dishwasher
Hope this helps?
Dec 06, 2016 | Dishwashers
I have a tricity bendix dh101 stopped working cold water not going in to manchaine many thanks if u can help
Possible that the INLET valve is faulty /clogged or there is no voltage to switch ON the inlet valve.
So measure the voltage at the inlet valve, also check if the inlet filter is clogged.
Check the water pressure at the inlet to confirm, remove the line from the inlet valve and confirm the flow when activated.
Aug 08, 2011 | Tricity Bendix Dishwashers
I have a Tricity DH101 replacement element, but can't see how I remove the old and replace it with the new one, do I have to do this from beneath the unit?
No. You need to remove the perforated floor of the machine to access the heater element, and you need to remove the rear cover to disconnect the wires. Once you have access to these points the job is actually very easy. Make sure that the power cord is removed from the wall socket before attempting any work on the machine.
Jun 25, 2011 | Tricity Bendix Dishwashers
Tricity bendix dh101 wont empty trying to but only a trickle was working ok no kinks in extract pipe
Dec 08, 2008 | Tricity Bendix 24 in. DH102 Free-standing...
Nov 03, 2008 | Tricity Bendix 24 in. DH102 Free-standing...
Dishwasher stuck in cycle tricity bendix DH 104
if this is stopping early in the cycle, the timer has just moved a little before it stops then it is highly likely to be a heater fault, check the element for open circuit, this can be accessed from under the machine, work with safety,
Sep 16, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix 24 in. DH102 Free-standing Dishwasher Logo
666 people viewed this question
Top Tricity Bendix Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Tricity Bendix Dishwasher Expert? Answer questions, earn points and help others
