Question about D-Link DSL-G604T Wireless Router
I connected a 100/10 switch behind the router. The link led (uplink) flickers and data transfert through switch in drastically reduced (by factor 150) Can I connect a switch behind the Dsl rputer ?
  • 1,879 Answers
1. Connect one end of your Ethernet cable to one of Four 10/100Mbps Ethernet LAN Ports.
2. Connect the other end of the Ethernet cable into one of the ports in the switch (try not to use the uplink port if it slows-down the connection)
Thanks
Posted on Aug 31, 2010
Set up wireless router
Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
Nov 11, 2012 | D-Link Wireless N 150 Home Router 4Port...
How many pc's, laptop's & printer's can i link up to belkin n1 vision wireless router model f5d8232-4
You can uplink a fairly good number of PCs or laptops with Belkin N1 as it supports high bandwidth. Keep in mind that upon adding every new PC, the overall bandwidth for the other PCs is reduced. If the PCs/ laptops do not require much bandwidth, you can connect / add more PCs to the network.
Generally, I have uplinked upto 10-15 clients to one router and the network worked just fine. It all depends upon the network environment and the bandwidth usage by each client PC. If the PCs are using just email and simple internet browsing (and remain idle for most of the time), you can add more clients to your network as not all the systems consume network resources at the same time.
Hope it helps! Good Luck!
CreativeTECH
Apr 01, 2011 | Belkin N1 Vision Wireless Router
How to connect the network cable
you will have 8 ethernet ports in this switch... One port is for input all the other ports are for output...
If you dont have any dedicated uplink port, then any port can be used as an uplink port and other ports becomes downlink port...
The Lan slot of router should be connected to the uplink port in switch.... you can connect upto 7 computers in this switch(in downlink ports)...
Dec 13, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Is it possible to connect wireless broadband internet with a laptop through D Link hub DE 809TC
The D-Link DE 809TC is a wired hub - it does not include any support for wireless connectivity.
On the back of the device you'll find nine RJ45 Ethernet connectors. Eight of these connect to arbitrary local network devices and the hub distributes any network package directed to the local network (regardless of its origin) to all of them. The ninth connector is an uplink. It receives packages from/to other networks.
This is *all* this device can do; forward packages to all other devices on the eight internal connectors or from/to the uplink port. It has no logic to selectively forward packages to dedicated ports (that is what a switch does) or connect to DSL service providers (like a DSL router).
For your problem you would need a router with wireless LAN support, e.g. D-Link DAP 1360.
Oct 18, 2010 | D-Link Computers & Internet
How do i connect 2 d-link switches
i found that there is a MDI uplink port for cascading
Dlink DES-1016D 16-port 10/100 Switch
Product Features
  • 16 10/100Mbps ports
  • Full/half duplex support for each port
  • MDI uplink port for easy expansion Expansion is easy through a MDI uplink port. You cascade several switches together through this port to get more ports.
  • Auto-learning of network configuration
  • Flow control in full duplex mode for protection against data loss
  • Back pressure in half duplex mode
  • RAM buffer dynamically allocated for each port
What's Included?
  • DES-1016D Network Switch
  • Quick Installation Guide
  • CD ROM
Aug 27, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
I'm having problems with my Linksys ezxs55w switcher. The plugs are not lined up with the correct lights. For example, I plug the uplink into the uplink plug, but it shows up as number 5. Same with other...
You have a 5-port router. The 5th port can be used either as an "uplink" port (with a cross-over Ethernet cable) or as a "data" port (with a straight-though Ethernet cable).
You've not provided enough details to trouble-shoot the "staying online" problem, i.e., IP-addresses of each of the connected computers/printers, whether you're using CAT3 or CAT5 or CAT5E cables, whether you've tried different Ethernet cables, and whether the router is connected into a UPS that provides "smooth" power.
Dec 27, 2009 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
Tutorials On How to configure a D-Link DES-1008D Ethernet Swich
There really isn't much to setting up an ethernet switch hub. Plug a network cable into your router LAN connection and into port 1 or uplink port of your switch. All other computers will attach to ports 2 to 8. If you have an Uplink port and port 1, they usually can only be used singlely. That is to say use either the Uplink or port 1 Using both disables the switch hub.
Jun 01, 2009 | D-Link Computers & Internet
Problems
Absolutely. The router will have an uplink port. It will indicate on the back. Hook the modem from sat to the uplink and the other 2 computers to the other ports. make sure the computers are on DHCP (they should be defaulted to it) and they should auto connect
Jan 26, 2009 | Linksys 5 x 10/100Base-TX - Ethernet...
D-Link DGS-2208 only works through Hub uplink but not router?
i think it it ehternet cable problem.
when u connect switch to swith it is twisted pair but when u connect router to switch then straight.
Dec 31, 2008 | D-Link DGS-2208 8-Port Gigabit Ethernet...
D-Link DSL-G604T Wireless Router Logo
64 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
