Question about Haier (HBF05EAVS) Beverage Dispenser
My haier beer dispenser model HBF05EBSS will not turn on. Compressor is hot and keeps clicking on and off. How can I fix
    Director Badge:
    Uploaded 100 video answers.
  • Haier Master
  • 488 Answers
Just In case You want to see how to replace compressor on refrigerator, I made video. Check it out. REPLACING COMPRESSOR TRUE AIR BEER COOLER R134A
Posted on Feb 04, 2015
  • Haier Master
  • 43,501 Answers
Try to change the capacitor and start relay first...then maybe if that don't work the compressor...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 31, 2010
Not starting
ck that you are getting power to it some of them have fuses on them , the switch may be bad
Mar 28, 2014 | Haier Kegerator HBF05EBSS Draft Beer Tap...
My True TD 50 18 beer cooler does not cool beers
If you hear a clicking noise coming from the compressor there is about a 80% chance that the compressor is dead. But you'll have to call someone out to be sure.
If the fan motor behind the grill is running (condenser fan) then the compressor should be running and vice versa. If the compressor is hot as a pistol and clicking and the fan motor is not working then it may cool down if you shut it off and you might just have a bad fan motor. With power turned off the condenser fan motor should freely spin. Compressor have a 5 year warranty from the manufacture not including labor and additional materials. Hope this helps.
Jan 14, 2012 | True Refrigerators
I have a kegerator. It's not functioning. When plugged in no clicking no sound nothing. Wondering if it's the overload switch or relay.
http://www.haieramerica.com/en/asset/product/1ffd77cfa0
This site has your product manual for your dispenser but it is very vague on trouble shooting the cooling system.
In general, the compressor is controlled by a thermostat that is usually located in the conditioned space. It cycles the compressor on and off based on the sensed temperature and the setting that it is adjusted to.
So, let's talk in general refrigeration terms. Where the compressor is located, is there a fan? If so, is it running? That fan is usually the condenser fan and is wired to come on anytime the compressor is supposed to be running. If the fan is running and the compressor is not, then there is an issue with the compressor. If the fan is not running and the compressor is not running, then there is an issue with either power or the thermostat. If the compressor is running and the fan is not, then there is an issue with the fan.
This is a good starting point. Let me know if I can be of further help.
Mar 24, 2011 | Haier HBF05EBSS Commercial Beverage...
I have a 2 year old Haier kegerator and it seems to have stopped working. I hear a clicking sound which I believe is the compressor going on and off. I have done some research and found that this is a...
Do you have any technical background? There is a simple and sure fix to this but you will need to be able to read a wiring diagram and have basic electrical tools like a wire stripper and electrical tape.
Dec 02, 2010 | Haier HBF05EBSS Commercial Beverage...
When i turn on my beer machine. It turns on and then makes a click noise and shuts down. No cooling at all anymore
What your hearing is the KliXon thermal overload tripping. The compressor is not starting and the thermal overload is trying to protect the compressor.
This can be caused by 3 things.
1. A locked rotor on the compressor. (bad news)
2. A failed PTC relay on the compressor
3. A failed run capacitor.
Usually a PTC relay and a run capacitor will bring it back to life unless the compressor is actually seized.
Thanks for using FixYa.
Kelly
May 20, 2010 | Maytag SkyBox MBV1976A Beverage Dispenser
When plugged in, the compressor never kicks on. It just clicks.
If the compressor is getting hot then the compressor is gone. But the price on a relay is fairly cheap so you can at least try it and if it doesnt work then return it and dump the unit. But like I said before when a compressor gets hot it means that the piston is bad and the rings are burnt and the oil is bad in the compressor.
Feb 13, 2009 | Haier HBF05EBSS Commercial Beverage...
Beer dispenser
Shut of the CO2 tank, then hit the pressure release valve on the side of the beer tap. Make sure there is a grey check valve in the tap where the red hose (co2) is connected. Also make sure the white ball in the tap where the white hose (beer line) is not stuck. You can remove this, it isnt really necessary. Once all checks out, open the tank and readjust the co2 regulator. The reading should not be more than 12 PSI. Everything should work just fine after this. Make sure the glass is as close to the faucet as possible (slanted is better) when dispensing beer. Hope this help :)
Jan 21, 2008 | Haier (HBF05EAVS) Beverage Dispenser
HAIER BEER REFRIDGERATOR
I have this same problem.  I have read discussions on this exact topic in several forums, and I have come across a link to a Haier Service Website.  http://service.haieramerica.com/  When you go to this site login with password "HAIER" and UserID "HAIER" and look up your model number (my model number is "HBF05EABB)".  There is a "service bulletin" which provides instruction/pictures for adjusting the thermostat.  I have not tried this yet, but I intend to later tonight.  I like my beer a little cooler than 41 degrees!  Hope this helps.
Oct 26, 2007 | Haier (HBF05EAVS) Beverage Dispenser
Haier beer dispenser model HBF05E
Either its not getting cold enough to shut off or your thermostate isnt working.. thats the only thing that cycles it.
Aug 27, 2007 | Haier (HBF05EAVS) Beverage Dispenser
Haier (HBF05EAVS) Beverage Dispenser Logo
694 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
