HOW TO CONNECT SAMSUNG LCD TV TO ACER ASPIRE
I have a samsung lcd tv LA32R7, i want to connect this with my laptop acer aspire 4710. i connected it with a vga cable, but the samsung tv cannot recognice the pc? what should i do?
  • 4 more comments
  • Ahmerjl Jul 22, 2008
    I am facing the same problem with my Toshiba Laptop. I think the problem is with the Samsung LCD itself. Its not detecting. I have tried it to lower/higher the resolution (tried it with Sony (Vaio) and Toshiba) and it just doesnt work. The PC option is 'Grey' in the Setup.
    Would appreciate if anyone can help by giving step by step instruction (using VGA cable or S-Video Cable).
  • mfs1273 Aug 20, 2008
    yes i have the same problem. after i done all the connections and swithched the pc and tv on ad off still no signal.#i cant choose from the list pc option any advice pleas ehel.
    thanks
  • prashant_b Sep 04, 2008
    How to connect Samsung LCD TV to a desktop PC via a 15 pin VGA cable
  • johnorion Dec 29, 2008
    I have done all that Ahmerjl said but still is gray on the input menu.
  • darkness_923 Feb 24, 2009
    I have an Acer Aspire One laptop and the TV that I own and wish to switch screens to, a Dynex 19" model, does not recognize my computer. Any ideas on how to do so?
  • Anonymous May 23, 2009
    I can't connect either of my laptops (ThinkPad or Acer Aspire One) to my Westinghouse lcd tv using VGA. I have the right cord....but the tv won't detect a signal. What do I need to do?
Atlast I got some help from the right people (Samsung)! I would like to share it with others facing the same problem:
If you are using the D-sub 15 pin jack (VGA Monitor Cable: make sure its 15 pin and NOT 14 pins), follow these steps:
  1. Make sure your TV and computer are off.
  2. Using a 15 pin D-sub (standard) video cable, connect the Video Out jack on your computer's video card to the PC In jack on the back of your TV.
  3. Using an audio cable with a min-stereo plug on one end and two RCA jacks on the other, connect the Audio Out jack on your computer to the left and right PC Audio In jacks on your TV. (Note: If you have your computer connected to separate speakers, you can skip this step)
  4. Switch on the Notebook and Adjust the Resolution (800 x 600 pixels would do). You can go to Control Panel and Adjust the screen resolution. (Keep ‘Screen Refresh rate’ at 60hz in the Monitor Settings)
  5. Switch on the TV and try to Select the Source as 'PC' (you can do this by either pressing the 'Source' button several times on your TV remote or go to the Menu - Setup and Select the 'PC' as source there).
  6. In most cases, after following the above steps, the TV would start to show 'Auto Adjusting' message and it will start showing your Desk top on the TV. But incase it doesn't work, you can do the following:
a. Mostly the problem lies with the VGA cable. Make sure you have the right one (15 pin) and its securely attached at both ends. If you are not using the right VGA Cable, it means that there is no connection between your TV and Notebook. Your TV will show 'PC' in Grey in the Source Input list (Go to ‘Menu’ from the TV remote).
b. Both your Notebook and TV should be switched off when you are connecting the cable otherwise one of them might have a problem detecting the other one.
c. Try Pressing Fn + F5, F6, F7 (depends on which Notebook brand you are using) on your Notebook several times. At times, you will see some signs that the Notebook and TV are trying to connect. Select 'CRT' from list of displays available to you.
Posted on Jul 23, 2008
At my mom's at christmas:
1. turn samsung off.
2. enter service mode via remote: mute-1-8-2
3. turn on power
4. you are now in service mode. navigation is clumsy, but use the up/down/left/right/menu/exit buttons, etc.
5. find the field called "Option Byte"
6. Switch PC from "Auto" to "Enable"
7. Get a hug from your mom, you're awesome!
note: be careful messing around in that menu. This simple bit flip that gives you VGA input doesn't erase or delete anything, but many other options may.
Posted on Dec 28, 2010
Http://samsunglcdla32a330.blogspot.com/2009/08/samsung-lcd-la32a330-cable-connetion.html
Click above link for solution.. Pictures included..
Posted on Sep 19, 2009
My acer 5100 has acer empowering utility programs, you need to go there. the pathway is: Start - All Programs - acer empowering tecnology - acer epresentation management - click on "Projection: XGA (1024 x 768) icon" this should send the screen signal out the VGA jack in the back of the notebook to your TV. Hope this helps
Posted on Jan 21, 2009
You can trick your Samsung HDTV into selecting the PC input!
Read my blog post here:
http://pctvcables.com/blog/?p=13
Posted on Mar 19, 2009
  • 558 Answers
The tv must be set to vga input
Posted on May 10, 2008
<a rel='nofollow' href="http://computertotvconnection.com/">Computer To TV Connection </a>
Posted on Jan 05, 2011
Cables that work are on ebay. Search 'Samsung HDTV PC cable".
Posted on Sep 21, 2009
How do I connect my acer netbook to my CRT HDTV? I have an adapter, but the image is not appearing on the TV screen. I restated, set it to 800 by 600, but no dice. My adapter has 15 pins. What can I do?
Posted on Jul 29, 2010
Plug your laptop into the pc, if it doesnt register leave the tv on but change it to the relevent source channel e.g. ext. 1, PC, S-Video. Then restart the laptop. That should work.
Posted on Oct 04, 2008
My laptop is Acer Aspire 4920. When I connect to Samsung LCD TV nothing is coming. I connected properly. Can any body explain how to go about it
Make sure TV is set to connecting input port, like VGA or S-Video. "New Display" should appear on laptop.
Acer has more troubleshooting answers with helpful pictures.
http://acer.custhelp.com/app/answers/detail/a_id/5989/kw/monitor/related/1
Oct 05, 2012 | Acer Aspire One PC Notebook
How do i connect aspire 5810t vista home pre 64b laptop to samsung lcd hdtv via hdmi
As long as you have an HDMI port on each hardware, just insert the HDMI cable into the ports and it should work fine.
Hope this helps
Mar 23, 2011 | Acer Aspire AS5530-5824 Laptop
I want to connect my Acer Aspire 5738 laptop to my LCD tv through HDMI cable. How can i do it? plz help me
THE ACER ASPIRE 5738 HAS AN HDMI PORT ON THE LEFT HAND SIDE. BUY AN HDMI LEAD AND CONNECT IT TO YOUR LAPTOP AND HDMI PORT ON YOUR LCD.SELECT HDMI AS INPUT ON YOUR LCD AND HEY PRESTO JOB DONE
Jan 03, 2011 | Acer Computers & Internet
How to connect an acer 3680 with windows xp to lcd tv
hi khan, its very easy to do this process , you can connect vga card just see this video
immortal4u_0.jpgGood luck ! if you think your problem solved don't forget to rate
Jan 01, 2011 | Acer Aspire 3680 Laptop
I HAVE CONNECTED MY ACER ASPIRE PC TO MY SAMSUNG LCDTV USING A VGA CABLE , THE PICTURE IS THERE , BUT I CANT GET ANY SOUND ?
The VGA cable only supplies video data to the LCD TV. Connect a sound cable from the audio out from the Acer PC to the audio input on the LCD TV to get sound from the LCD TV's speakers.
Dec 14, 2010 | Computers & Internet
How to connect/configure my acer aspire 4736Z to my LCD TV using the HDMI port/cable of my laptop? i tried to connect the HDMI cable but my laptop hangs...please help
for HDMI, I guess you just connect it with HDMI cable to your LCD TV, and use the FN+F5 or F6 to switch display from laptop's LCD to external. I think it should be the same way as using projector.
Sep 30, 2010 | Acer Computers & Internet
How do i connect acer apire one to lg lcd tv?
In order to connect your netbook to lcd tv your need a VGA or a HDMI cable( if your laptop has a hdmi port). Once you connect the netbook with the lcd tv you nned to use you tv remote to choose the input to pc or pc1 or HDMI depending the lcd tv. if you any futher questions please feel to ask.
Jul 08, 2010 | Acer Aspire One PC Notebook
hi if you laptop has the s-video you can connect that to the tv an it would work
Jan 10, 2009 | Televison & Video
How to connect my acer 5633 l/top to a lcd tv?
just the cable from lcd tv to laptop use function and key relevant to cahnge the screen
Jul 14, 2008 | Computers & Internet
Televison & Video Logo
36,417 people viewed this question
Top Televison & Video Experts
