Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
Sanborn Blackmax B3511 The part that has the gauge on it. This part is a black square about 1.5" square. Off of it is the handle to turn the air off and the hose connects to it. The black square is preventing the air to flow thru.
  • 90 Answers
I assume your are talking about the pressure regulator. if it won't adjust to raise and lower the outlet pressure it is broke. you will have to replace it with an in kind type.
Posted on Sep 01, 2010
Looking for manual for sanborn B51-A24-80V1 model
PDF]Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1
intrigante35hindu.strictlyyouth.org/rzsatzo_sanborn-black-max-5hp-air-...
Jul 16, 2015 - Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1 ... Black Max Portable Air Compressor - 5 gallon Item #: 81527 ' Model #: BS0880504 ...Compressor Manual: $4.95: Buy Now: B51-AT24-80V,B51-A24-80V1.
Aug 28, 2015 | Air Tools & Compressors
Century motor wiring diagram for 8-152863-01 motor
You can\'t run it on 220, but if you take only one of the 220 black wires and attach it to the black on the compressor you are feeding it 110. The problem will be that you have no neutral wire so you\'d have to use the ground of the 220 lead (green) as the neutral on the compressor (white). It\'ll run fine but it\'s not the right way and it can be a hazard. The white wire is neutral which is basically a ground wire from the electric company, the green is the ground wire in your building and it\'s there for safety so using it to power things is dangerous and probably illegal. I\'ve done it in a pinch, but wouldn\'t do it if at all avoidable. You may be able to get a transformer but you\'re probably better off running a 110 circuit or getting a 220 compressor.
Jul 29, 2014 | Sanborn 20 Gallon Horizontal Portable Air...
Plug wiring diagram for 240v outlet 7000w blackmax
Probably its similar to the wiring on page 31 of this manual (pdf page 28) of this manual, reference NGK-7000HE: http://www.electricgeneratorsdirect.com/manuals/NGK%20Generator%20Honda%20engine.pdf
Dec 25, 2009 | Electrical Supplies
What type of oil should i use on my sanborn blackmax air compressor?
You can use any 20 or 30 weight non-detergent motor oil in your compressor.
Oct 31, 2009 | Air Tools & Compressors
Where can i find blackmax parts
there are a few vendors on the web, or you could go to Coleman, who bought Sanborn, the mfg for BlackMax.
Oct 23, 2009 | Air Tools & Compressors
I have a Sanborn Black Max 22 gal. compressor Mod#B109BLR300-22SWC. The motor is a Magnetic/Century 3 H.P. 115v Model 8-165730-20 Ser# BF-532 15A-7.5 RPM 3450. It is missing the run and start capacitors....
Sanborn/Coleman was bought out by MAT Solutions. A website I found lists Sanborn/Coleman compressors and parts but it does not show your model number. It does say, however, to email them with your model number and they will be able to find your parts for you. I have included the link for you here: http://www.mastertoolrepair.com/colemansanborn-portable-parts-freedirect-drive-electric-c-271_35_172_178.html
Sep 10, 2009 | Air Tools & Compressors
Mercury 200 blackmax oil to fuel mix
Fuel oil ratios are,50/1. Eg.50 litres of fuel and 1 litre of oil. Hope this helps
Aug 29, 2009 | Furuno Navpilot 500 Designed for Use with...
Air compressor is sluggish and will not auto shut off
TO ME IT SOUNDS LIKE YOUR BIGGEST PROBLEM IS THE BELT. ITS INSIDE AND SURE ITS COLD BUT PROBABLY NOT THAT COLD. SPRAY CARB OR BRAKE CLEANER IN IT AND MIX WITH CHEAP OIL, RUN FOR SHORT PERIOD AND DRAIN. NOW PUT YOUR GOOD STUFF IN. VOLTAGE DROP CAN BE UP TO 10 V. READ VOLTAGE WHEN OFF AND WATCH IT WHEN IT COMES ON. MORE INTERESTED IN THE GAUGE OF POWER CORD. 15 AMPS ISNT ALOT AND A SHORT 12 GAUGE CORD SHOULD BE FINE. AMPS WILL PROBABLY SPIKE UP TO 40-50 DURING START-UP. THE AIR PRESSURE PUSHS ON A DIAPHRAGM WHICH LIFTS A SHAFT THAT MOVES THE POINTS BACK AND FORTH. YOU CAN WATCH THE POINTS OPEN AND CLOSE WHILE WATCHING THE AIR GAUGE. BELT SHOULD HAVE 1/2" DEFLECTION.
Mar 26, 2009 | Air Tools & Compressors
Need connecting rod for Sanborn type ''143'' air compressor pump
if you cant find the part ,just get a new compressor that is about the same as the old one.Not a complete unit,just the compressor.Northern tools sells many types of replacement units
Dec 14, 2008 | Air Tools & Compressors
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
449 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
