Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Kodak 5500 will not scan comes up with error code and says that JIT debugging must be enabled
  • Anonymous Jul 05, 2008
    kodak esp3 all in one printer will not scan comes up with error code.
    Unhandled exception has occurred in your application. MSG_OPENDS failed with result 1 & condition code 5.
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.Exception: MSG_OPENDS failed with result 1 and condition code 5.
    at Twain.Scanner.OpenSource(String source)
    at Kodak.Utilities.Scanning.Scan..ctor(IntPtr handle, String source)
    at KodakAiO.ScanForm.ScanForm_Load(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.ContainerControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.42 (RTM.050727-4200)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    AiOHomeCenter
    Assembly Version: 2.2.773.0
    Win32 Version: 2.2.773.0
    CodeBase: file:///C:/Program%20Files/Kodak/printer/center/AiOHomeCenter.exe
    System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Localization
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Localization/2.2.773.0__5cc7ad8abd921325/Localization.dll
    System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    Kodak.Diagnostics
    CodeBase: file:///C:/Program%20Files/Kodak/printer/center/Kodak.Diagnostics.DLL
    Kodak.Utilities
    CodeBase: file:///C:/Program%20Files/Kodak/printer/center/Kodak.Utilities.DLL
    Kodak.Configuration
    CodeBase: file:///C:/Program%20Files/Kodak/printer/center/Kodak.Configuration.DLL
    Kodak.Controls
    CodeBase: file:///C:/Program%20Files/Kodak/printer/center/Kodak.Controls.DLL
    System.Deployment
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
    Kodak.Hardware
    CodeBase: file:///C:/Program%20Files/Kodak/printer/center/Kodak.Hardware.DLL
    Interop.WIA
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/Kodak/printer/center/Interop.WIA.DLL
    CustomMarshalers
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/CustomMarshalers/2.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
    Kodak.Automation
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Kodak.Automation/2.2.773.0__5cc7ad8abd921325/Kodak.Automation.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    Kodak.Controls.Exhale
    CodeBase: file:///C:/Program%20Files/Kodak/printer/center/Kodak.Controls.Exhale.DLL
    Accessibility
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    FixItCenterControl
    CodeBase: file:///C:/Program%20Files/Kodak/printer/center/FixItCenterControl.DLL
    System.Data
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
    Kodak.Imaging
    CodeBase: file:///C:/Program%20Files/Kodak/printer/center/Kodak.Imaging.DLL
    Twain
    Win32 Version: 2,2,773,0
    CodeBase: file:///C:/Program%20Files/Kodak/printer/center/Twain.DLL
    msvcm80
    Assembly Version: 8.0.50727.762
    Win32 Version: 8.00.50727.762
    CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700/msvcm80.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
  • Hokapontas Sep 09, 2008
    I'm having the same problem and copied the same post, happens when I try to scan and do anything basically with the Easyshare software. Called Kodak, they said they'd get their research team on it and get back to me, I'm pretty sure they're never going to call me back.
Remove all of Kodak software, remove it completely.
Go to control panel, open add printer, find Kodak, the 5500 will not show
on right side. Be sure to select the plug and play option, windows asks if you want
it to find the software, select yes, windows pretty much takes over from there. If you
want to scan add scanner/camera in control panel and pretty much do the same thing. You
will lose some of the special options but at least it works. Good luck!!!!
Posted on Dec 16, 2008
    Problem Solver:
  • 15 Answers
Try updating java and let me know. Also, go to add/remove programs and repair the MS .NEt Framework 2.0. Only 2.0 You may have MS .Net Framework 1.1 & 3.0. Do not touch those.
Posted on Jun 11, 2008
Jit debugger error
jrotten65,
This error only pertains to Microsoft Visual Studio. Depending on which version of the software you are using, follow the links below.
Try updating to the newest release of Visual Studio
http://www.microsoft.com/express/
or use the Debugging Tools for Windows as an alternative
http://msdn.microsoft.com/en-us/windows/hardware/gg463009.aspx
The Registry key HKLM\SOFTWARE\Microsoft\.NETFramework\DbgJITDebugLaunchSetting is set to 0x00000010 when JIT debugging is enabled.
I hope this helps.
Nov 04, 2012 | Dell Computers & Internet
Jit debugging problem. I have tried disabling the script debugging on internet and other. This didn't solve the problem. Any other suggestions ?
I was just reading the thread! Kinda hilarious though.
JIT is used to catch real time errors especially run-time. It is very useful for developers. To catch un handled exceptions.
Jit comes as a part of Visual Studio. If you do not know how to manage Jit its better not to install Visual Studio (no skills to manage it will give you lots of trouble). Just the programing skills does not make a good developer. Well its not a fault of VS developer team or Bill Gates. Doh!
Jit will be invoked if enabled by Visual studio, instead of Dr Watson. If programs crash the crash handlers will be invoked and you will see Dr.Watson process running in the background. It will call dumprep and will create error logs; Errors will be logged in Event Viewers as well. Even a simple failure will be handled and Jit will be invoked. So programs will begin to crash while they run or install.
Some developers set programs to use Jit and Jit will be enabled instead of Dr.Watson. Dr.Watson will be invoked in serious errors however. Its obvious. But specially if you have installed Visual Studio, you will be using JIT as well. JiT overrides the Dr.Watson Program. But you can reverse it back using two methods.
Its a third party piece however. I wonder why these MSDN people do not know how to provide a complete answer. Each and every person does not understand Administration of programs. So its their responsibility. That is a laughing matter though. But people will be pissed off. Can't blame them either. Some of them are not familiar with regedit tools. So the answers have to be flexible and complete.
The bad behavior of JIT is it will suspend the program an once when an error occur. You will never be allowed to run further. So its kinda piece of ****. It also has security issues with it.
Unfortunately if a program Invokes JIT intensionally its not possible to reverse the process.
Stop JIT while you have Visual Studio installed (Its a stupid thing to uninstall it without removing JIT. No way!)
How this thing will be enabled?
  1. Open VS:
  2. Go to Tools and then Options.
  3. In the Options Dialog box Double click Debugging and then click JIT
  4. Enabling options:
  • Manage
  • Native
  • Script
Click on OK.
This sets the Registry key and will start JIT. So do the Revers to Disable it.
You have to Disable the Keys. Method one:
  1. Click on Start Menu and Type Run (for P Hit Run box)
  2. Type in regedit and hit Enter
  3. Expand the Keys to located the place
  4. HKLM\Software\Microsoft\Windows NT\CurrentVersion\AeDebug\Debugger is one location.
  5. HKLM\Software\Microsoft\.NETFramework\DbgManagedDebugger
  6. Delete these keys. Or set the Auto key's value to 1.
  7. On a 64bit system the paths will be: HKLM\Software\Wow6432Node\Microsoft\...
  8. You may need to reboot the system as well.
Method two: Enable Dr.Watson using an alternative method:
  • Get a Command Window (Command Prompt)
  • Type drwtsn -i and
  • Hit enter
If you were using a third party debugger read this Microsoft Support
Next step
Open Start>Control Panels>Internet Options: Advanced and activate (check box)
  • Disable Script Debugging (Internet Explorer)
  • Disable Script Debuggung (Other)
If you have enabled Server Side Script Debugging the pages will freeze if an error occurs. Read the enabling procedure. Steps to enable debugging portion. Do the Reverse to disable it.
For Script Debuggers: Here is how you enable the JIT:
  • Click on Options then Tools
  • Click on Debugger
  • Select JIT debugger and attach to programs running on this machine
  • So now you know how it happened. Do the reverse to disable it!
Using third party tools and software may enable this tool. If you detect one you have to avoid using it. Just posted this in the MSDN thread as well.
Please rate the answer as well! Feel free to contact if you have further issues.
Thanks for using Fixya! -Lasitha
Jul 09, 2010 | Computers & Internet
Can i make my kodak easyshare 5500 wireless? or is it not able to go wireless?
Well, yes, to some extent.
This printer will accept a Kodak Bluetooth adapter which plugs into the USB port in the front of the printer. You can then send pictures from Bluetooth enable products such as PDA's, mobile phone, and digital cameras.
You can refer to Page 41 in the manual.
Kodak 5500 Manual
Thanks for using Fixya.
Jan 20, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
Error code 1-2010 I cannot scan. Something to do with JIT Debugging not enabled.
If you'd like to resolve this isue just download and run the Kodak Clear Utility from www.kodak.com/go/clear.
Once done, download and install the lastest Kodak Home Centre Software from www.kodak.com/go/drivers. This should sort it out for you
Oct 19, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Can seem to scan in a photo on my all in one printer...kodak 5100. am i doing something wrng HELP
Try checking for printer error indicated by flashing light, printer will not scan if it has an error
Oct 05, 2009 | Kodak 5500 ALL-IN-ONE PRINTER
I cant scan from my kodak all in one printerto my
Try system restore to a day before your problems started and then you should be right.
Jun 03, 2009 | Kodak 5500 ALL-IN-ONE PRINTER
Will not scan kodak easyshare 5100
For WINDOWS VISTA/XP Operating Systems:
  1. Go to:
    • C:>Windows>twain_32>Kodak>Kds_aio5000
    • C:>Windows>twain_32>Kodak>Kds_aioesp
  2. Confirm the folders Kds_aio5000 and Kds_aioesp are available in C:>Windows/twain_32/Kodak.
    NOTE: If these folders are missing, the following error codes will be generated:
    • 1-2036 when scanning
    • 1-2037 when printing
If the error condition continues:
  1. Right-click the KODAK AiO Home Center icon.
  2. Click Properties, then select the Compatibility tab.
  3. Clear all checked boxes.
  4. Click Apply, then OK.
  5. Scan a document from the Home Center.
Jun 03, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
JIT debugging
Dear rmakrishnan2,
JIT stands for Just In Time and I believe it's some sort of compiler and sounds like your .NET infrastructure may need to to be reinstalled. Try the Add/Remove programs control panel to Repair or Reinstall your .NET infrastructure.
Jul 29, 2008 | IBM ThinkPad T30 2366 Notebook
Go to Control Panel
Double Click on Printers and Other Hardware
Double Click on Scanners and Cameras
Double Click on Kodak 5100 AiO
Click Next
Read and follow directions
It ain't rocket science
Feb 08, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
355 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
