Win ME How can I turn off that annoying error reporting with Internet Explorer 6 in WinME?
    Problem Solver:
  • 35 Answers
In Registry Editor (Regedit.exe), create a DWORD value called IEWatsonEnabled and set it to 0 in the following registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Main
For more info, see this MSKB article: http://support.microsoft.com/default.aspx?scid=kb;EN-US;q276550
Posted on May 09, 2008
After done the disable error reporting, the error is not showing, but internet explorer will automaticaly closed..... what is the reason ?
Hi Kamaleshan,
You need to reset the internet explorer and the issue would be fixed.
Open the new internet explorer page and click on tools.
Select internet option from the drop down.
Select advaced from the pop up as shown in the picture above.
Click on reset and restart the internet explorer.
hope it helps.
Cheers!!
Dec 30, 2010 | Microsoft Windows XP Professional
Tip
For All XP user Don't Use IE 7.0 & higher version
Applicable for all window XP (all edition, all PCs and Laptops)
If you are getting trouble after the updates of internet explorer..
Then I would suggest you to Roll Back it to the original Internet Explorer (i.e Internet Explorer version 6.0)
Which come up with Installation of Win Xp with Service Pack 2.
Bad Effect due to IE 7.0 or higher version:
Screen hang up, internet freezes abruptly, prominent windows crashes anytime.
So to stop these problems, better to run with lower and safe version of IE:
To remove Internet Explorer 7 from your PC use the following methods
Method 1: Use "Add or Remove Programs" to uninstall Internet Explorer 7
Step 1: Use "Add or Remove Programs" to uninstall Internet Explorer 7
a. Click Start, and then click Run.
b In the Open box, type appwiz.cpl, and then click OK.
c. In the list of programs, click Windows Internet Explorer 7, and then click Remove.
d. Follow the wizard instructions to uninstall Internet Explorer 7. Also remove if any updates under this entry found.
If you cannot uninstall Internet Explorer 7 by using this method, try Method 2.
Method 2: Use Spuninst.exe to uninstall Internet Explorer 7
Run Spuninst.exe to uninstall Internet Explorer 7
b. In the Open box, type %windir%\ie7\spuninst\spuninst.exe, and then click OK.
c. Follow the wizard instructions to uninstall Internet Explorer 7.
After you uninstall Internet Explorer 7, double-click the Internet Explorer icon to verify that Internet Explorer 6 is restored.
This will bring up you to run Internet explorer as it come up with the installation kit, which is safe and reliable.
Have Nice Surfing!!
Ellin
on Oct 14, 2008 | Microsoft Windows XP Home Edition
When I click on the browser it does not give any respone.
This may be due to a malware Browser Helper Object which causes Internet Explorer process to terminate. If you see the Error-Reporting dialog, click "to see what data this report contains" and identify the Module Name causing this error. In most cases, it may be the malware DLL; in which case, reinstalling Internet Explorer may not help. To test with: Disable third-party browser extensions in Internet Explorer using this REG or following these steps:
1. Click Start, point to Settings, and then click Control Panel.
2. Double-click Internet Options.
3. Click the Advanced tab.
4. Under Browsing, clear the Enable third-party browser extensions (requires restart) check box.
5. Restart Internet Explorer.
Try to open Internet Explorer again. If you are able to open Internet Explorer, then, the problem was caused by a malware BHO. Disabling third-party browser extensions is just a workaround and does not eliminate the root of the problem.
Dec 01, 2010 | Computers & Internet
Good day sir. problem with internet explorer, error signature AppName: iexplorer.exe AppVer: 7.0.5730.13 ModName: tbzyn1.dl ModVer: 5.72.2 Offset: 0014ba56 every time i open the internet explorer a message...
Have any toolbars or new sofware been added recently? If so and you are using Win XP you may want to try a system restore to a previous point before the changes were made or uninstall the toolbars completely. Also disabled all Pop-Up blockers to see if that has any effect.clean up ur registry using reginout
Dec 01, 2010 | Microsoft Windows XP Professional
Ie script error
Follow below mentioned steps-
1. Open Internet Explorer.
2. Click on tools.
3. Click on Advanced.
4. Click on reset.
5. Click on Apply and then OK.
6. Open Internet Explorer again.
Mar 23, 2010 | Microsoft Windows XP Professional With...
While opening orkut the following error occurs line 30 char 18271 error : exception thrown & not cought code: 0 url:http:/www.orkut.co.in/main please resolve
for win Xp press windos key + r , run box would appear type appwiz.cpl in the box and press enter, add or remove programs window will pop up select windwos componenet fron the left hand side and uncheck internet explorer and once process is complete check it again and restart the system, this is a process for reinstalling internet explorer in windwos xp once reinstallation is done you should not face this error again.
for vista and win 7
go to control pannel then internet options go in advance tab and click on reset tab , this would resolve the issue.
Mar 20, 2010 | Microsoft Computers & Internet
I am missing the listing of an previous Security update for windows Internet Explorer KB938127 installed on 20/02/2008. Operating system in Windows XP home edition service pack 3 with IE Version 7. Since...
I downloaded the Internet Explorer 7 installation from http://www.microsoft.com/downloads/details.aspx?familyid=9AE91EBE-3385-447C-8A30-081805B2F90B&displaylang=en and let it finish then rebooted again.
Opened Microsoft Update and it again found available updates
KB953838 and KB938127 and both installed successfully.
Jan 11, 2010 | Microsoft Windows XP Home Edition
I am using win XP and internet explorer. I am
Have you tried one photo at a time, sounds like you have an old PC or slow connection.
Jan 03, 2010 | Microsoft Windows XP Professional for PC
Windows int. explorer keeps closing saying java script error
This article offers five methods that you can try to resolve the issue, and also presents some advanced troubleshooting tips that you can try. Try each method in the order presented until you resolve the issue. If one method does not work, try the next.
This article is intended for a beginning to intermediate computer user. You may find it easier to follow the steps if you print this article first.
Method 1: Disable script debugging loadTOCNode(3, 'whattotry'); If the only sign of a problem is the error message, and Web sites are working, you can probably ignore the error. Also, if the problem only happens on one or two Web pages, it might be a problem with those pages. If you decide to ignore the errors, you can disable script debugging.
Note If this problem occurs on more than one or two sites, do not disable script debugging. Go to method 2 now.
To turn off the Scripting Debugger in Internet Explorer 6, follow these steps:
  1. On the Tools menu, click Internet Options.
  2. On the Advanced tab, click to select the Disable script debugging check box. and then click OK .
To turn off notification about every script error in Internet Explorer 7, follow these steps:
  2. On the Advanced tab, click to clear the Display a notification about every script error check box, and then click OK.
Method 2: Test a Web page from another user account, another browser, and another computer loadTOCNode(3, 'whattotry'); Use another user account, another browser, or another computer to view the Web pages that triggered a script error to determine whether the problem persists. If the script error persists, there may be a problem with the way the Web page is written. You can probably ignore the error and disable script debugging as described in method 1.
If the script error does not occur when you view the Web page from another user account, browser, or computer, the problem may be caused by files or by settings on your computer. Go to method 3 to continue to troubleshoot.
Method 3: Verify that Active Scripting, ActiveX, and Java are not being blocked by Internet Explorer loadTOCNode(3, 'whattotry'); Active scripting, ActiveX, and Java are all involved in shaping the way information displays on a Web page. If these are blocked on your computer, it may disrupt the display of the Web page. Reset the Internet Explorer security settings to make sure these are not blocked. To do this, follow these steps:
  1. Start Internet Explorer.
  2. On the Tools menu, click Internet Options.
  3. In the Internet Options dialog box, click the Security tab.
  4. Click Default Level.
  5. Click OK.
Note ActiveX controls and Java programs are turned off at the High security level in Internet Explorer.
Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to Method 4.
Method 4: Remove all the temporary Internet-related files loadTOCNode(3, 'whattotry'); Every time that you open a browser to view a Web page, your computer stores a local copy of that Web page in a temporary file. If the size of the temporary Internet files folder becomes too large, some display problems may occur when you open Web pages. Periodically clearing the folder might help resolve the issue.
To remove all the temporary Internet-related files from your computer when you use Internet Explorer 6, follow these steps:
  3. Click the General tab.
  4. Under Temporary Internet files, click Settings.
  5. Click Delete Files, and then click OK.
  6. Click Delete Cookies, and then click OK.
  7. Under History, click Clear History, and then click Yes.
  8. Click OK.
To remove all the temporary Internet-related files from your computer when you use Internet Explorer 7, follow these steps:
  4. Under Browsing History, click Delete, and when you are prompted, click Yes to confirm.
  5. In the Delete Browsing History dialog box, under Temporary Internet Files, click Delete Files, and when you are prompted, click Yes to confirm.
  6. Under Cookies, click Delete Cookies, and when you are prompted, click Yes to confirm.
  7. Under History, click Delete History, and when you are prompted, click Yes to confirm.
  8. Click Close, and then click OK to close the Internet Options dialog box.
Try to open a Web page where you previously received a scripting error. If you do not receive the error, the issue is resolved. If the issue persists, go to method 5.
Method 5: Install the latest service pack and software updates for Internet Explorer 6 or Internet Explorer 7 loadTOCNode(3, 'whattotry'); If you do not have the latest service pack or software upgrades for Internet Explorer 6 or 7, download and install them. They may contain updates that can help resolve the issue.
To install Internet Explorer 6 Service Pack 1, visit the following Microsoft Web site:
http://www.microsoft.com/downloads/details.aspx?FamilyID=1e1550cb-5e5d-48f5-b02b-20b602228de6&displaylang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=1e1550cb-5e5d-48f5-b02b-20b602228de6&displaylang=en) Note Internet Explorer 6 Service Pack 1 is recommended for systems that are running versions of Windows earlier than Windows XP.
To install the most current software updates for Internet Explorer 6 or for Internet Explorer 7, visit the following Microsoft Web site:
http://windowsupdate.microsoft.com (http://windowsupdate.microsoft.com) Please leave me comment, if you need further assistance Thanks for using Fixya Please rate this solution Rnj VinodKumar
Dec 15, 2009 | Sun Java Desktop System
Internet Explorer
I would go into control panel, system, device drivers and uninstall your modem. Reboot the computer and let windows re-install it.
Apr 08, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
