Acer Ferrari 3400MLi Please advise when adding RAM memory to both positions. In the first position it is a matter of unscrewing 2 screws and removing the plate. In the second position - how do you access it? Must you remove the complete base plate? Or is there another way?
  • 23 Answers
The second memory module is under the keyboard and it must be removed to access it.
Posted on May 10, 2008
How do I fit extra memory in my acer aspire z series
If there is no Random Access Memory (RAM) compartment cover on the rear or underside of this computer, then, as is common with All-In-One (AIO) computers, a degree of disassembly is required in order to access the RAM Module slots internally.
If so, unless you are experienced at the disassembly and internal repair or mopdification of AIOs, Liquid Crystal Display (LCD) or Light Emitting Diode (LED) Personal Computer (PC) Monitors and LCD or LED Televisions (TVs), my advice would be to take this computer in to have the RAM upgrade performed by an authorized Acer Service Center.
The internal areas of AIOs, LCD, LED PC Monitors and LCD or LED TVs are u highly unsafe and inexperienced user-unfriendly working environments because such devices contain Electrolytic Capacitors (e-caps) that are storage devices capable of storing dangerous and even lethal charges, even when the device is completely disconnected from the mains electricity. Some capacitors can store charges as high as several tens of thousands of volts.
The aim would be to remove the back panel.
Often (but not always) with AIOs, LCD, LED PC Monitors and LCD or LED TVs, the key to removing the back cover lies in first unscrewing and removing the stand.
Look out for hidden screws, particularly deep-set screws, some of which might even be completely obscured by a warranty sticker or other label, meaning that upgrading the RAM in this computer within its warranty period might invalidate the warranty unless the upgrade is performed by an authorized Acer Service Center.
When the rear cover is removed (some additional internal panels might need to also be unscrewed/unclipped and removed), you should have access to the four RAM Module slots. Two slots should be free and the remaining two occupied, each containing a single (2048 Megabytes) otherwise referred to as 2 Gigabyte (Gb) RAM Module, because the standard RAM specification of this computer is 4Gb. The maximum specified RAM for this computer is 8Gb, meaning that either one or two 2Gb Modules can be added during a RAM upgrade.
The specifications of the RAM Modules for this computer are:
240 Pin 1.8v DDR3 PC3-1066 Non-ECC Dimm (240 contact elements, 1.8 volt, 1066 GigaHertz Oscillation Cycle Clock Speed, 3rd Generation Double Data Rate, Non Error Checking and Correction, Dual Inline Memory Module).
Nov 30, 2011 | Acer Computers & Internet
I want to fit some extra memory to my Acer Aspire 9300. Which door do I open on the bottom of the notebook. thanks.
You can adding RAM to your Acer Laptop by following the below steps.
1 . Unplug your laptop from the AC power source and remove the battery.
2 . By unplugging the power connector you will be safe from shock.
3 . Locate the memory access door for the main memory module. It should be on the back of your computer.
4 . Unscrew the memory access door and remove it.
5 . Remove the RAM module by applying gentle outward pressure to the securing clips on either side of the RAM module until they release.
6 . Rotate the RAM module upward to a 45 degree angle and slide it out of the slot.
7 . Align the new RAM module with the tab in the connector slot.
8 . Slide it firmly into place and gently rotate it downward until it clicks into place.
9 . Replace the memory access door.
10 . Replace the battery and power up the computer. It should recognize the added memory and reconfigure itself for use.
Hope the above information will be helpful to you.
Thanks for using Fixya.
Nov 23, 2010 | Acer Aspire 9300 Notebook
I want to install memory and after taking off the two screws, the cover does not want to come off and I am concerned that I will break the tabs or something.
After removing the battery, get a suitable screwdriver (normally the philips head screwdriver) and unscrew the screws on the memory module(RAM) section.Push the cover back away from the side where the screws were. When you open the lid covering the section, you will see the original RAM installed inside. Remove the RAM by lightly pushing out the side panels. The RAM will pop up and in a slanted position (around 45 degree) and then proceed to pull the RAM out.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 17, 2010 | Acer Aspire 5742Z-4200 Notebook
Change RAM in Acer Aspire 5315
hi
  • Step 2 Protect your computer from static electricity by grounding yourself with an ESD wrist strap or through another grounding method.
  • Step 3 Locate the memory access door for the main memory module. It should be on the back of your computer.
  • Step 4 Unscrew the memory access door and remove it.
  • Step 5 Remove the RAM module by applying gentle outward pressure to the securing clips on either side of the RAM module until they release.
  • Step 6 Rotate the RAM module upward to a 45 degree angle and slide it out of the slot.
  • Step 7 Align the new RAM module with the tab in the connector slot.
  • Step 8 Slide it firmly into place and gently rotate it downward until it clicks into place.
  • Step 9 Replace the memory access door.
  • Step 10 Replace the battery and power up the computer. It should recognize the added memory and reconfigure itself for use
  • Jun 01, 2010 | Acer Aspire 5315 Notebook
    Add more ram
    hi-
    To add ram - look on the back of the lap top. You will see some screws that are holding down a little door. There may be two of these. Remove the screws on the ram cover and remove ram cover
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ram slots are stacked. you have to remove the top one first.
    1- press the buttons on the sides of the ram chip, and then it will pop up and towards you.
    2- 2- pull this ram upwards and out
    3- from there, you can take out the other chip, if there is one, or you can start installing.
    4- installing the new ram chips is just as easy
    5- line up the slots in the chip, then push it in as far as you can without breaking it.
    6- then push it down so that you hear it click on both sides, and doesn't budge.
    7- Repeat using the top chip.
    This should do it –
    I hope it helps- please rate me – thanks
    G
    Mar 18, 2010 | Acer Aspire 9500 Notebook
    Wats the most ram for acer 3680 notebook
    The most RAM (Random Access Memory) you can ad to a Acer Aspire 3680 Notebook is 2 GB. There is only 2 slots for RAM so I would get two 1 GB RAM sticks for a total of 50$.
    Shouldn't be too hard to replace, just flip it over and unscrew the compartment.
    Good luck,
    Brandonmxb
    Dec 11, 2009 | Acer Computers & Internet
    Difficulty locating memory chips in my Acer Aspire L310
    visit youtube web,, there so many video how to install ram or laptop desktop hardware installation
    Jan 08, 2009 | Acer Aspire L310 (ASL310UD631A) PC...
    How to put extra memory in Lenovo T60 laptop
    Ok the RAM location is actually underneath the touch pad on the top of your keyboard. However, to get to the memory area where you can add/remove RAM cards you need to do the following:
    STEP 1) On the botton the latop you should see 4 screws that have a "memory chip" ICON. These are the 4 screws you want to take out. (important note: my T60 has 4 screws with this icon, yours might have 5). Please the screws somewhere secure so they are not lost.
    STEP 2) After you take out the screws noted in step 1. Flip your laptop and open it up as if you were going to type something.
    On each side just below the keys pull up gently and the botton portion that has the touch pad will come up. You want to pull it back towards you. You won't be able to complete remove it away from the laptop, because there's a ribbon cable connecting the touch pad. So just move the piece back toward you out of the way (in essence peeling it back toward you).
    STEP 3) You should now see the RAM card(s) they will have a bracket mechanism on each side of the RAM card, push them outward to unlock the RAM card (if your removing.
    STEP 4) If your ADDING RAM. Evaluate if you need to remove existing cards or not. To install RAM you insert the new card in the slot, then push it down and it should snap int place.
    STEP 5) Place the touch pad plate back into position and push it to snap down.
    STEP 5) Close laptop cover, flip over and insert the screws back into their positions.
    Jun 17, 2008 | Lenovo Thinkpad T60 Notebook
    No display jus beeps
    Your memory chips must be had i that sounds like a chip problem under the laptop secured by two screws will be where the chip lodged pull it out and re-enter it might go it might not but that your problem I am sure of it.
    Oct 10, 2007 | Acer Ferrari 4000 Notebook
    Replacing RAM chip in a acer aspire 3000
    I found the user manual at http://www.synapsenow.com/synapse/data/7117/documents/AS3000-5000_UG_ENG.pdf Page 63 of the acer user manual listed these steps for changing the memory: "1 Turn off the computer, unplug the AC adaptor (if connected) and remove the battery pack. Then turn the computer over to access its base. 2 Remove the screws from the memory cover; then lift up and remove the memory cover. 3 (a) Insert the memory module diagonally into the slot, then (b) gently press it down until it clicks into place. 4 Replace the memory cover and secure it with the screw. 5 Reinstall the battery pack, and reconnect the AC adaptor. 6 Turn on the computer. The computer automatically detects and reconfigures the total memory"
    Sep 02, 2007 | Acer Aspire 3000 Notebook
    Computers & Internet Logo
    32 people viewed this question
    David Payne
    David Payne
