Question about Nokia 6300 Cellular Phone
Nokia 6300 washed out
Hi
my nokia 6300 ended up in the washing on a wash, i have dried it out and everything is working apart from ive got no signal when my sim card is in can it be fixed???
  • 3 Answers
Unfortunately no....depending on the water damage that had occured. It would have been quite lucky if the phone actually worked. and if it did, other aspcts of the device may work now but fail later. No one part can be identified for repair because water can get into EVERY component. Making repar an expensive option. Replacement is the only recommendation
Posted on May 12, 2008
Drum goes round, only cold air circulating and no heat to dry washing, machine is constantly bleeping and signalling end of drying cycle
If you pull the panels off you should find the tech sheet to help diagnose your machine. But in you case sounds like it need to be taken apart and cleaned and check the limit switches.
Jan 15, 2014 | AEG T58840 Dryer Electric
I put my remote control in my drink can I dry it out?
Possibly. don't press any buttons!..take out the batteries..take it apart.(this make take a bit, but check for small screws in the battery compartment, then squeeze the case at the "seam" and work it apart.. wash the case with warm soapy water..take circuit board (if it isn't fried) and wash with an electronic spray solvent or high grade alcohol that evaporates quickly...wash the rubbery button pad lightly with soapy water , then high grade alcohol...let everything air dry or lightly dry with hair dryer (set on cool setting)...reassemble and cross your fingers.
this has worked in the past, but all night in cordial,,,i can't make any promises.
Feb 21, 2013 | Sanyo Televison & Video
Hi, My Admiral 560 heavy duty washing machine has stopped washing and won't spin dry iether , it fills empties and gose through the motions of everything , but will not wash or spinn dry, what is that...
I had a similar problem with a maytag and it was the lid switch. I put a new one in and it worked just fine. Hope this works for you. Cost about 10 dollars.
Dec 24, 2010 | Admiral Washing Machines
Signal problem
Dear customer
I will get vary happy to help u. If u are a Technician then open ur mobile handset by T-6 screw driver and firstly wash ur network antina and IC areas by a toothbrash with PCB cleaner.Check the network connecter make a jumper from network connecter to connecter pins by micro soldering IRON and give some hot air to network IC with pest.If u are not a technician then its better to go ur nearest NOKIA care center.If u are saticfied withmy information then please vote me. Thank you for your visit.
May 24, 2010 | Nokia 6300 Cellular Phone
Maytag 6300 won't agitate durring wash cycle
HI. this is usually caused by a faulty drive assembly(agitator gear components and clutch malfunction).
I recommend replacing the agitator components by purchasing a Agitator replacement kit. and, replace the clutch assembly as well. this will fix this issue.
Jun 17, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Washed my nokia 6300
try to use a cool hair dryer not hot maybe it will work
Jun 06, 2009 | Nokia 6300 Cellular Phone
Water remains under rubber seal. Water too high in bleach dispen.
Did you try taking the dispenser tray apart and cleaning it? The exit ports tend to clog over time. Best thing I have found is to remove the tray at the end of wash day, rinse it out, dry it and put it only partially in the machine, thereby allowing air circulation. Some water will always remain at the end of the wash cycle...inherent in the design.
As for the gasket, you'll have to wipe it down at the end of wash day and leave the door open to dry everything out. I leave mine open all the time.
May 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Cell won't charge????
No, I dare say your phone has charked it, However it could be the battery that is water soaked, Try using another battery before calling the phone a write off
Jul 13, 2008 | Nokia 6300 Cellular Phone
Why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
Oct 28, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Nokia 6300 Cellular Phone Logo
135 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
