My compressor wont kick on since lastnite. Whats wrong?
  • 674 Answers
Is this a split system or a wall unit. If it is a split system, is the outdoor fan running? If it isn't, check the fuses or disconnect first. If that's good, set the thermostat to make the air come on then remove the cover where the power goes into the outside unit and see if the contactor is pulled in. Next, check voltage on the primary and secondary side of the contactor and make sure it is getting power. If the outdoor fan is running then the problem may be just your capacitor. You can check it with a multimeter or take it to a heating and air supply and they can check it. If the capacitor is good then check the compressor motor windings. Let me know what you find and I can give more suggestions. There are a lot of possibilites but these are some common ones.
Posted on Aug 31, 2010
Car cutting off
Need more detail, are you saying your A/C stops working all together or you are hearing the compressor kick off and on?
Apr 08, 2014 | 1993 Ford Taurus
Electrolux ere 3500 problem
Ok you have a faulty relay on the compressor very easily fixed, tell your repair man whats wrong then they cant rip you off.
Nov 16, 2013 | Refrigerators
Fan will come on but compressor wont kick in on wall unit ac
The start capacitor on the compressor is bad. Replace it and the compressor will run.
Jun 30, 2013 | Heating & Cooling
Goodman AC inside handler is running so is outside fan but when compressor tries to kick on (lights dim and you can hear it try to start up) it immediately shuts back off, whats wrong?
It sounds like you need to install what is commonly called a "hard start kit." This is merely a start capacitor that gives your compressor extra punch to get it going. The compressor is trying to start but cannot before it draws too much amperage. A hard start kit should alleviate this problem.
If my answer helped you please take the time to write a short testimonial.
Aug 04, 2011 | Heating & Cooling
Airconditioner wont work
this could be as simple as needing a charge. mobile air conditioner systems leak freon. It is just the nature of the beast. It is attached to the motor which moves and the car body which is fixed. It doesn't have a chance. there is a low pressure switch that protects the compressor if you lose too much freon and that could be why the compressor is not coming on. Freon cost a shop a little over $3 a pound when bought in bulk and labor is about a half hour. Look for a small independant that can do a/c for the best price. If this helps please reply and good luck
Apr 27, 2010 | 2003 Hyundai Santa Fe
AC Compressor will not engage.
Inner rim is the compressor. If it wont turn youre compressor is bad.
Apr 16, 2010 | 2000 Saturn L-Series
Bike appears seazed,was ok when i parked it in garage lastnite.but now the kick start is stuck it wont start in nuteral & when i attempt to push start it in 2nd it is jammed
take spark plugs out and try turning engine over by putting it top gear and turn rear wheel by hand if it still doesnt turn then it mite be a dropped valve which will mean an engine top end strip down.
Apr 04, 2010 | 2005 Daelim Daystar
I have a craftsman air compressor that wont buld
Hi there is a air leak or the safety valve is letting by some thing on the valveseting passing air ?
Jan 22, 2010 | Plumbing
Fridge not cooling,compressor wont kick in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fsdgj
Jun 02, 2009 | Maytag MZD2665HE Stainless Steel Side by...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
