The battery is not charging betwwen 60% and 100% it charges till 59% and then it become 100% with out charging from 69% to 100%
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 88 Answers
Faulty battery, needs replacing sounds like some of the cells have died.
Posted on Aug 31, 2010
How does the charging system on a 1969 Honda 325 cc motorcycle work to keep engine running?
I think you mean a 69 CB350. It sounds like you have a bad battery since the battery charger won't charge it.
On this bike there is an alternator and rectifier that combine to charge the battery whenever the engine runs. If the battery won't hold a charge, the charging system wont work.
Replace the battery.
Sep 26, 2014 | Motorcycles
Nikon d300s
Refer to everything that has to do with battery. I wonder if you can see anything on the control panel. If nothing is there you battery is dead for sure.
If you can see symbols on the control panel, it could be your on on / off switch is defect.
The Battery
Check the battery level be focusing the camera and replace or charge the battery if necessary. Do not continue charging once the battery is fully charged as this will result in reduced battery performance. Whenever possible, carry a fully charged spare battery when taking pictures on important occasions.
Do not use the battery at ambient temperatures below 0 C (32 F) or above 40 C (104 F).
Charge the battery indoors with an ambient temperature of 5 C to 35 C (41 F to 95 F) before use.
Note that the battery may become hot during use; wait for the battery to cool before charging.
Failure to observe these precautions could damage the battery, impair its performance, or prevent it from charging normally.
On cold days, the capacity of batteries tends to decrease. Be sure that the battery is fully charged before heading outside to take pictures in cold weather. Keep spare batteries in a warm place and exchange as necessary. Once warmed, a cold battery may recover some of its charge.
Dirt on the battery terminals can prevent the camera from functioning. Should the battery terminals become dirty, wipe them off with a clean, dry cloth before use.
If the battery will not be used for some time, insert it in the camera and completely exhaust it before removing it for storage. The battery should be stored in a cool location with an ambient temperature of 15 C to 25 C (59 F to 77 F). Do not store the battery in hot or extremely cold locations.
Nov 16, 2013 | Nikon Cameras
Plugged in, Not Charging
first thing you should check is the AC Adapter voltage output and Amperes that your computer requires.
if all ok, try this:plug in your AC adapter to your computer in a switched off position. wait for an hour or two then turn on your pc and check whether the battery has been charged or not. if not, then the battery is gone but if it's been charged and drains so fast while the computer is on then you should buy a new battery.
Mar 06, 2013 | Lenovo ThinkPad SL410 Notebook
I had my plugged in my laptop in overnight and took it off charge to use it today within 20mins after i turn it on, it was down to 59%. What solutions are there to fix the broken?
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jan 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
Battery new cahrging good green light flashes
Hi. How many times does the light flash betwwen pauses? this is a fault code. Check free-wheel lever. Check motor and battery leads and connectors.
Check the resistance through the motor with a multi meter.
Good luck. Neil.
May 09, 2010 | Pride Sonic 3 Wheel Portable Scooter
My Highnote won't charge past two battery bars. whenever I put it on the charger it will not go past two bars. ive taken the battery out and shut it off and everything. still nothing works.
FileName : (Film 2009) Capitalism A Love Story (Hd realtv).hebrew.avi Header Data : 43 61 70 69 74 61 6c 69 73 6d 00 00 00 00 00 00 Capitalism......
Mar 06, 2010 | Samsung Highnote Cell Phone
We Dont Kno!!!
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop power it up then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 02, 2009 | Dell Inspiron 6400 Notebook
Mobile battery charging not becoming full
Sir/ Madam,
I, Ajay Kr Chatterjee of 8/60, East Mall Road, Green Valley, Kolkata, PIN:700080, Resi. Ph.No. 033 21162389 purchased a Motorola L6 Mobile phone from our local The Mobile store at Kolkata near Dum Dum Road Hanuman Mondeer shop on 3-4 month ago! But from yesterday when I Charged the phone on night that time to till my Mobile phone was not yet Charged! I applied all types regulation from the Motorola L6i Mobile phone Manual but till time my Mobile phone will not Charged! Please give me advise what can I do for this problem!
Wait for your early positive messege.
Thanking you .
Yours faithfully
Ajay Kr Chatterjee
N.B.:My e-mail address is chatterjeeajaykumar@yahoo.co.in
Apr 20, 2008 | Motorola Mobility L6 Cellular Phone
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
