Question about IOGear GPSU21 Print Server
Using IOGear GPSU21 print sever with Zebra LP2844 printer, keep getting blank labels printed before printer actually prints the label. Driver for LP2844 is latest on a Windows 2008 sever. I get about 9 blank labels to each label printed.
5 Suggested Answers
SOURCE: Does IOGEAR GPSU21 work with Vista?
I had a similar problem.
I had original printer install disk to help me with the problem
I went to PSAdmin and changed the DCHP Setting to allow my router to give it a new ip address.
I then added the printer using vista's add printer wizard: I used the add network printer and used the new ip address the PSAdmin gave me: I installed driver off disk, but then chose the one vista had already. I also used the "Print server 1 usb" device when asked which device I had installed.
Mutant
Posted on Aug 20, 2008
firesnake09
  • 2923 Answers
SOURCE: IoGEAR printserver GPSU21 with VISTA
Yes, the GPSU21 is tested to work with Vista 32 and 64-bit Operating System. The things you need to do is listed below:
1. There's no need for you to install the CD that came with it, if the MFP Utility is already installed in another computer.
2. Get the IP Address of the GPSU21 from the computer that has the MFP Utility installed.
- Open the MFP Utility > locate TCP/IP at the lower portion of this window and click the plus (+) sign. > get the IP Address.
3. After getting the IP Address of it, go to your Windows Vista computer and ping the IP Address (just to make sure that Vista is seeing the Print Server).
- To ping, follow the steps below:
- Click the start menu and open the MS DOS Command Promt.
- On the black screen, type this "ping (type the IP Address of the print server): just like this
- C:WINDOWS\Desktop\Scott>ping 192.168.x.x and then hit enter.
4. Once you get ping statistics 4 packet sent; 0% loss. Then the Print Serve is communicating with Vista.
5. On you Windows Vista computer, make sure that the printer is working when directly connected to it. Because there could be a possibility that the printer driver is not properly installed that's why the server is not working.
6. On Vista, go to the Control Panel > Printers > Locate the printer icon (the one that is set as you default printer)
7. Right-click on the printer icon and then select properties > go to Ports tab.
8. Click on Add port button > select Standard TCP/IP > click on "New Port" (beside Cancel)
9. Hit next > type the IP Address of the print server. > Next
10. Click on Custom > Settings button
11. For Protocol: select LPR
12. For the Queue Name: type L1 > Click on OK > Finish.
13. Then under the printer properties, you will see the Standard TCP/IP is selected
14. Hit Apply so that the printer name would appear right next to that port > OK
15. Try printing a test page.
NOTE: After following the steps, you should be able to print using your Vista computer. I configured this print server with Vista several times and it does work with Vista.
Posted on Apr 07, 2009
  • 5342 Answers
SOURCE: Print server Iogear GPSU21 + HP Deskjet F4180 do not print!
The print server is Vista compatible. However, the Deskjet F4180 is not listed as a supported printer.Look at this list: http://iogear.com/files/pdf/GPSU21_Printer_Compatiblity_List_4-20-09.pdf . This print server is not the right one for your printer. You can either try a different print server, a supported printer or directly connect the printer to a computer and make that computer a print server for the rest of your network. The last option will take a bit more work. In Windows, the directly connected computer will need to allow sharing for the printer and the firewall software will need to trust the other machines in the network connect to it. The other computers will only be able to print and not use the other multi-function features. You may need to get additional software drivers to make this work (particularly if one computer uses a 64-bit OS and another has a 32-bit OS).
I hope this helps.
Posted on Jan 28, 2010
firesnake09
  • 2923 Answers
SOURCE: IOGear GPSU21 doesn't work wirelessly with ip4500.
First, you have to make sure that the printer can print directly connected to the computer.
Second, make sure that you can "ping" the print server while it's connected to the router.
If the printer works when connected to the computer and you can ping the print server, then you just need to change the port in the print server utility. It should be set to LP1 and not LPT. The queue name should be set to L1.
Check also the printer port, and be sure that it's set to USB001 or USB002 Virtual Printer Port.
If same problem occur, try to uninstall and re-install the server utility. Use the link below to download the utility for Vista 64-bit OS:
http://www.iogear.com/support/dm/driver/GPSU21#display
You may refer to the user manual of GPSU21 or call IOGEAR through 866-946-4327.
Thank you and good luck!
Posted on Jun 02, 2010
Testimonial: "This is very close to the work around I got from Iogear support. This is very helpful and informative and it works"
Hello I was working on Zebra LP2844 label printers. I need to print labels and barcodes from a data source using EPL.I have never done this things before so any help is appriciated
Epson standard code is totally different. EPL is Eltron printer language. I've not programmed in it, but there should be a programmers manual out there somewhere.
Jul 29, 2015 | Zebra LP 2844 Thermal Printer
I have setup my zebra LP2844 printer with the correct power adapter and the latest windows driver from the zebra website,however it's printing rubbish on windows test print and you have to turn the...
reinstall it again the printer driver, then test if it appear rubbish on windows test print but good on paper labels itself your gonna use, then use it. it doesnt matter at all as long as it's print good ok on actual paper application
Feb 12, 2011 | Zebra LP 2844 Thermal Printer
I want to print 2X4 labels without skipping 2 labels each time
obviously its your vb software. try using a real label program and end this issue.
Sep 05, 2017 | Zebra LP 2844 Thermal Printer
WordPerfect prints a blank label after each request
I would think you are printing using a printer driver for the LP2844, not using the lexmark driver. Depending on whose Zebra driver you're using, one setting to check would be to make sure the web sensor is being used for type of media sensor. The names for this setting vary but can usually be found in the printing preferences tab.
Hope this helps a little.....
Apr 27, 2010 | Zebra LP 2844 Thermal Printer
ZEBRA LP 2844 PRINTING PROBLEM IN USPS SHIPPING ASSISTANT
Are you sure that the page size is wrong, or are you just guessing because of the way that the label is printing? I would uninstall the driver - delete the printer from printers and faxes and remove the driver from Server Properties (in the file drop down in Printers and Faxes). Go to ups.zebra.com/ctp and get the latest driver - you have to have the UPS version of the driver in order to support pass-through printing. Go into your UPS Ship Asst application and make sure that the generic thermal is not checked.
Jan 15, 2010 | Zebra Eltron LP 2824 Thermal Printer
Zebra lp2844 printing incorrectly with paypal multi order
Same here... Can't be the printer - has to be something with either the paypal software or the driver since my 'SAMPLE' prints solid as well. Did you ever find a solution?
Oct 15, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844 print is wrapping horizontally
Update the printer firmware, download latest printer driver from zebra website.
Oct 01, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Mar 06, 2009 | Zebra LP 2844 Thermal Printer
IOGear GPSU21 Print Server Logo
181 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
