Question about NEC Office Equipment & Supplies
How do you reset replace fuser on a bizhub c200?
5 Suggested Answers
wheatlandsvc
  • 1110 Answers
SOURCE: I have bizhub c250 and
You can reset the fuser counter only by replacing the counter reset fuse. This fuse is located on the fusing unit which must be removed and a small cover opened to get access to the fuse. You ca get the fuses from precisionroller.com
Their part number is M9970. It will say imaging unit fuse but the fuse is the same for the C250 fuser reset.
If you do not feel that you can remove the fusing unit and replace the fuse then you might be able to find a local independant copier repair person to do it.
Be assured tho that you can reset this indicator as I have done this a dozen times or more for my customers.
Good Luck and Thank You for using Fixya.
Posted on Nov 04, 2010
Testimonial: "Thanks"
wheatlandsvc
  • 1110 Answers
SOURCE: can you reset fuser counter without replacing the
You can. You have to remove the fuser, and replace the counter reset fuse that is soldered into the wiring harness, then re-install the fuser. 10 minute job but not a one I would recommend unless you know the machine pretty well. Depending on your location and service options I would try to find a local independant repair person who can do this for you. I reset 20 to 30 of these fusers per year. Note you can also reset your transfer belt unit as well as your Imaging Units as well.
WheatlandServices
Posted on Jan 06, 2011
Testimonial: "thank you very much. I can tell, you're really an expert. your response was very helpful, i will contact a good technician right away to change fuse."
  • 60 Answers
SOURCE: reset fuser
Unforunately once a fuser goes, you are out of luck. I don't know of any printer that will continue to work once the fuser has gone bad. It's best to keep an extra fuser handy for business-critical printers.
Posted on May 28, 2008
SOURCE: put in newer fuser unit but machine still says to replace
the fusers have an inline fuse soldered on the plug which resets an internal counter. if you pulled a fuser from another machine will still show up spent when putting it into another machine. you can buy these fuses and solder them on yourself. most on the fusers will last 2 to 3 cycles by doing this.
Posted on Oct 11, 2011
How do i re-set fuser unit replacement message on bizhub c253
SIR/MAM
TROUBLE RESET
FIRST, If this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Jun 27, 2016 | Konica Minolta Bizhub C253 Copier
How jto reset a bizhub c200 when showing an alarm code
stop,0,0,stop,0,1 gets you into service mode where you should find the counters
Jan 14, 2015 | Konica Minolta bizhub C200 Cyan IU Reset...
C 3201 bizhub c351
did you reset the machine after installing the different fuser a different fuser does not reset the machine requires a manual reset procedure your old one might be ok just got to hot and shut down reset the machine.
Apr 01, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
ERROR CODE 3921 BIZHUB 450
replace the fuser unit.
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
Then reset.
use this procedure:
Feb 03, 2014 | Konica Minolta bizhub C450P Laser Printer
Reset password bizhub 211
how can i reset the password for my konica minolta bizhub 211 to remove the maintainance call 2 display?
Nov 21, 2012 | Konica Minolta KONICA BRAND TN-211 BLACK...
Abort code
contact service use go to www.konicaminolta.com
Oct 06, 2012 | Genuine Konica Minolta Konica Minolta...
Can you reset fuser counter without replacing the fuser on a C352 bizhub?
WheatlandServices
Jan 06, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
I have bizhub c250 and the 83000 prints (copies). My Fuser unit show empty and I can't use my bizhub c250. it should be replaced on 120 000 copies. How to reset this fuser unit on my printer?
Nov 04, 2010 | Office Equipment & Supplies
Put in newer fuser unit but machine still says to replace
If you want to clear the fuser message you have to be sure you replaced the fuser web. Then go to 25 => counter clear(items 13)=> Clear fuser counter or 36=>counter clear(items 8)=>Clear fuser counter.
May 28, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Reset fuser
May 28, 2008 | Konica Minolta bizhub C250 All-In-One...
802 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
