Question about Amana Refrigerators
My 4 year old Amana fridge (ABD2233DE) stopped working (both the fridge/freezer). Air still blows but it's not cold. After checking coils, I called out a service tech. He tapped on the PC board, and when that didn't do anything he moved to that back. After a few minutes he said it was the compressor, and that it would be approx $500 to fix. He also said that he had a similar fridge at his store for $1000. I was at work when he was here so I didn't get to ask any questions. Before I decide to fix/purchase, I want to make sure that there isn't something that I can try to verify that it's the condensor--ie short the cable to the mother board to confirm that that's not the problem. Thanks in advance, Al
  • Amana Master
  • 43,501 Answers
This is a tough one.... but I would trust the integrity of the repair guy...What he did is probably exactly what I would do....he probably felt the compressor and heard it "try" to start and then made the pronouncement of the death of the compressor...
If he will sell you a new one for 1000 I would not change the compressor anyway...
heatman101
Posted on Aug 31, 2010
Amana BR18V1S is running but fridge temperature is low (slightly cool) Checked everything, cleaned coils (very dirty) Freezer OK.
Check and see if the freezer coils are blocked with ice. If not you may have a refrigerant problem as you stated the coils were dirty. The new refrigerants when hot tend to clog the capillary tube which feeds the refrigerant to the evaporator (freezer coils)
Jun 06, 2011 | Amana Bottom Mount Refrigerator 22 cu ft -...
The freezer is working but the fridge part is not blowing any air. Model #BR22TL, MFG No P1196710WL and S/N 9801166059. I have check for continuty and all readings are o.k regards Elton Hinds
The refrigerator gets its cold air from the freezer, usually through a flap between the two sides. First make sure your temperature control has not been turned down in your refrigerator. You might have to defrost your freezer to get the flap working again, which could mean something in the defrost circuit is bad.
Also note that
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Hope this works and Good luck in fixing....
Jul 28, 2010 | Amana ARS2661B Side by Side Refrigerator
Freezer works but fridge side not cold
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Dec 06, 2009 | Amana DRS2462B Side by Side Refrigerator
Freezer working but Fridge not cooling... Tried adjusting temp to max cool and nothing. Unblocked vents, still nothing... Pulled off back panel cover to vacuum and brush... still nothing... help??? In case...
Oct 26, 2009 | Amana ARB1917CSR Bottom Freezer...
Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Jul 01, 2009 | Amana AFD2535DES French Door Refrigerator
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Amana (freezer on top) not making ice; fridge warm
I would be calling the store from where it was purchased it should be under warranty. If the ice maker is not working the freezer is not getting down to proper temp. therefor the refrigerator does not cool because all cooling takes place in the freezer, there is a damper between the refrigerator and freezer that allows air through cooling the refrigeration section. Look for ice on the back wall, of the freezer section, If present then the defrost cycle is not working. The evap.coil is icing up and there is no air blowing into the refrigerator. This is the most common problem.
Oct 20, 2008 | Amana ATB1836AR Top Freezer Refrigerator
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
The refrigerator is not keeping tempurature. Freezer is working fine
Either the freezer fan has stopped blowing air or the defrost timer has stopped and the airways to the fridge are clogged with ice. Only the freezer gets cold in a refrigerator. The fridge part gets cold by cold air being blown through air passages from the freezer. Good Luck!!
barneyluc
Oct 03, 2008 | Amana Refrigerators
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
125 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
