Question about Acer AL1716 17" LCD Monitor
No Power , No green light - Acer AL1716 17" LCD Monitor
  • 131 Answers
Check the power cable is inserted securely... at both ends.
Posted on Aug 31, 2010
2006 F150 no brakes light all other lights work
Does this include the CHMSL ( Center High Mount Stop Lamp ) ?
The turn signals work fine when you say all other lights work ?
If so could be 2 things.
1. The BPP ( Brake Pedal Position ) Switch
1.1. The BPP has 4 wires on it
1.1.1. Tan w/ Red stripe & Pink w/ Light Green stripe are the shift interlock
1.1.2. Light Green w/ red stripe & Light Green wires are the Brake lamp part of the BPP.
When you have the brake off, the Light Green w/ Red stripe wire should have power on it ( from fuse #2 ) and when you press on the brake pedal, the Light green wire should also have power.
- If only the Light green w/ red stripe wire has power with the brake on and off, and the Light green wire never has power, the BPP switch needs to be replaced.
- If the Light Green wire does not have power ( and you are use of the ground you are testing with ) fuse #2 is blown.
- The fuse for the brake lamps ( Fuse #2 in the cab fuse panel ).
-- This is if the CHMSL is also not functioning
Jan 26, 2011 | 2006 Ford F-150
1996 Camry Tail ights not working
So its a wagon? or I dont know what S/W is. If the license plate light works, the light failure sensor could be bad. It should be in the left rear corner area and have 4 wires. Green, Light Green, Yelow/Green and White/black. You should have power on the Green going into the box, and the Light Green out to the tail lights. If you have power on the Green, but no power on the Light Green, then the box is bad, either replace the box, or you can just connect the Green to the Light Green wire to get tail lights operating.
May 12, 2010 | 1996 Toyota Camry
Power supply light keeps flashing green and problems with tray op
under normal conditios power supply light should be a steady green light not flashing if not power supply is might be bad call (800) 4MY-XBOX
Oct 11, 2009 | Microsoft Xbox 360 Console
Drive stopped working
I had the same problem - green light on power cord but when plugged in the green light would go off and the hard drive would do nothing. I took it into Geek Squad finally and it turned out that the problem was hard drive casing, which I had to have replaced.
Jun 07, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Green light flashing on back of unit near power cord also green light flashing on motherboard near power supply plug in.
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
May 06, 2009 | Sony VAIO VGC-RB40 PC Desktop
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Acer AL1716 17" LCD Monitor Logo
14 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
