Question about Dryers
I have a Kenmore electric dryer model 110.62822101. It has stopped heating on any setting.
    President:
  • 3,773 Answers
Remove the back panel and check the heating element with an
ohm meter. (continuity Test) The one
with the two big red wires attached to it
also the thermal switch just above the element on the element case.
If you can't use an ohnmeter take the parts to your local appliance center and they will check them for you.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 02, 2010
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
Problem with Dryer Timer or heating element
The heat cycle must be working for the timer to advance in the Auto Dry setting.
Your heating element and or high limit thermostat is bad.
We need a complete model number to be more specific.
May 31, 2010 | Kenmore 600 6965 Electric Dryer
Older dryer just stopped heating. Air still blows
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | Kenmore 64742 Electric Dryer
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Kenmore Dryers
No Heat
go to servicematters.com
Jan 15, 2009 | Kenmore 63942 Dryer
Low heatworks, high heat does not.
it sounds like you need a set of thermo switches. one may have stopped functioning. a service tech can test them easily. should be low cost
Jun 28, 2008 | Kenmore 64202 Electric Dryer
Electric dryer wont heat or turn off
there could be a temperature switch that tripps off. look at the diagram and trace also the power to the timer motor. it seems that you lost your power to your timer motor that is why the timer stays @ what ever setting you set it.
Feb 11, 2008 | Kenmore 63942 Dryer
Dryers Logo
67 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
