Question about Sharp AL-1540CS All-In-One Laser Printer
I have an error code "L1" what does that mean
  • 1,110 Answers
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Good Luck and Thank You for using Fixya.
Posted on Aug 31, 2010
What is error code f69 on a frigidaire electric range
Hello. You have a serious problem--that error code means L1 or L2(the 120v supply wires) may be shorted with the neutral on the incoming power supply. TURN OFF THE POWER!! Check the wiring at the terminal block. The neutral is the center post. L1 is usually black and L2 is usually red. The F68 and/or F69 error means high voltage or the above-mentioned condition. Once you have verified there is no incorrect polarity or voltage condition, then the main oven control board must be replaced. The part number you might need is 316562011. I hope I helped you!
Sep 20, 2015 | Frigidaire Kitchen Ranges
Why does remote UMC-117 flash error code 11 and then L1?
Multiple error codes can mean bad PC board.
C11 is combustion, vent or gas issues
L1, heat exchanger needs delime.
Catch unit up on required maintenance each year.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#error
Gene
Water Heater Timers Save Money
Jun 17, 2014 | Rheem Tankless Water Heater Main Remote...
My AL 1566 Sharp multifunctional printer shows me error code L1-00 what will i do?
L1-00 is scanner feed trouble. This normally means the optical or mirror unit is not moving correctly. This could be caused by a disconnected wire or a faulty motor or sensor.
Apr 22, 2013 | Sharp Office Equipment & Supplies
What does L1 error code mean on an Electrolux dishwasher
The only solution I can come up with for this one is that L1 is a Leak Detector problem-When water is detected under the tub. I spent an hour researching this issue. I've never come across this one before.
May 11, 2012 | Electrolux Dishwashers
After installation my sharp ar-m420u copier mx-2300g displays error codes L1-00 and F2-00
L1 MEANS U HAVE TO REMOVE THE SCANNER LOCK WHICH IS ON THE SIDE OF THE MACHINE.
F2 MEANS SOME PROBLEM WITH YR TONER CATRIDGE.CHANFE IT AND SEE
Jan 11, 2011 | Sharp AR-5320 Black and White Copier
What does ''L2'' stand for shown on Kenmore Elite Oasis st?
you can call sears parts service and they can tell you what code means
Aug 19, 2009 | Kenmore Elite Oasis ST 7806 Dryer
L1-18 code
I don't see a reference to a L1-18. A L1 code is a scanner feed problem. I only show a L1-00 code. Sorry.
Jul 01, 2009 | Sharp AR-507 Copier
Scanner bar won't move
According to another source, the L1 error means "Scanner position error". Hope you find a solution, and not an expensive one.
May 16, 2006 | Sharp AL-1540CS All-In-One Laser Printer
Sharp AL-1540CS All-In-One Laser Printer Logo
178 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
