MPT 8051 "Surround Sound System" has suddenly refused to reproduce my TV's audio. It has been marvelous in reproducing my poor TV sound quality. All front panel indicator lamps illuminate normally, however I get no TV screen indications when I work the remote. The remote indicator light lights when pushing buttons. I've been through the wiring several times, they seem to be OK using BNC cables. HELP Bill Wareham
  • 19,396 Answers
Try performing the usual reset by disconnecting the TV power cable, I do not know the TV details, but it does not look a settings problem.
If the same cable works on different devices (ensure), then the cable is OK. Ensure that the cable has no broken contact in connector are (if using AV cables). If you use an optical audio cable, sometimes a broken cable may work when you move it, test a spare.Also be sure that you connect the AV cable to a proper input on MPT 8051.
If nothing works, test the MPT 8051 audio input using a different device, and do the same on TV to find where the problem is.
Once you find the responsible, next step would be taking apart back panel to resold terminal connector to Audio port, or replacing optical connector.
Posted on Aug 31, 2010
Digital audio output tv
Digital audio refers to technology that records, stores, and reproduces sound by encoding an audio signal in digital form instead of analog form. Sound is passed through an analog-to-digital converter (ADC), and pulse-code modulation is typically used to encode it as adigital signal. A digital-to-analog converter performs the reverse process, and converts the digital signal back into an audible sound. Digital audio systems may include compression, storage, processing and transmission components. Conversion to a digital format allows convenient manipulation, storage, transmission and retrieval of an audio signal.
Oct 13, 2013 | Insignia 42" LCD Flat-Panel HDTV
Plying blu ray, voices not reproduce only surround channels!
Make sure you have a center speaker hooked up as most voice tracks come through the center channel.
Jul 12, 2013 | Televison & Video
No sound on the tv
As TV and DVD playing reproduces sound, you have to check TVs tuner function first. Connect the TV to external areal by connecting areal via areal socket. Make an auto-tune function. Refer the user manual about how to make an auto-tune to local on-air program. Make sure that, the TV reproduces picture and sound normally. If it is correct, your TV is perfect in all respect. If not, the tuner to your TV should be replaced with same type and number.
Jun 20, 2012 | RCA Universal Remote 3 Device Remote...
How do I get the C5 Subwoofer to activate?
Hello
If subwoofer is inactive now, the sound preference settings you set now is wrong.
Before using the remote control for the following
operation
* Set the remote control mode selector to AUDIO
** There are exceptions in the operation mentioned
above. In such a case, follow each instruction
Dolby Pro Logic II*1
# Dolby Pro Logic II has a newly developed multichannel playback
format to decode all 2 channel sources - stereo source and Dolby
Surround encoded source - into a 5.1 channel.
Dolby Pro Logic II has two modes - Movie mode and Music
mode
# Pro Logic II Movie (MOVIE)
Suitable for reproduction of Dolby Surround encoded sources
# Pro Logic II Music (MUSIC)
Suitable for reproduction of any 2 channel stereo music sources
# Dolby Digital*1
Used to reproduce multichannel soundtracks of the software
encoded with Dolby Digital
# DTS Digital Surround*2
encoded with DTS Digital Surround. DTS Digital Surround (DTS) is another discrete multichannel
digital audio format available on CD and DVD software
Jun 19, 2011 | JVC TH-C5 System
Can't hook up to a flat screen tv
I can only guess as to the nature of your problem, but I'll try. If you're trying to hook up your amplfier and its a 5.1, or 6.1 amp you need to hook up the audio by using the orange output on the flat screen, it may be labeled "coax" or "hd audio out" or surround out, this is the one wire you need to reproduce the surrond sound with left, right, center and rear speakers, and also the sub woofer. The other outputs on your tv will be red and white or red and black, these are the analog audio out and you plug them into your amplifer too, but they won't be 5.1 sound, although your sub woofer will still work. I hope I have helped some.
Mar 12, 2011 | Audio Players & Recorders
I have a pioneer vsx 818 v amp, when I set it up we get noise / beeps etc from the surround sound speakers but then when playing a film in 5.1 we get no sound from the surround speaks ..driving me nuts !...
To get sound out of your surround speakers, first off go through the receiver setup and make sure that is correct. Also, usually the best soundfields to use for sourround sound is PLII Movie or dolby digital. Next , make sure the source you are viewing is capable of outputting 5.1 sourround sound. Lastly, it is a good thing to remember that sourround speakers are only intended to reproduce sound effects. You certainly can override it so that all speakers play full range audio, but that is not the intention.
Good Luck
Jan 07, 2011 | Pioneer VSX-818V-K Receiver
I have a Sharp Aquos with a optical output, i conected it to the tv optical input of the panasonic sc ptx7 but it doesnt have audio via optical,on the contrary via rca works perfectly.
hi,
check the following on ur tv
1. Press MENU to display the MENU screen,
and then press c/d to select "Digital
Setup".
2. Press a/b to select "Audio Setup", and then
press ENTER.
3. Press a/b to select "PCM" or "Dolby
Digital", and then press ENTER.
4. Press MENU to exit.
PCM The optical output terminal output studio signal in PCM form. If your digital audio system does not support Dolby Digital, select "PCM".
Dolby Digital
The optical output terminal outputs audio signal in Dolby Digital form. it reproduces sound from surround program of digital.
also check the input assignment of ur dvd palyer's tv input. if it is selected as analog then change it to digital.
ok
Dec 20, 2010 | Panasonic SC-PTX7 Home Theater System With...
Onkyo 6.1, 75 watts connected to sony blue-ray.quality sound not there maybe because I have it connected to reg. stereo speakers with klipsch center speaker.If so, what speakers work good? Iam on a...
How much of this scenario is NEW?
Within limits: Speakers is speakers. They don't know how many other channels are there, so their sound quality is independent of each other. Send them good sound and they will reproduce it.
Improper setup will hurt the 'sound' as much as poor speakers.
Not knowing what you have for speakers now, I would advise you might get yourself somethingto serve as a sub an some surround speakers before you declare your current speakers faulty.
Mar 31, 2010 | Audio Players & Recorders
I have a samsung cinema system rts he10t and a samsung lcd tv le32a556 and i am trying to get the sound from the tv to the cinema system i have a hdmi cable and the red and white phono cable connected but...
make sure you have the audio cables connected to the OUTPUT on the tv & the INPUT on the surround sound(from your desciption sounds like you have them reversed)hope this helps,thanx for using fix-ya,please rate all replys
Nov 17, 2008 | Audio Players & Recorders
CAN ONLY GET THE SURROUND SOUND TO WORK WITH DVD'S NOT WITH NORMAL TV OR SKY?? WHY??
You should have a AUDIO menu in which you can simulate true surround sound. This should be in your owners manual. Your DVD is recorded in dolby surround sound that's why on your set it will be reproduced as recorded. I hope Samsung is using a ATSC tuner in that model?
Apr 04, 2008 | Samsung HT-Q100 System
24 people viewed this question
 Grubhead
Grubhead
