Hi, I have a HP laser jet 2600n and my printer keeps telling me there is a paper jam, but there is not paper stuck what so ever. any little info would help. thank you
  • stacey_conta Aug 31, 2010
    I have tried that, tried troubleshooting off of my control panel as well. tried shutting down my computer, i am on a network and all three computers are having the same problem.
Try disconnecting the power cord and let it reset for aminute....
Posted on Aug 31, 2010
I have a HP Color laser jet 2600n printer. I have tried different Glossy paper, marked for laser jet, but still get bad smudges on my prints. these smudges are still visible on the next ordinary prints...
You need to ensure that you are telling the printer that and your print driver that you are using glossy paper as this will change the speed that the printer prints at and ensure better bonding.
May 23, 2011 | HP Color LaserJet 2600n Printer
How can i repair my hp laser jet 2600n printer when paper jam
Hi. I would suggest cleaning your printer on the inside and removing any blockage from rollers or look for any peace of paper that's clogging any device inside your printer. Also try pressing all the sensors inside to check if they are not stuck or something. Hope this helps
Jun 04, 2010 | HP Color LaserJet 2600n Printer
Cartrige jam how do i fix
  • Inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.
  • Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers; look for bonded paper that is "laser and ink-jet compatible."
  • If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer.
  • Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper.
  • If you have a laser printer, inspect the printer's paper rollers. They should be smooth but not shiny. Rollers that are cracked or glazed are a frequent cause of paper jams and should be replaced by a technician.
  • If you have a laser printer, try cleaning the printer's paper rollers with a lint-free cloth and isopropyl alcohol (available at electronics shops or drugstores).
  • Try changing the toner or ink cartridge.
  • If you hear a clinking sound during printing, your printer probably has a broken gear and needs to be serviced by a technician.
Please rate my response!!
Jan 29, 2010 | HP Photosmart C5180 All-In-One InkJet...
My 2600n laser printer had a paper jam in the outbox bin. I took the stuck paper out and had a look inside. I see no other paper jam but the printer keeps telling me I have a paper jam in the outbox. ...
There is a sensor flag (little black peice) that hangs down in the paper path as the paper exits. The flag tells the printer if the paper has made it out or not. That sounds like your problem. Just in case it is something else, her's a copy of the complete service manual for your printer. Start on page 90 (pdf page 113) and it goes thru the jam areas.
http://www.feedroller.com/Store/Service%20Manual/HP%20Color%20LaserJet%202600N%20(Q6455A)%20Parts,%20Service%20Manual.pdf
Nov 16, 2009 | HP Office Equipment & Supplies
HP 2600n Ironing transfer paper jammed around top roller
It is probably stuck permanently, and the fuser will need to be replaced. I believe the "fuser replacement" instructions are in the manual.
Jun 05, 2009 | HP Color LaserJet 2600n Printer
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
Laser jet HP 2600n
Before you print, check the printer settings and see if it is set to choose paper automatically. If it is try manually setting it to the tray 1 you mentioned. This may stop the printer from checking every time it is grabbing paper. Also try keeping the other tray slightly open which may automatically tell the printer to look right away at the other tray.
Hope this helps!
May 01, 2008 | HP Color LaserJet 2600n Printer
Adhesive jam
Some adhesive still on the transfer or fuser. Try a cleaning page, or some manual cleaning with dry towel-paper if adhesive signs are visible on transfer. Do not try fusing unit because very delicate silicone film inside.
If stain are of a single color, (p.es. magenta) you must change this cartridge.
Dec 24, 2007 | HP Color LaserJet 2600n Printer
k24674
