Question about Avaya 5400 Series 5410 Phone
What does the g or d or other letter codes on the right hand side of the 5410 display mean?
On Display telephones, the following letters can appear:
Posted on Aug 31, 2010
  • Anonymous Aug 31, 2010
    • B indicates that the user is barred from making outgoing external calls and can only be used for internal calls.
    • D indicates that the user is set to forward all calls.
    • G indicates that the user has their hunt group membership enabled.
    • H indicates that the user has placed a call on hold.
    • N indicates that the user has Do Not Disturb turned on.
    • P indicates the number of parked calls.
In my book it 7452 but it not working and now it displays error
If the numbers under the right hand bar code end W297, then the code is 3733. If I have misread the barcode, let me know the last letter and 3 numbers.
Jul 15, 2015 | Renault Cars & Trucks
How do i put code in my phone,ive asked this question before. My Giff Gaff sim card is in the phone on the screen on the left hand side it says OK. On the right hand side it says SOS if i press the key...
You would have to call your customer service number and tell them what your wanting to do they will help you or go to your security and go to change security code and you can do it that way to
Feb 08, 2015 | Cell Phones
P1 code what does this mean
what does the user manual tell you .
Jan 17, 2015 | Cameras
How do i check what the error code is on the e 3500
When your copier is displaying an error the code will be found in the top right hand corner of the display. It will be a mixture of letters and numbers and will be 4 characters. If the copier is not displaying an error code, holding the c and 8 button will make it appear.
Sep 25, 2010 | Toshiba Office Equipment & Supplies
Estudio3500 spanner flashing call service, how do you find what the error code is
Sep 24, 2010 | Toshiba E-Studio 3511 Color Copier
The panel control going shows Er in temp display
ER in temp means error code next 2 letters are first letter of part giving problem or where problem located.. if " ER DH" means def heater not coming on, does not mean heater bad but def control bad not letting voltage to heater. could need main bd also
Aug 21, 2009 | LG LRSC-26922 Side by Side Refrigerator
How do i change the time on the avaya 5410 handset There is a feature code i have used before but cant remember where i wrote it down....... doh ! pls help!!!!!
  1. Press feature +(00)+(left intercom)+(left intercom)+#103 at extension 10 or 11.
  2. Enter a new time in 24-hour notation. For example, to set the time to 2:15 p.m., press 1415.
    A display similar to the following appears:
    System Time
    Data 1415
    This time appears on system display phones as 2:15 p.
  3. Select another procedure, or exit programming mode.
Apr 01, 2009 | Avaya 5400 Series 5410 Phone
I dont know how to program frequiences on the scanner
1. Press Menu (Bottom left hand side of the scanner) You should see "Program System"
Press E You should see "Select System"
2. Turn VFO knob (Top outside right knob on the scanner as it faces you.) until "New System is displayed.
3. Press E
4. Using the VFO knob, select "Conventional then press E three times
5. Press the decimal key until all the letters under "Edit Name’ disappears
6. Now you’re ready to name your system. Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E
7. Turn VFO to Edit Group then press E
8. Use VFO to select New Group then press E twice
9. Press the decimal key until all the letters under "Edit Name’ disappears
10. Now you’re ready to name your group. Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E
11. Turn the VFO to Edit Channel then press E. (You should now see "New Channel")
12. Press E then enter a frequency
13. Press E twice
14. Press the decimal key until all the letters under "Edit Name’ disappears
15. Now you’re ready to name your "Subgroup" i.e. " Dispatch" Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E then menu
16. Use VFO to select New Channel
17. Repeat steps 12 through 16
Mar 27, 2009 | Uniden BC246T Handheld Scanner
Right hand side of key board displays numbers
Your bios probably is set to use the embedded keypad when the numlock is on. you can set it to numbers only when you press the FN key
Feb 18, 2009 | Dell Latitude C640 Notebook
Avaya 5400 Series 5410 Phone Logo
1,011 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
