Question about Delta TP300 Shopmaster 12-Inch Portable Planer
Drive belt for planer epn 7582 n to replace a broken one
  • 90 Answers
If you need a part check tool parts direct. if you have the belt, pull the side off opposite the handle that raises and lowers it. you have to roll the old belt off and then you have to roll the new one on. it will be tight and hard to do. if it isn't, there is something loose and that is not good.
Posted on Sep 01, 2010
Belt on my dewalt dw680 planer slips and starts smoking
If the ball bearing of the armature was getting too hot by working with too hard woods may be the bearing of the armature can melting loss the drive belt have lost a little tension by it the housing and a bearing has to replaced in that case.
Feb 10, 2016 | Dewalt DW680K 3-1/4" Planer
I need all manuals for my SAC RS 63-S Surface Planer
Planers - Single - West Coast Machinery
www.wcmachinery.com/WCMACHINERY/myinventory.asp?...S...
Delta/Invicta RC-63-D 24" Planer in excellent condition. ... Table jack screw sprocketshave been replaced ... 16" single surface planer, - 5HP 208-230 volt single phase belt drive motor, - push ... with operation manual, - excellent condition but offered "as taken from service". ... 2240/440V, three phase S/N 203851 1974 year.Missing: my
Wood working machinery > Planers > Thickness planer (used)
www.machineseeker.com/2-106-65.html
Used Dickte SAC, further information will follow shortly... 2.500 EUR ... Thickness Planer, Thicknesser Huefner & Soehne 63 ... Thicknessing machine Sicar S 500... Working width: 500 mm Working height: 200 mm 2 speeds 2 Table rollers manualtable lift 4 knives - Safety shaft. ... Thicknesser mitTersawelle SAC RS 53Missing: my
Woodworking Planers - Southwest Machinery & Equipment
Dec 14, 2015 | Masonry Tools
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Planer problems
If you're looking at the planer from the infeed side, there's a belt guard on the right side of the head. Remove it and check the condition of the drive belt. If it's broke the motor will spin without powering the cutterhead and feed rollers. The drive belt is still available as part number 22-563 on sites like http://servicenet.dewalt.com/ and www.ereplacementparts.com. Just put your model number in their search box and find the drive belt in the breakdown.
Aug 01, 2012 | Masonry Tools
When I feed the board in it stops then starts again. ever four inches. Leave a little snip in board. I've replaced the belt an the chains on the in feed and out feed still have this problem.
Couple of things to check:
1. Are your knives sharp? Dull knives will cut not fast enough to keep up with the rollers.
2. What is the depth of cut? Dewalt's planers cannot plane a board to excessive depths.
3. Are you rollers clean? Dirt, pitch or possibly grease could affect your feed rate.
4. The belt/chain for your rollers engaged or are they slipping? Open up the planer and check for wear or possibly broken belt/chain.
Snipe is usally caused by improper support while exiting the planer. Use outfeed rollers set to the correct height. Also chek that you outfeed bed is aligned with the bed of the planer.
Hope that helps,
Dec 20, 2010 | Dewalt Tools & Hardware - Others
How to replace drive belt on ryobi thicknessor
How to change belt on a ap10 thickness planer
May 09, 2010 | Ryobi Thickness Planer Blades
Delta TP300 Shopmaster 12-Inch Portable Planer Logo
300 people viewed this question
Top Delta Masonry Tools Experts
Vernon Taylor
Are you a Delta Masonry Tool Expert? Answer questions, earn points and help others
