Question about Kensington Pilotmouse Optical 2-button (72127)
Hello. i have a kensington pilotmouse optical model # 72127. one day right-click was working, the next it stopped. i switched settings from right-handed to left-handed and it worked, but the left-clicked stopped, so it's not the button. is this a normal occurrence for this mouse or mice in general, or is there a simple solution? i've had the mouse for a couple of years. thanks. good day.
    Top Expert:
  • Kensington Master
  • 79,847 Answers
I would replace the mouse.
Posted on Aug 09, 2017
5 Suggested Answers
debbily
  • 101 Answers
SOURCE: kensington Pilotmouse Mini Wireless Model 72314
check batteries
make sure the mouse and receiver can 'hear' each other
Posted on Oct 13, 2007
im4um2
  • 77 Answers
SOURCE: Kensington Wireless Mouse
You might want to try this. Synchronize each mouse one at a time and make sure the other mice are in the off position or remove their batteries. Once you have one of the mice set up turn it off as it is already synched with the base unit. Now synch the other mouse the same way, ensuring that you turn it off before synching the last one. Once all of the mice have been synched with their own base units they should be on different frequencies. If unsuccessful you may want to think about going with different models or manufactures.
Good Luck.
Posted on Jun 27, 2008
  • 3 Answers
SOURCE: manual PDF
For the Kensington Wireless Mouse 72214. Press the scroll wheel and the inset button on the bottom at the same time. This turns it on and off.
Press the inset button and the button on the end of the USB receiver at the same time and you will connect to the computer for use.
Rickabilly
Posted on Nov 25, 2008
SOURCE: having trouble with my wireless mouse and I can't
thanks
I did solve the problem
It was an easy solution.
nan
Posted on Aug 03, 2009
Cannot find driver for kensington 72127. using xp pro on toshiba satellite 300
the software that you need is here
http://ftp.kensington.com/PC/Input/mouseworks611.exe
it is compatible with that mouse
Apr 19, 2011 | Kensington Pilotmouse Optical 2-button...
Kensington PilotMouse 72129 Erratic movement across the screen, even with reset and new batteries
Microsoft has a knowledge base article on erratic mouse pointer movement that may help. As you can see in this article, there is more to it than uninstalling and reinstalling the mouse driver. Microsoft Support on Mouse Problems.
As I've said, it's possible that something has corrupted your mouse driver. You can either 1) re-install the driver, or 2) roll back the driver. Either one of these may help. To roll back your driver in Windows XP, go to Start --> Settings --> Control Panel --> Mouse. Click on the "hardware" tab. Select the appropriate pointing device, and click "properties." Click the driver tab, then select "roll back driver."
Under the "hardware" tab, there may be more than one mouse. If this is the case, select the one that is not used, follow the settings above, and then select "uninstall." Or, you can go into Control Panel --> System --> Hardware --> Device Manager, and remove the device under "Mice and other pointing devices
Dec 14, 2010 | Kensington PilotMouse 72129 (DH72129)
My Kensington 72216 mouse makes selections automatically.
Have you installed the drivers for your mouse? Sounds like you need to install the drivers. I looked on there site and they don't have separate drivers for each mouse. I'm guessing you need to download the mouse works program and install it. Here is the link to the website to get that software. After you install that software for the operating system your working on, your mouse should work fine. If i helped please leave me a rating. If i didn't help, comment and ill try again.
Mar 22, 2010 | Kensington PilotMouse Optical Wireless...
After replacing batteries (niCad rechargables) it
dear sir
good day
this device is in need to make the celebration process on it by clicking the conn button and pluging in the usb stick at once and use the sw that came with the mouse to adjust it
thank you
Dec 23, 2009 | Computers & Internet
My optical mouse Kensington Ci60 stopped working. Changed batteries and still not working ... How can I fix it?
Unplug the USB receiver and plug into a different USB port if available. Press the connect button on the receiver and wiggle and click the mouse for the next 10-20 seconds. This should revive the mouse.
If the above does not work, you may have to reinstall the drivers.
I hope this helps.
Nov 14, 2009 | ACCO Brands Kensington Ci60 Mouse
Kennsington 72216 mouse continuosly clicking after changing batte
try installing the software that came with the mouse. if none came with it then go to the manufacturers website and down load the drivers. if none available then there might be something physically wrong with the mouse and you replace it.
Feb 28, 2009 | Kensington PilotMouse Optical Wireless...
Kensington PilotMouse Wireless Mini interference
buy a different mouse for one of them not same make
Sep 30, 2017 | Kensington Pilotmouse Wireless Mini...
Kensington Pilotmouse Mini Wireless Model 72314
check batteries
Oct 13, 2007 | Kensington 72223 (72213) Mouse
Open Questions:
Having issues on Acer Product ' call +1888784-9316 Care Number 24/7 Helpline Acer is a Taiwan-based electronics multinational that is best known for its computer products, although it also produces other consumer electronics such as personal digital assistants and mobile phones, as well as computer-related products such as servers and storage devices. Acer has ruled the consumer electronics market because it has the most innovative approach. Acer laptops are famous for their energy efficient performance with long lasting battery life, high portability due to the laptop's light weight construction, along with the added features like high speed Bluetooth and wireless connectivity and also wide screen display that provides exemplary image quality with higher resolution. Because of all these and many more qualities acer support have made it to the top of the list of customer's choice for best laptops. But its users might face some issues from time to time that could prove to hinder their important work and so, to prevent this, we have a team of technically superior and experienced technicians who can be contacted anytime on our toll free call acer tech support number. Issues faced by Acer customers:- • Black laptop screen issues • Stretched images on laptop screen issues • Laptop heating up followed by forced shut down • Window update issues • Crashing issues in acer computer support • Windows 10 upgrade problems • Computer Tune up issues • BIOS update • Virus removal issues Call on our Acer support phone number acer customer service and get all these issues and many more related to Acer laptops, addressed by our technically advanced and experienced support team members. Our Services: If you have any query or issue related to Acer laptops that you want to get resolved in the most efficient way possible by some of the greatest minds in this job with highest levels of experience then contact us on our toll free Acer support phone number. Contact our technical support team for any assistance regarding issues concerning Acer Laptops by Calling on our acer technical support phone number. Get all your troubles sorted out in a matter of few minutes by most courteous and experienced technicians.
Jun 18, 2018 | Acer Computers & Internet
See all Kensington Pilotmouse Optical 2-button (72127) Questions
Kensington Pilotmouse Optical 2-button (72127) Logo
87 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Alun Cox
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
