Question about Seca 703 Digital Medical Column Scale Height Rod BMI Function (7031321999) ()
Hi, i'm looking for some solution for the error 140 in a column scale SECA 703... thanks
4 Suggested Answers
reyjoshua07
  • 1157 Answers
SOURCE: Hi i have a Seca
Hi pethkars,
You may do the following to helps you solve the issue with the Error that you are getting:
1. Switch off the scale with the Start key and start the scale again. The scale will then
work normally again.
2. If this is not the case, disconnect the power supply by briefly removing the batteries.
If this measure is equally unsuccessful, the last option you have is to inform the Service department. This will require advance troubleshooting that only people from Seca can provide. You may reach them through this.
Hope this helps.
Thank you for using FixYa.
Posted on Sep 19, 2011
Hi, this error code indicates an internal processing error and unfortunately it means that you will have to have it repaired. Often it is the "Stress/torsion bars" in the weighing part of the scales but not always. It is simply a generic fault indicator.
The best way to undertake this is to contact the manufacturer and ask for instructions on what to do? They may refer you to an authorised service center, or ask you to return it to the manufacturer itself? If worried about costings, and who isn't, simply first ONLY ask for a "Quote" as to prospective costings and go from there as to repair or replace?
Accordingly i give you the manufacturers link below.
http://www.seca.com/
SOURCE: I have a Seca 703
This could be a power issue. Make sure your battery pack wire connections are good. If they are loose, I suggest purchasing the Seca 400 power adapter, which works with this model.
Posted on Jun 14, 2012
For seca 763 having problem with the display. All led segment was displayed and weight is varying.Kindly help.
Try weighing an inanimate object, is the weight stable? Maybe you're stabalizing yourself by holding on to something? That will throw it off. all weight must be on the base and not moving to get an accurate reading. If it's still unstable it need new weight sensors and calibration. Probably not a DIY.
May 06, 2015 | Seca 763 Electronic Weighing and Measuring...
Seca 769 error code e.10.11
showing error code " Seca 769 error code e.10.11" how can i solve this problem.pls help me.
Oct 07, 2013 | Seca 769 Digital Scale 400 Lb with Bmi and...
I have a Seca 703 digital scales, When I turn on it says Er:1:40 Can you help me?
Sep 18, 2011 | Seca 769 Digital Scale 400 Lb with Bmi and...
Er: 1: 11 appears anytime anyone tries to weigh themselves.
I do not know this particular scale, but you might try this solution that works with many electronic scales. To activate the scale, lightly tap the scale, placing enough weight on the scale to initiate the electronic process. (A foot tap will do.) Wait for the display to show 0000 (or whatever the ready state display of your unit is), and THEN step on the scale.
Mar 03, 2011 | Seca 780 Robust Digital Column Scale /...
Seca 769 error code e.10.16
What does this code mean? How do I fix it?
Thank
Jun 03, 2010 | Seca 769 Digital Scale 400 Lb with Bmi and...
Balance beam wants to stick at about 300 lbs. not smooth moving
I contacted the manufacturer and here is there reply.
No need for oiling or grease, but tip the scale on its side, and look
under the base. There will be four "connection points" where pivot pins
connect to the linkage assembly; see if any of those pins or linkage
points are bent or look different from the other ones.
Then, note down the serial number of the scale located on the side of
the base, or behind the column of the scale at the top or bottom of the
column, and call our Maryland repair center at 800-542-7322 ext. 111 and
speak with Tyson Long from 9:00 AM - 4:00 PM Maryland time to describe
the issue and for further troubleshooting over the phone.
I have attached our new catalogue in PDF format as well. FYI: The model
703 is a very popular, extremely heavy-duty, high-capacity digital
column scale that is a popular alternative to the mechanical physician
scales in the gym and schools environment.
Kind regards,
William Morris
Sales Support
seca north america west
Medical Scales and Measuring Systems seca corp.
3401 Centrelake Drive, Suite 320
Ontario, CA 91761
USA
Telephone +1 909 605 7600
Telefax +1 909 605 7654
E-Mail william.morris@seca.com
Internet www.seca.com
Jan 26, 2009 | Seca 700KG Balance Beam Scale With Wheels,...
Err 12 and Err 16
Dear FixYA
Was advised to send to Scales to another company to be fixed. Therefore no longer need your assistance.
Thank you
Julia
Jan 22, 2009 | Seca 354 Digital Baby Scale Pediatric...
Seca 703 Digital Medical Column Scale Height Rod  BMI Function (7031321999) () Logo
327 people viewed this question
Top Seca Health & Beauty Experts
pawnpower
Jaye t rock
Tom Chichester
Are you a Seca Health and Beauty Expert? Answer questions, earn points and help others
