Question about KitchenAid KHMS147 Microwave Oven
Stooped Working After Installing Inside Microwave Light
I had installed the inside light into the socket located behind the vent grill and under the bulb cover. The light was on as I tried to feed the light into the light receptacle. As I did this the light went out and there was a small snapping noise. The microwave no longer works, no lights on the panel at all. I checked that the outlet still works (yes I should have unplugged the microwave before changing the bulb) and that the curcuit breakers did not trip off. Is it possible that I shorted-out the whole unit? If not what else shoudl I try. Is is worth the expense to have it serviced? The manual does not show that the unit has any internal fuse or reset button. We also let the unit unplugged overnight and replugged in this morning with no success.
  • KitchenAid Master
  • 9,098 Answers
Either a fuse blew or the control board is damaged.
A fuse can be replaced pretty easily, but if it's the circuit board, we repair those for $39.95 for customers nationwide. This is a common problem.
Be sure the oven is unplugged. Remove the vent grille again. You will now see a screw at the top of the control panel frame.
Remove that screw, then gently lift up & out and the control panel can be eased away from the chassis so you can see inside to find the fuse.
You can usually find helpful exploded view diagrams by entering your full model number here: http://tinyurl.com/gv383
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If you think the problem is on the control panel, please feel free to contact me directly.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 09, 2008
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Shorted out microwave when i tried tochange lightbulb. GE model jnm1731dm1bb, where is the fuse located?
The fuse is probably located behind the grille, and it may again be behind a small panel behind the grille. Look for the fuse label when you get the grille off.
There is a video here which shows you how to remove the grille.
But chances are good that you also damaged the circuit board when you removed or inserted the bulb without first unplugging the oven, as it says on the label by the light socket.
But that can usually be repaired economically repaired.
Or you can order and install a new smart board.
For model jnm1731dm1bb (also called JNM1731DMBB01) it is part number WB27X10933 and you can get it from the Pros here for $151.56.
Aug 10, 2013 | Smeg MD6CAS Microwave Oven
How do i change the bulb on ag821azh microwave x2
follow this steps and use the VOM for fix it. God bless you
Light Bulb
If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
Main Control Board
If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
Light Bulb Socket
If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
Jun 19, 2013 | Microwave Ovens
The lamp of won't work
follow the steps and fix it. God bless you
ight Bulb
Main Control Board
Light Bulb Socket
Jun 11, 2013 | Neff H5642 Convection / Microwave Oven
Frigidaire microwave oven
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb to the over the range microwave you will need to follow the steps below:
1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the vent grill mounting screws.
3. Pull the vent grill away from the unit.
4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
Note: DO NOT USE BULB LARGER THAN 30 WATTS.
Oct 27, 2012 | Frigidaire FMV152K Microwave Oven
Light won't go on; Model MMV1153WB-O
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
■ Cavity light: The cavity light bulb is located behind the vent
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
prototech@usa.net
May 06, 2010 | Maytag Over-the-Range Microwave
GE xl1800 active vent bulb replacement
I think the key is pulling the vent to the left.
From page 36 of the online version of the owner's manual, which also mentions the active grille's presence on some models:
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jan 10, 2009 | GE JVM1870 Microwave Oven
Microwave won't come on after circuit tripped
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Once you remove the control panel assembly, the fuse is located in a holder behind that area toward the top. The tech sheet shows part locations.
But you'll almost certainly need to have the control board repaired.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Nov 23, 2008 | Whirlpool MH1150XMQ Microwave Oven
Amana AM6177 Microwave
Interior light bulb is located behind the grill, above door. It requires removing 3 or 4 screws to remove grill. I have same problem. I pulled out bulb, it looks like it was glued in some type of foam material. There are two pin connectors at the mounting. but I can't see how they fit into bulb.
Apr 07, 2008 | Amana AMV6177 Convection/Microwave Oven
KitchenAid KHMS147 Microwave Oven Logo
82 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
